Unable to create SUP
Himanshu Bansal September 21, 2023
I am facing an issue while creating an SUP post adding a few mandatory fields to a diff screen (resolve SUP)
Kindly help
Raul Pelaez _TecnoFor - Marketplace Partner_
Edit the Field Configuration and put as "Optional" the field "Root Cause"
After this, go to the Workflow and put a validator in the transition that opens the Resolution Screen in order to validate as mandatory the field "Root Cause"
Hope this helps! Regards!
Saikalyan Akunuri September 21, 2023 edited
Incase field is optional but still shows the error message there is a possibility that the message would have been set in script runner under behaviors.
Thanks @Raul Pelaez _TecnoFor - Marketplace Partner_ - It worked like charms
Supa dupa what is SUP for you?
SUP is support project.
I added a few mandatory fields in create SUP screen which were removed later and added to SUP resolution screen.
Now, I am unable to create a SUP ticket and the err says, "Root Cause is mandatory"
PS: This field is not a part of the create screen.
Pasam Venkateshwarrao
September 21, 2023
Hi @Himanshu Bansal
can you please provide the detail information so that i can investigate
Kindly look at the response above. I hope it helps you help me :)
Rilwan Ahmed
September 21, 2023
Hi @Himanshu Bansal ,
  1. Open the issue type workflow, check if there is any validator added for the create transition.  If it is present remove the validator, publish the workflow.
  2. Go to project settings --> Fields
    Check if "Root cause" field is marked as required. If yes, change it to optional
