I am running JIRA 5.0.3 in my system .
OS-Windows 7
I have my own plugins and when i ever i try to run jira by atlas-debug i get this exception-
Skipping OBR generation... no OSGi bundle manifest instructions found in pom.xm
[jira:test-jar]
[amps-dispatcher:debug]
[jira:debug {execution: virtual-execution}]
] BUILD ERROR
Unable to execute mojo
ed error: java.net.UnknownHostException: marketplace.atlassian.com
For more information, run Maven with the -e switch
This was not happening before,I see that it is trying to contact marketplace.atlassian.com but my proxy is not allowing.Any idea how to fix this?
Try this...
atlas-debug --jvmargs -Dhttp.proxyHost=proxy -Dhttp.proxyPort=8080 -Dhttps.proxyHost=proxy -Dhttps.proxyPort=8080
why does this work and running atlas-debug on its own gives the mojo exception?
I faced this error intermittently. Even though the proxy details are specified in maven settings xml, I am not sure why but for some unknown reason the Java do not pick these proxy settings and hence we pass the proxy information directly to the process as JVM arguments.
Not sure if below helps.
Just noting my experience with "Unable to execute mojo exception".
I was getting "Unable to execute mojo exception" when running atlas-run -Dhttps.proxyHost=xxx.xxx.x.xx -Dhttp.proxyHost=xxx.xxx.x.xx -Dhttps.proxyPort=80 -Dhttp.proxyPort=80 when developing a Confluence plug-in.
I had edited C:\QA\atlassian-plugin-sdk\apache-maven\conf\ settings.xml
And added Proxies there too (see below).
When I removed the settings.xml changes, I no longer get "Unable to execute mojo exception"
I now get
[INFO] confluence started successfully in 180s at http://MN26C001162386:1990/confluence
[INFO] Type Ctrl-D to shutdown gracefully
[INFO] Type Ctrl-C to exit
Problem fixed. :)
<!-- proxies
| This is a list of proxies which can be used on this machine to connect to the network.
| Unless otherwise specified (by system property or command-line switch), the first proxy
| specification in this list marked as active will be used.
| -Dhttps.proxyHost=xxx.xx.x.xx -Dhttp.proxyHost=xxx.xx.x.xx -Dhttps.proxyPort=80 -Dhttp.proxyPort=80
<proxies>
<proxy>
<active>true</active>
<protocol>http</protocol>
<username></username>
<password></password>
<host>xxx.xx.x.xx</host>
<port>80</port>
<nonProxyHosts></nonProxyHosts>
</proxy>
<proxy>
<protocol>https</protocol>
<port>80</port>
</proxy>
</proxies>
What if we are not connected to the internet?
I tried the flag "-Dupm.pac.disable=true" with these both commands:
atlas-run -Dupm.pac.disable=true
atlas-run --jvmArgs '-Dupm.pac.disable=true'
atlas-run --jvmargs '-Dupm.pac.disable=true'
None are working. Atlassian sdk 4.2.7
I'm behind a quite restrictive firewall, and can't access lots of hosts. So I would like to disable it. Any clue?
Arg... it works when adding the "-o" (offline) option
great!
Answed by Erik Salko-Saari .. I tried that it worked out thanks.
Restarting might help
You are connecting to the web?
[INFO] No manifest found or validation skip flag specified, skipping validation [INFO] [jira:jar] [INFO] [jar:jar] [INFO] Building jar: C:\Users\i065939\PERFORCEWORKSPACE\jira\JiraExt\dev\SAP-JIRA-SERVICES\target\SAP-JIRA-SERVICES-1.0.2.jar [INFO] [jira:generate-obr-artifact] [INFO] Skipping OBR generation... no OSGi bundle manifest instructions found in pom.xml [INFO] [jira:test-jar] [INFO] [amps-dispatcher:debug] [INFO] [jira:debug {execution: virtual-execution}] [INFO] ------------------------------------------------------------------------ [ERROR] BUILD ERROR [INFO] ------------------------------------------------------------------------ [INFO] Unable to execute mojo Embedded error: java.net.UnknownHostException: marketplace.atlassian.com [INFO] ------------------------------------------------------------------------ [INFO] Trace org.apache.maven.lifecycle.LifecycleExecutionException: Unable to execute mojo at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:703) at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeStandaloneGoal(DefaultLifecycleExecutor.java:553) at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:523) at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:371) at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:332) at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:181) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:356) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:137) at org.apache.maven.cli.MavenCli.main(MavenCli.java:356) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315) at org.codehaus.classworlds.Launcher.launch(Launcher.java:255) at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430) at org.codehaus.classworlds.Launcher.main(Launcher.java:375) Caused by: org.apache.maven.plugin.MojoExecutionException: Unable to execute mojo at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:128) at org.twdata.maven.mojoexecutor.MojoExecutor$ExecutionEnvironmentM2.executeMojo(MojoExecutor.java:466) at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojo(MojoExecutor.java:80) at com.atlassian.maven.plugins.ampsdispatcher.AbstractAmpsDispatcherMojo.execute(AbstractAmpsDispatcherMojo.java:64) at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:483) at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:678) ... 16 more Caused by: java.lang.RuntimeException: java.net.UnknownHostException: marketplace.atlassian.com at com.atlassian.maven.plugins.updater.MarketplaceSdkResource.getPluginJsonAsMap(MarketplaceSdkResource.java:136) at com.atlassian.maven.plugins.updater.MarketplaceSdkResource.getLatestSdkVersion(MarketplaceSdkResource.java:98) at com.atlassian.maven.plugins.amps.util.UpdateCheckerImpl.check(UpdateCheckerImpl.java:57) at com.atlassian.maven.plugins.amps.DebugMojo.doExecute(DebugMojo.java:40) at com.atlassian.maven.plugins.amps.AbstractProductHandlerMojo.execute(AbstractProductHandlerMojo.java:650) at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:483) at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:126) ... 21 more Caused by: java.net.UnknownHostException: marketplace.atlassian.com at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:195) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366) at java.net.Socket.connect(Socket.java:529) at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:559) at com.sun.net.ssl.internal.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:141) at sun.net.NetworkClient.doConnect(NetworkClient.java:163) at sun.net.www.http.HttpClient.openServer(HttpClient.java:394) at sun.net.www.http.HttpClient.openServer(HttpClient.java:529) at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:272) at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:329) at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:172 at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:911) at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:158) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1172) at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:234) at com.atlassian.maven.plugins.updater.MarketplaceSdkResource.getPluginJsonAsMap(MarketplaceSdkResource.java:133) ... 27 more
Yes I am.Here is the stack trace
If you use a proxy, I think that you must do some configuration in your file settings.xml
INFO] [jar:jar]
INFO] Building jar: C:\git\stash-notify-push-to-ref-hook\target\stash-notify-push-to-ref-hook-1.0.0-SNAPSHOT.jar
INFO] [stash:generate-obr-artifact]
INFO] [stash:test-jar]
INFO] [stash:debug {execution: virtual-execution}]
ERROR] BUILD ERROR
mbedded error: java.net.ConnectException: Connection timed out: connect
INFO] For more information, run Maven with the -e switch
INFO] Total time: 1 minute 8 seconds
INFO] Finished at: Tue Dec 31 13:15:52 CST 2013
INFO] Final Memory: 108M/313M
This was not happening before.
I have the same issuse the above solution didnt help . Is there any other soloution?
Register now
