This is usually down to a missing certificate somewhere. Usually on the server side, when one server (with incorrect or missing certificate(s) ) is missing
Have a run through https://confluence.atlassian.com/kb/ssl-and-application-link-troubleshooting-guide-719095282.html - that usually helps us find a missing or broken certificate.
I'm trying to call one of Confluence OOB REST APIs from within a Confluence java plugin, and the call is failing with this error.
It makes sense, since our Confluence is running over SSL. But what is the solution? Do I have to import Confluence SSL certificate in its own trust-store?
AI-curious? This series walks you through building Rovo Agents step by step, no matter your experience level. Multiple workshops available throughout October and November!
Register now
