Unable to get Atlassian SDK to run from /opt dir
Richard Snyder May 28, 2024 edited
I'm new to this, but I've been trying to install the atlassian sdk and I'm stuck on a step that isn't well documented.  From this link: https://developer.atlassian.com/server/framework/atlassian-sdk/install-the-atlassian-sdk-on-a-linux-or-mac-system/https://community.atlassian.com/t5/Products/ct-p/products
I followed the .tgz file approach.  I placed the sdk in the /opt directory.  Then to test the instructions state to open a terminal and just run "atlas-version".  I get nothing.  I get:
bash: atlas-version: command not found.
Now if I navigate into the /opt/atlassian-plugin-sdk/bin and run the atlas-version directly it works.  What linking am I missing?  I would think additional hooks would need to be setup for an application to be run in the /opt dir.
Robert Wen_Cprime_
Hi @Richard Snyder !  Welcome to the Atlassian Community!
This sounds like you didn't set your PATH environment variable.  Basically, Linux checks the directories in the PATH environment variable when evaluating whether something is a command to run.
To append the Atlassian SDK path type:
> export PATH="/opt/atlassian-plugin-sdk/bin:$PATH"
Note this works as long as the shell is active.  To make the changes permanent, add the same line to your .bashrc
Richard Snyder May 29, 2024
Thank you for that information, it's basic but I was having a hard time figuring it out.  Not sure if it should be included in the instructions linked above, but it would be helpful as a tip in step 3.
