I'm trying to install JSS 2.1.2.
It needs quickedit modification(adding Export-Package: com.atlassian.jira.quickedit.* in MANIFEST.MF of quickedit plugin) and issuenav modification(adding Export-Package: com.atlassian.jira.plugin.issuenav.* in MANIFEST.MF of issuenav plugin).
But still the quickedit and issuenav modules of jss gets disabled.
I tried the following content of export-package in quickedit:
Export-Package: com.atlassian.jira.quickedit.rest.api;uses:="javax.xml .bind.annotation",com.atlassian.jira.quickedit.rest;uses:="com.atlass ian.jira.quickedit.rest.api,com.atlassian.jira.rest.api.http,com.atla ssian.jira.quickedit.user,javax.ws.rs,com.atlassian.crowd.embedded.ap i,com.atlassian.jira.security,javax.ws.rs.core";version="1.0.36",com. atlassian.jira.quickedit.user;uses:="com.atlassian.jira.quickedit.res t.api,com.atlassian.crowd.embedded.api,com.opensymphony.module.proper tyset,com.atlassian.jira.user,com.atlassian.jira.util.dbc,org.apache. commons.lang",com.atlassian.jira.quickedit.action;uses:="com.atlassia n.jira.issue.issuetype,com.google.common.base,com.atlassian.jira.conf ig.properties,com.atlassian.jira.exception,com.atlassian.jira.util,co m.atlassian.jira.quickedit.user,org.apache.log4j,com.atlassian.jira.w eb.action,com.atlassian.crowd.embedded.api,com.atlassian.jira.project ,com.atlassian.jira.issue.customfields,com.atlassian.jira.bc.issue,co m.atlassian.jira.security.xsrf,webwork.action,com.atlassian.jira.user ,com.atlassian.jira.quickedit.rest.api.field,org.apache.commons.lang. exception,com.atlassian.jira.security,com.atlassian.jira.issue.fields .config.manager,com.atlassian.plugins.rest.common.json,com.google.com mon.collect,com.atlassian.jira.web.action.issue,com.atlassian.jira.is sue,com.atlassian.jira.rest.api.util,com.atlassian.jira.quickedit.res t.api,org.ofbiz.core.entity,com.atlassian.jira.issue.operation,com.at lassian.jira.config,com.atlassian.jira.issue.fields,com.atlassian.jir a.issue.fields.screen,javax.servlet.http",com.atlassian.jira.quickedi t.rest.api.field;uses:="org.apache.commons.lang.builder,javax.xml.bin d.annotation,com.atlassian.jira.util.dbc,com.atlassian.jira.quickedit .rest.api,webwork.action,com.atlassian.crowd.embedded.api,com.atlassi an.jira.issue,com.atlassian.jira.issue.customfields,com.atlassian.jir a.issue.fields.screen,com.atlassian.jira.util,com.atlassian.jira.issu e.fields.layout.field,org.apache.commons.lang,com.atlassian.jira.issu e.operation,com.atlassian.jira.util.collect,com.atlassian.jira.issue. fields,com.atlassian.jira.security"
it is working fine for quickedit and module got enabled in JSS.
But I do not know what content of export-package needs to be added for issuenav.
Could anybody help me please?
Thanks a million in advance!
Hey there again, chintu.
You are most welcome! Perhaps you have to give them some time to get back to you on the mail.
I think you can also try to call them directly as well.
Warm regards,
Danial
Hey there, Chintu.
In this case, I would recommend you to contact the respective plugin vendor to address the problem that you have when installing the plugin. Kindly refer to the following details below:
This will speed things up since they will be the best point of contact to assist you with the issue. Hope this helps.
Warm regards,
Danial
Hi Ahmad,
Thanks for your info!
I sent mails to <span>sales@quisapps.com and </span>shchagin@quisapps.com, but I did not get any reply. Could anybody help me on this?
Thanks in advance!
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
