Unable to hide Custom Field in Edit Screen
J Manas Kumar
December 17, 2019 edited
Hi I have a Edit type Custom Field, which i am using for section divider, but when i am trying to hide that field using by name or field ID i am unable to do it. i have added the field screenshot below.custom field.PNG custom field 1.PNG
Alexander Ling
December 18, 2019
Hello @J Manas Kumar
Where are you trying to hide your field? What fields that are showing on an issue is based on some different aspects in which the basic ones are:
  • Is the field on the corrects screens?
  • The field configuration for the issue type
  • Does it contain any value? (otherwise it will be hidden in the view screen)
So I would take a look at those aspects and get back to me if you have any questions. I found this link about the Message Custom Field (for edit). I'll put it here in case it's useful.
Best regards,
Alexander
J Manas Kumar
December 18, 2019 edited
Hi @Alexander Ling
actually i have created custom edit field to use as a section divider, so under the section divider i have some fields, in the edit page of an issue i am able to hide those fields but unable to hide the Section Divider field.
For reference i have added a screen share , here you can see when my project type == agile , i am able to hide SDLC fields but the SDLC section field i am not able to hide.
Yes it has a value , i have added in field configuration in value field = "<h3><strong>SDLC Requirements</strong></h3>".
this HTML code i have added , so that the section could get a name.So here you can see that how this is happening, i mean fields are hidden but the section is not hidden, i even tried with GetFieldByID and Name, but nothing seems working.
Register today
