Unable to select label
Daniel_Drion
I'm unable to select a label.
When I try to select a label, nothing happens.
This is both in Chrome and in Internet Explorer.
Is there a setting to disable the selection of labels ?
Or is something wrong in the application ?
Andrey K. LEAD PM
February 13, 2020 edited
Issue has been resolved, at least for Jira Cloud.
Daniel_Drion
Thank you for the update
PaoloKivra February 13, 2020
Yes it works, thanks!!
Ilham RADITO
February 13, 2020
Do put your support ticket here @Daniel_Drion so we can vote it.
Andrey K. LEAD PM
same to me. I can change / edit labels in OLD VIEW but not in NEW VIEW. This is for Jira Cloud.
Daniel_Drion
Ok, I'll raise a support ticket for Jira Cloud
Like • PaoloKivra likes this
Andrey K. LEAD PM
Great. I also raised one.
What is the OLD VIEW, how to get there?
Andrey K. LEAD PM
Please check screenshot:
Thanks, I cannot see any of the "New Jira Issue View" options, I am using Next-Gen maybe that's why
Andrey K. LEAD PM
@PaoloKivra yes, I think that's the reason. I am using classical software project.
Adriano Attolico
February 13, 2020
same issue, is possible to insert labels while creating but not possible after to edit
Same here, I need it fixed
Daniel_Drion
Hi Poalo,
if you switch to the old version, it might work again.
To switch to the old version : click on you avatar icon - settings
Then deactivated the new version by turning the switch off
But for company boards and next-gen projects it doesn't work
If you click on Jira software in the left corner and click on Issues and filters and then All Issues, you get a list of all issues and then you click on the issue you want to change, then you can change the label
Aha! Thanks a lot!
Like • Daniel_Drion likes this
Rahul Rakesh
February 13, 2020
Same here. Suddenly the labels field has stopped working. Its greyed out.
