Unable to clear error message after entering wrong value in behaviour custom field
anshu02
November 6, 2019
We have a custom field where we want to get inputs between 1-10 only, and inputs apart from this range should give error message. So when we put incorrect value it gives the error message but after clearing the incorrect value and trying to keep the field blank it still throws error message.
This is the script which we are using:
def abvField = getFieldById("customfield_12404")
def abvValue = getFieldById("customfield_12404").getValue() as Integer //Actual Business Value
if (abvValue > 10 || abvValue <1 )
abvField.setError("This field should contain a number value between 1-10")
else { abvField.clearError()}
Leo
Hi @anshu02
Seems like this is a known issue with behaviour it does not work on when field clears it keep on holds the previous value
The workaround I can suggest you to consider script validator in workflow or custom listener
you can place validator script something like below
def value = cfValues['Filed Name for validation'] as Integer
if(value){
if(value < 11 && value > 0){
return true
else{
return false
else{
return true
BR,
Leo
Hemant August 28, 2020
Is there still no fix for this yet? @Leo
Really need to make use of the behavior plugin instead of the validator and this bug is causing huge trouble.
Would really appreciate any help
Alain Fragman
September 6, 2022
I have encountered the same issue on my end as well. Can someone comment on a possible workaround?
Robert Leachman
Also seemingly stuck on this in 2023. Any suggestions please?
Robert Leachman
October 6, 2023 edited
Looks like `clearError()` does the trick, this is working:
import static com.atlassian.jira.issue.IssueFieldConstants.*
def assignee = getFieldById(ASSIGNEE)
assignee.setRequired(true) // marks with red star. Unassigned still a valid value so:
def newAssignee = assignee.getValue() as String
// clear any previous error and then be sure the ticket gets assigned
assignee.clearError()
if (!newAssignee || newAssignee == "-1") {
assignee.setError("Assignee is required")
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
