×Dear all,
I have installed a trial version and working with JIRA the first time. When trying to create a new (my first) project I receive the following error message:
hmm... we couldn't create your project due to an unknown error
I found an article which suggested to run integrity check and resolve any issues foud. I ran the integrity checker and there was one issue I was able to resolve ther found error with the tool. However my issue to create a project is still there. Did anybody had the same issue and a clue how to resolve it?
Andreas
2017-03-18 22:37:03,001 http-nio-8080-exec-22 ERROR q351292 1357x1052x1 1ldzv4q 172.27.244.24 /rest/project-templates/1.0/templates [c.a.p.r.c.error.jersey.ThrowableExceptionMapper] Uncaught exception thrown by REST service: An error occurred while notifying that a project was created
java.lang.RuntimeException: An error occurred while notifying that a project was created
at com.atlassian.jira.bc.project.DefaultProjectService.notifyHandlersOfProjectCreated(DefaultProjectService.java:397)
at com.atlassian.jira.bc.project.DefaultProjectService.createProjectInternal(DefaultProjectService.java:379)
at com.atlassian.jira.bc.project.DefaultProjectService.createProject(DefaultProjectService.java:349)
at sun.reflect.GeneratedMethodAccessor626.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy282.createProject(Unknown Source)
... 2 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
at com.atlassian.jira.projecttemplates.service.ProjectTemplateServiceImpl.applyProjectTemplate(ProjectTemplateServiceImpl.java:173)
at com.atlassian.jira.projecttemplates.rest.ProjectTemplatesResource.createProjectFromFormRequest(ProjectTemplatesResource.java:170)
... 3 filtered
at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60)
... 12 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:154)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:68)
... 36 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 53 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:80)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:78)
... 16 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
... 20 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 29 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 28 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Hello Quentin, Niclas,
Thank you Niclas and Quentin for your answers. However this wasn't my issue.
In the meanwhile I was in Contact with Atlassian Support.
I have installed JIRA 7.3.3 in a PostgreSQL DB in another schema than public (default in PG). JIRA let you do so during the installation. However obviously there are issues in the JIRA product in later steps during the usage.
We found out that the SQL Statement for creating a project does not consider schmea prefix to address the table were the primary key and the rest of the project details need to be written into the DB. So JIRA tries to find the a table called AO_B9A0F0_APPLIED_TEMPLATE in the public schema, but can't find it there, becuase I used a different schema. JIRA should call the table with MySchemaName.AO_B9A0F0_APPLIED_TEMPLATE.
You can set the default search_path at the database level:
ALTER DATABASE <database_name> SET search_path TO schema1,schema2;
Or at the user or role level:
ALTER ROLE <role_name> SET search_path TO schema1,schema2;
I have tested it with the ALTER DATABASE solution, in your case I think it would
I hope this will help other for the time the fix will take!
Andreas
Thank you for sharing your experience!
Hello, maybe this documentation could help you :
Assuming you have a standard connection to tomcat and installation is vanilla there should be no issue creating a project. Since its your first install I would not put to much effort investigating.
Try installing a New fresh instance of 7.3.3 in a virtualbox or suitable lab space and compare results. Maybe even use the built in DB.
Hello Niclas,
I was using 7.3.1, however I'm currently trying to install it from scratch and will continue with the most recent version 7.3.3.
Yes it is the first project I tried to create.
Andreas
Whats version you trying with and is this the first project you try to create?
