After upgrading JIRA from 6.4.7 to 7.1.7, I get a "JIRA Startup Failed" message via the GUI which states "Unable to load values for CacheKey[entityName=jira.properties,entityId=1]"
Environment: Windows 2012, SQL Server 2012 SP1
One thing I noted is that the collation is incorrect but i have no idea if this is what is causing the problem.
The following snipit is from the atlassian-jira.log file.
016-05-23 11:20:42,515 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml2016-05-23 11:20:42,625 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2016-05-23 11:20:42,625 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2016-05-23 11:20:43,546 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2016-05-23 11:20:43,562 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Product Version is 11.00.3000
2016-05-23 11:20:43,562 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2016-05-23 11:20:43,562 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Driver Version is 1.3.1
2016-05-23 11:20:44,640 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2016-05-23 11:20:44,640 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Product Version is 11.00.3000
2016-05-23 11:20:44,640 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2016-05-23 11:20:44,640 JIRA-Bootstrap INFO [o.o.c.entity.jdbc.DatabaseUtil] Database Driver Version is 1.3.1
2016-05-23 11:20:45,234 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is configured. Now running Database Checklist Launcher
2016-05-23 11:20:45,265 JIRA-Bootstrap WARN [c.a.j.appconsistency.db.CollationCheck]
You are using an unsupported mssql collation: SQL_Latin1_General_CP1_CS_AS. This may cause some functionality to not work.
Please use SQL_Latin1_General_CI_AI or SQL_Latin1_General_CP437_CI_AI as the collation instead.
2016-05-23 11:20:47,187 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully.
2016-05-23 11:20:47,187 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is configured. Now running Post database-configuration launchers
2016-05-23 11:20:49,875 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2016-05-23 11:20:50,375 JIRA-Bootstrap ERROR [c.a.jira.startup.ComponentContainerLauncher] A fatal error occurred during initialisation. JIRA has been locked.
com.opensymphony.module.propertyset.PropertyImplementationException: Unable to load values for CacheKey[entityName=jira.properties,entityId=1]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.propEx(CachingOfBizPropertyEntryStore.java:317)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.resolve(CachingOfBizPropertyEntryStore.java:113)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.getEntry(CachingOfBizPropertyEntryStore.java:131)
at com.atlassian.jira.propertyset.CachingOfBizPropertySet.get(CachingOfBizPropertySet.java:189)
at com.opensymphony.module.propertyset.AbstractPropertySet.getString(AbstractPropertySet.java:305)
at com.atlassian.jira.config.properties.ApplicationPropertiesStore.getStringFromDb(ApplicationPropertiesStore.java:225)
at com.atlassian.jira.config.properties.ApplicationPropertiesImpl.getString(ApplicationPropertiesImpl.java:51)
at com.atlassian.jira.config.properties.ApplicationPropertiesImpl.getEncoding(ApplicationPropertiesImpl.java:124)
at com.atlassian.jira.util.UriValidatorFactory.create(UriValidatorFactory.java:21)
at com.atlassian.jira.ContainerRegistrar.registerComponents(ContainerRegistrar.java:3376)
at com.atlassian.jira.ComponentManager.registerComponents(ComponentManager.java:422)
at com.atlassian.jira.ComponentManager.initialise(ComponentManager.java:139)
at com.atlassian.jira.ComponentManager.initialise(ComponentManager.java:149)
at com.atlassian.jira.startup.ComponentContainerLauncher.populateFullPicoContainer(ComponentContainerLauncher.java:47)
at com.atlassian.jira.startup.ComponentContainerLauncher.start(ComponentContainerLauncher.java:27)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$831(DefaultJiraLauncher.java:141)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:298)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:194)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:137)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$829(DefaultJiraLauncher.java:103)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:101)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:115)
at java.lang.Thread.run(Unknown Source)
Caused by: com.atlassian.cache.CacheException: com.querydsl.core.QueryException: Caught SQLException for select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype
from dbo.propertyentry O_S_PROPERTY_ENTRY
where O_S_PROPERTY_ENTRY.entity_name = ? and O_S_PROPERTY_ENTRY.entity_id = ?
order by O_S_PROPERTY_ENTRY.id desc
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:207)
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:158)
... 22 more
Caused by: com.querydsl.core.QueryException: Caught SQLException for select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype
at com.querydsl.sql.support.JavaSE7SQLExceptionWrapper.wrap(JavaSE7SQLExceptionWrapper.java:41)
at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:48)
at com.querydsl.sql.AbstractSQLQuery.fetch(AbstractSQLQuery.java:502)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.lambda$loadPropertyKeysAndTypes$648(CachingOfBizPropertyEntryStore.java:462)
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.lambda$executeQuery$776(DefaultQueryDslAccessor.java:79)
at com.atlassian.jira.database.DatabaseAccessorImpl.executeQuery(DatabaseAccessorImpl.java:67)
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.executeQuery(DefaultQueryDslAccessor.java:78)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.query(CachingOfBizPropertyEntryStore.java:278)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.access$200(CachingOfBizPropertyEntryStore.java:71)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.loadPropertyKeysAndTypes(CachingOfBizPropertyEntryStore.java:456)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.<init>(CachingOfBizPropertyEntryStore.java:416)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.loadPropertySetData(CachingOfBizPropertyEntryStore.java:264)
at com.atlassian.cache.memory.MemoryCacheManager$3$1.load(MemoryCacheManager.java:162)
at com.atlassian.cache.memory.DelegatingCache.lambda$get$0(DelegatingCache.java:158)
at com.atlassian.cache.memory.DelegatingCache.lambda$get$1(DelegatingCache.java:186)
at com.google.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:4742)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4739)
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:173)
... 24 more
Suppressed: java.sql.SQLException: Invalid column name 'entity_id'.
at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:372)
at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2988)
at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2421)
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:677)
at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:505)
at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeQuery(JtdsPreparedStatement.java:1029)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:83)
at com.querydsl.sql.AbstractSQLQuery.fetch(AbstractSQLQuery.java:446)
... 44 more
Suppressed: java.sql.SQLException: Invalid column name 'property_key'.
... 44 more
Suppressed: java.sql.SQLException: Invalid column name 'id'.
... 44 more
Caused by: java.sql.SQLException: Invalid column name 'entity_name'.
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:671)
... 44 more
2016-05-23 11:20:50,375 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Database transactions enabled: true
2016-05-23 11:20:50,390 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2016-05-23 11:20:50,406 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Database configuration OK
___ Database Configuration ________________
Loading entityengine.xml from : file:/C:/Program%20Files/Atlassian/JIRA/atlassian-jira/WEB-INF/classes/entityengine.xml
Entity model field type name : mssql
Entity model schema name : dbo
Database Version : Microsoft SQL Server - 11.00.3000
Database Driver : jTDS Type 4 JDBC Driver for MS SQL Server and Sybase - 1.3.1
Database URL : jdbc:jtds:sqlserver://dev-app-uat:1433/JIRA
Database JDBC config : mssql jdbc:jtds:sqlserver://dev-app-uat:1433/JIRA
2016-05-23 11:20:50,406 JIRA-Bootstrap ERROR [c.a.jira.startup.LauncherContextListener] Unable to start JIRA.
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.getType(CachingOfBizPropertyEntryStore.java:141)
at com.atlassian.jira.propertyset.CachingOfBizPropertySet.exists(CachingOfBizPropertySet.java:139)
at com.atlassian.jira.config.properties.ApplicationPropertiesStore.getOption(ApplicationPropertiesStore.java:157)
at com.atlassian.jira.config.properties.ApplicationPropertiesImpl.getOption(ApplicationPropertiesImpl.java:85)
at com.atlassian.jira.index.ha.DisasterRecoveryLauncher.getRecoveryMode(DisasterRecoveryLauncher.java:53)
at com.atlassian.jira.index.ha.DisasterRecoveryLauncher.earlyStart(DisasterRecoveryLauncher.java:102)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$831(DefaultJiraLauncher.java:143)
... 15 more
... 17 more
... 37 more
... 37 more
... 37 more
... 37 more
2016-05-23 11:20:50,421 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
These sort of errors mean one of two things - a broken connection to the database, or broken data in the database.
As your collation is wrong, it's probably the second one and you need to fix that to eliminate it as the cause.
Definitely was the case-sensitive vs case-insensitive. Once we changed that the JIRA instance came right up.
