Unable to delete group in JIRA.
Nallusamy Narayanaswamy
I want to delete some unwanted groups in JIRA. Those groups were getting synced from AD. Now, We have deleted them on AD and want to delete it from JIRA also.
But, It throws an error "You do not have permission to remove this group from all the directories in which it occurs." when I try to delete it.
Can anyone pls guide me?
Nic Brough -Adaptavist-
June 12, 2020
Your system is using an external user directory to handle (some or all of) its users and groups.
This directory is set up so that Jira can not delete groups from it.
Thanks for the reply @Nic Brough -Adaptavist-
Is there anything I can change on the User Directory configuration to delete that group? or If that group is deleted on AD (external directory), will get it deleted automatically on JIRA as well?
June 12, 2020
If you remove a group from AD, that will be updated next time Jira runs a sync.
You can check the user directory list to see how often the sync runs, and also if the directory is read-only on the Jira end.  But be aware that you can tell Jira that a directory is read/write while being read-only on the directory side.  You'll need to check the AD config to see if that is read/write as well, whatever Jira is showing.
ok. Thanks @Nic Brough -Adaptavist-
It is marked as read-only on JIRA side.
Like • Ola_Sugar likes this
