Unable to create zephyr test execution using postman api in jira?
sai chinamuthevi
i have created a body like this
  "cycleId": "-1",
  "issueId": "1821331",
  "projectId": "24771",
  "versionId": "10001",
  "assigneeType": "assignee",
  "assignee": "",
  "folderId": ""
even after getting 200 response test execution was not created in jira issue
Zephyr QA January 31, 2022
Hi @sai chinamuthevi
can you please use the below API for creating execution , if you are using  Zephyr Cloud:
https://zfjcloud.docs.apiary.io/#reference/execution/add-tests-to-folder/create-execution
Sample request:
POST /connect/public/rest/api/1.0/execution HTTP/1.1
Host: prod-api.zephyr4jiracloud.com
Authorization: JWT XXXXX(using script)
zapiAccessKey:  Access key copy from zephyrsquad menu
Content-Type: application/json
Cache-Control: no-cache
Postman-Token: b5a56b25-a61b-befd-1804-32cd35398d07
"cycleId": "-1",
"issueId": "10414",
"projectId": "10009",
"versionId": "-1",
"assigneeType": "",
"assignee": "",
"folderId": ""
Sample Response:
"warningMessage": null,
"originMessage": null,
"execution": {
"id": "19b7f4e3-9b28-467c-a00b-6a4dbfa97b8b",
"issueId": 10414,
"versionId": -1,
"projectId": 10009,
"cycleId": "-1",
"orderId": 1,
"createdBy": "XXXXX",
"createdByAccountId": "XXXXX",
"status": {
"name": "UNEXECUTED",
"id": -1,
"description": "The test has not yet been executed. edited",
"color": "#A0A0A0",
"type": 0
"cycleName": "Ad hoc",
"creationDate": 1643623868441,
"executedByZapi": true,
"folderId": "",
"zfjIndexType": "execution",
"issueTypeId": 10005,
"projectType": "classic",
"issueIndex": 10414,
"projectCycleVersionIndex": "10009_-1_-1",
"executionStatusIndex": -1,
"projectIssueCycleVersionIndex": "10009_10414_-1_-1"
"issueKey": "Z8-56",
"issueLabel": "BDD_Scenario",
"component": null,
"issueSummary": "test3",
"issueDescription": "",
"projectName": "Zsqaud 802",
"versionName": "Unscheduled",
"priority": "Lowest (migrated)",
"priorityIconUrl": null,
"executedByDisplayName": null,
"assigneeType": null,
"assignedToDisplayName": null,
"testStepBeans": null,
"defectsAsString": "",
"projectKey": "Z8",
"plannedExecutionTimeFormatted": null,
"actualExecutionTimeFormatted": null,
"executionWorkflowStatus": null,
"workflowLoggedTimedIncreasePercentage": null,
"workflowCompletePercentage": null,
"versionReleased": false,
"customFieldValuesAsString": null,
"viewIssuePermission": true,
"executionWorkflowEnabled": false
if you need more details please reach out to zephyr support :
https://support.smartbear.com/zephyr-squad/message/?product=zephyr_for_jira_cloud
Zephyr QA
sai chinamuthevi
we are using zephyr squad and our's is data center not cloud.
after executing them in data center getting response 200 but no execution has been created.
Like Jeanette likes this
