Unable to run groovy script in JIRA 5.1
swati sneha October 18, 2012
I am using a grrovy script for workflow transition. On the transition, it is showing following excepton/error in the log file:
The script failed : javax.script.ScriptException: javax.script.ScriptException: javax.naming.NameNotFoundException: Name jdbc is not bound in this Context"
JamieA
October 24, 2012
swati sneha October 21, 2012
def getSQL = {
Context initialContext = new InitialContext();
if ( initialContext == null) {
log("JNDI problem. Cannot get InitialContext.");
System.exit(0)
DataSource datasource = (DataSource)initialContext.lookup("java:comp/env/jdbc/defaultDS");
if (datasource == null) {
log("Failed to lookup datasource.")
System.exit(0)
new Sql(datasource)
*Note: defaultDS is the datasource name.
Regards
Swati
Mizan
October 18, 2012
can you share the script ? what the script does ?
Nic Brough -Adaptavist-
October 18, 2012
You've got an invalid call to the database stuff in your script. You'll need to give us more information - the section of script causing the problem would be a start.
swati sneha October 24, 2012
def getSQL = {
System.exit(0)
System.exit(0)
new Sql(datasource)
Regards
Swati
