Unable to add comments after upgrade to 9.12.2
tcarter
February 6, 2024
After upgrading to 9.12.2 we are unable to add comments to most projects.
Strangely, some projects still allow us to add comments.
The comment area is greyed out showing the "skeleton" instead of the actual comment section.
It appears the code to swap the skeleton to the "addcomment" <div> does not get called.
There are no console errors that indicate a JavaScript error.
How can I troubleshoot this further, or does anyone have a fix?
See the grey, empty, boxes in the attached images where the add comment section should go.
Finally, please note that at the top the "Add Comment" button that goes to another page works and we are using that as a workaround.
Parul Soni
December 27, 2024
Is it enabled, yet one cant add comments
alexchaychenko June 21, 2024
Enable service-desk-comment-field module in Service Desk plugin helped me.
SERVER
VERSION
9.12.2
