Unable to generate OAuth Access token
Ashvik Mohan January 4, 2018
After configuring Application link for OAUTH authentication , i tried to create request token using following command in command prompt i'e
C:\OAuthJar>java -jar rest-oauth-client-1.0.one-jar.jar requestToken  https://testjira18.atlassian.net
but it return error on my command prompt .
please guide me to generate request token which will help me to integrate with JIRA
regards
Ashvik
Gonchik Tsymzhitov
Hi!
Could you generate from other scripts?
https://bitbucket.org/atlassian_tutorial/atlassian-oauth-examples
For example, from python script it works
Gonchik Tsymzhitov
Register now
