Unable to enable plugin after upgrade
rodney ellis
February 18, 2020
2020-02-18 15:15:44,713+0000 ThreadPoolAsyncTaskExecutor::Thread 52 ERROR rodney@synthesis.co.za 915x112471x1 r6xnu3 154.117.184.110,172.16.1.132 /rest/plugins/1.0/com.codebarrel.addons.automation-key [c.a.p.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin 'com.codebarrel.addons.automation'
org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from URL [bundle://283.0:0/META-INF/spring/plugin-context.xml]; nested exception is java.lang.IllegalStateException: The bundle is uninstalled.
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:414)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:336)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:304)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:187)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:223)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:194)
at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:171)
at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:141)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:133)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:619)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$800(AbstractDelegatedExecutionApplicationContext.java:57)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$3.run(AbstractDelegatedExecutionApplicationContext.java:239)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.startRefresh(AbstractDelegatedExecutionApplicationContext.java:217)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:224)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:177)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:154)
at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$1.run(LifecycleManager.java:213)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.IllegalStateException: The bundle is uninstalled.
at org.apache.felix.framework.Felix.getBundleResources(Felix.java:1706)
at org.apache.felix.framework.BundleImpl.getResources(BundleImpl.java:689)
at org.eclipse.gemini.blueprint.util.BundleDelegatingClassLoader.getResources(BundleDelegatingClassLoader.java:186)
at org.springframework.core.io.support.PropertiesLoaderUtils.loadAllProperties(PropertiesLoaderUtils.java:178)
at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.getHandlerMappings(DefaultNamespaceHandlerResolver.java:164)
at org.eclipse.gemini.blueprint.extender.internal.support.NamespacePlugins$Plugin.resolve(NamespacePlugins.java:77)
at org.eclipse.gemini.blueprint.extender.internal.support.NamespacePlugins$5.operate(NamespacePlugins.java:209)
at org.eclipse.gemini.blueprint.extender.internal.support.NamespacePlugins$5.operate(NamespacePlugins.java:205)
at org.eclipse.gemini.blueprint.extender.internal.support.LazyBundleRegistry.apply(LazyBundleRegistry.java:159)
at org.eclipse.gemini.blueprint.extender.internal.support.NamespacePlugins.doResolve(NamespacePlugins.java:205)
at org.eclipse.gemini.blueprint.extender.internal.support.NamespacePlugins.resolve(NamespacePlugins.java:169)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.gemini.blueprint.context.support.TrackingUtil$OsgiServiceHandler.invoke(TrackingUtil.java:106)
at com.sun.proxy.$Proxy612.resolve(Unknown Source)
at org.eclipse.gemini.blueprint.context.support.DelegatedNamespaceHandlerResolver.resolve(DelegatedNamespaceHandlerResolver.java:55)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1361)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1352)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:178)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.doRegisterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:148)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:98)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:508)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:392)
... 20 more
2020-02-18 15:15:44,742+0000 ThreadPoolAsyncTaskExecutor::Thread 52 ERROR rodney@synthesis.co.za 915x112471x1 r6xnu3 154.117.184.110,172.16.1.132 /rest/plugins/1.0/com.codebarrel.addons.automation-key [o.e.g.b.e.internal.support.ExtenderConfiguration] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.codebarrel.jira.plugin.automation-for-jira, config=osgibundle:/META-INF/spring/*.xml))
... 2 filtered
... 20 more
2020-02-18 15:15:44,743+0000 ThreadPoolAsyncTaskExecutor::Thread 52 ERROR rodney@synthesis.co.za 915x112471x1 r6xnu3 154.117.184.110,172.16.1.132 /rest/plugins/1.0/com.codebarrel.addons.automation-key [o.e.g.b.e.i.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.codebarrel.jira.plugin.automation-for-jira], unsatisfied dependencies: none
... 2 filtered
... 20 more
2020-02-18 15:16:18,430+0000 plugin-transaction-0 INFO [c.a.jira.plugin.PluginTransactionListener] [plugin-transaction] numberStartEvents:608, numberEndEvents:608, numberSendEvents:421, numberEventsInTransactions:12860, numberOfPluginEnableEvents:283
sukkeong
December 9, 2021
(Incorrectly placed. Moved as reply to answer by Atlassian team)
Earl McCutcheon
February 19, 2020
Hello @rodney ellis ,
When encountering an "Unable to start the plugin container for plugin" error, leading to an Add-on failure post upgrade the issue is usually related to corruption in the plugin caching, especially as there are several mentions of "The bundle is uninstalled" in the error output, pointing further to a caching issue.
I would recomend a manual plugin cache flush as the first step and let me know how it goes.  To do this:
  • Stop Jira
  • Remove the ".bundled-plugins" and ".osgi-plugins" manually from the "<JIRA Home>/plugins" directory (These files are hidden by default):
$jira-home/plugins/.bundled-plugins
$jira-home/plugins/.osgi-plugins
  • Delete the contents of the work directory (!) Only remove the contents, do not remove the directory itself, or the path will not rebuild correctly:
$jira-install/work/*
  • Restart Jira, and watch the startup logs for any additional errors
If there are additional errors with plugin startup, let me know what you find and I can take a closer look.
Earl
sukkeong
December 9, 2021
I currently have the same issue  with the migration from JIRA7.13 to JIRA8.13. My plugin that builds on top of jira-remote-copy-plugin (from AtlassianLabs). The jira-remote-copy-plugin was able to be recompiled from source and deployed successfully. Despite updating the dependencies version reflecting the same version as jira-remote-copy-plugin, the error persist.
[c.a.p.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin 'com.thales.jira.rhythm'
org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Unable to locate Spring NamespaceHandler for XML schema namespace [http://www.eclipse.org/gemini/blueprint/schema/blueprint]
Offending resource: URL [bundle://236.0:0/META-INF/spring/atlassian-plugins-component-imports.xml]at org.springframework.beans.factory.parsing.FailFastProblemReporter.error(FailFastProblemReporter.java:72)
at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:119)
at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:111)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.error(BeanDefinitionParserDelegate.java:281)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1388)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1371)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:179)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.doRegisterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:149)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:96)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:514)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:394)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:337)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:305)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:188)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:224)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:195)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:637)
SDK used: 8.0.16
@Earl McCutcheon
Tried the suggestions above without any success
sukkeong
December 9, 2021
I was able to enable 1 of 2 plugins that had failed with this error, by removing <component-import ... > and adding "@ComponentImport" instead.
Second plugin which is more complicated, extending the functionality of jira-remote-copy-plugin and bundling the plugin within still cannot be enabled.
