HI,
We are on a process to migrate our jira to data center edition.
earlier our jira server is integrated with Nginx using SSL.
for test I had replicated the prod server and upgraded it to Data center edition and added node and both nodes are added to elb which is on http://
Now the issue is ELB is working fine and I can create a issue on elb its replicating on both the nodes. But I'm unable to create a issue or search in market place on my nodes. Its keep on loading & i cant find anything in logs either.
Hi Vivek,
I guess you should not access the nodes directly (the load balancer will take care of directing you to the right node) - why do you need to do it?
Christoph
