Hi all!
I have been building a project plan, scrum based, including the estimated story points per epic. For some reason, when I ask to commit the changes, the system's response is "Unable to commit the item's story points". This is although these story points are aligned with the team's velocity and all.
What is the reason for this notice, and how do I solve it?
Thank you!
The Story Points custom field is not configured as Global Context or Story is not configured as Chosen Applicable Issue Types.
Find the Story Points custom fields and click on the "Cog" icon then select "Configure".
I went into the field configuration in JIRA and it is already set to Global Context.
I'm still getting the same issue the user is having where when I commit changes the points aren't coming over. I've not changed anything about the fields.
Same for me, any solution?
