Unable to enable pending triage to Priority Scheme
Ramya Yarru March 29, 2021 edited
Hello Team,
I have a  Priority Scheme associated with Issue Type Priority Schemes linked to a project.
I have added Pending triage to priorities but for some reason I'm unable to enable pending triage to Priority Scheme whereas I could enable all other priorities.
Nic Brough -Adaptavist-
March 30, 2021
What do you mean by "unable to enable"?  Could you describe the exact symptoms?
Ramya Yarru March 30, 2021
@Nic Brough -Adaptavist- If you see in the attached screenshot, there is an option to enable which enables the priority for issue. Though I click on Enable, nothing happens it's still in disabled mode whereas I could enable all other priorities.
March 30, 2021
Odd, but it *might* be down to a controlled priority.
Can you try renaming the priority and seeing if you can then enable it?
Ramya Yarru March 31, 2021 edited
@Nic Brough -Adaptavist- I'm able to edit or rename but I'm still unable to enable its o recreating it fixed the issue.
KAGITHALA BABU ANVESH
March 29, 2021
Hello @Ramya Yarru ,
Can you please help me by providing the below details.
1. Which Version of Jira you using.
2.May I Know what is meant by  Issue type priority Scheme ?
Anvesh
@KAGITHALA BABU ANVESH I'm using Jira v8.6.1 and Issue type priority Scheme allows you to control which Priorities can be used for particular issue types.
March 30, 2021
I think we have only one priority scheme is used within the project for all issue types.
We don't have different priority schemes for issue types in Single project. that's why i felt a bit confused.
Please recheck once.
Anvesh
