I keep seeing this error on JIRA restart (and on installation of Script Runner plugin). Can anyone please offer advice?
I'm running JIRA 5.0 Standalone and the Script Runner plugin is version 2.1.17. Log from startup pasted below.
I found some other answers that suggest adding JVM arguments, so I added the following to setenv.sh.
JVM_EXTRA_ARGS="${JVM_EXTRA_ARGS} -XX:ReservedCodeCacheSize=128m"
Also tried increasing PERMGEN to 512 but still get the same error.
[rogerw@krkdevrogerw1 atlassian]$ sudo jira/bin/start-jira.sh ;tail -f jira-home/log/atlassian-jira.log To run JIRA in the foreground, start the server with start-jira.sh -fg executing as current user ..... .... .NMMMD. ... .8MMM. $MMN,..~MMMO. .?MMM. .MMM?. OMMMMZ. .,NMMMN~ .IMMMMMM. .NMMMN. .MMMMMN, ,MMMMMM$..3MD..ZMMMMMM. =NMMMMMM,. .,MMMMMMD. .MMMMMMMM8MMMMMMM, .ONMMMMMMMMMMZ. ,NMMMMMMM8. .:,.$MMMMMMM .IMMMM..NMMMMMD. .8MMMMM: :NMMMMN. .MMMMMM. .MMMMM~. .MMMMMN .MMMMM?. Atlassian JIRA Version : 5.0 Detecting JVM PermGen support... PermGen switch is supported. Setting to 256m If you encounter issues starting or stopping JIRA, please see the Troubleshooting guide at http://confluence.atlassian.com/display/JIRA/Installation+Troubleshooting+Guide Server startup logs are located in /var/local/atlassian/jira/logs/catalina.out Using CATALINA_BASE: /var/local/atlassian/jira Using CATALINA_HOME: /var/local/atlassian/jira Using CATALINA_TMPDIR: /var/local/atlassian/jira/temp Using JRE_HOME: /usr Using CLASSPATH: /var/local/atlassian/jira/bin/bootstrap.jar Using CATALINA_PID: /var/local/atlassian/jira/work/catalina.pid at java.net.Socket.<init>(Socket.java:249) at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:79) at org.apache.commons.httpclient.protocol.ControllerThreadSocketFactory$1.doit(ControllerThreadSocketFactory.java:90) at org.apache.commons.httpclient.protocol.ControllerThreadSocketFactory$SocketTask.run(ControllerThreadSocketFactory.java:157) ... 1 more 2014-03-18 11:03:04,275 StreamsCompletionService::thread-3 WARN anonymous com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor [atlassian.streams.internal.ActivityProviderConnectionMonitorImpl$ActivityMonitorJob] Could not reach provider FishEye 0 (http://fisheye/); it will be omitted from the stream. The connection will be retried in 5 minutes 2014-03-18 11:04:04,282 QuartzWorker-0 ERROR ServiceRunner com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job [sal.jira.scheduling.JiraPluginSchedulerService] Unable to load a service descriptor for the job 'com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job'. This is usually the result of an obsolete service that can removed in the Administration section. 2014-03-18 11:06:04,284 QuartzWorker-1 ERROR ServiceRunner com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job [sal.jira.scheduling.JiraPluginSchedulerService] Unable to load a service descriptor for the job 'com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job'. This is usually the result of an obsolete service that can removed in the Administration section. 2014-03-18 11:06:27,779 main INFO [atlassian.jira.startup.DefaultJiraLauncher] Stopping launchers 2014-03-18 11:06:27,786 main INFO [atlassian.plugin.manager.DefaultPluginManager] Shutting down the plugin system 2014-03-18 11:06:47,118 main INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /var/local/atlassian/jira-home/dbconfig.xml 2014-03-18 11:06:47,369 main INFO [atlassian.jira.startup.JiraStartupLogger] **************** JIRA starting... **************** 2014-03-18 11:06:47,399 main INFO [atlassian.jira.startup.JiraStartupLogger] ___ Environment _____________________________ JIRA Build : 5.0#713-sha1:aec58e27a0d402341b1f1be2fc8c0204a0b070f6 Build Date : Wed Feb 15 00:00:00 PST 2012 JIRA Installation Type : Standalone Application Server : Apache Tomcat/6.0.32 - Servlet API 2.5 Java Version : 1.6.0_45 - Sun Microsystems Inc. Current Working Directory : /var/local/atlassian Maximum Allowable Memory : 682MB Total Memory : 245MB Free Memory : 239MB Used Memory : 6MB Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 1069440(1044K) committed = 2555904(2496K) max = 134217728(131072K) Memory Pool: PS Eden Space : PS Eden Space: init = 67174400(65600K) used = 2688384(2625K) committed = 67174400(65600K) max = 246153216(240384K) Memory Pool: PS Survivor Space : PS Survivor Space: init = 11141120(10880K) used = 3705808(3618K) committed = 11141120(10880K) max = 11141120(10880K) Memory Pool: PS Old Gen : PS Old Gen: init = 178978816(174784K) used = 0(0K) committed = 178978816(174784K) max = 536870912(524288K) Memory Pool: PS Perm Gen : PS Perm Gen: init = 21757952(21248K) used = 16880296(16484K) committed = 21757952(21248K) max = 268435456(262144K) JVM Input Arguments : -Djava.util.logging.config.file=/var/local/atlassian/jira/conf/logging.properties -XX:MaxPermSize=256m -Xms256m -Xmx768m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Datlassian.plugins.enable.wait=300 -Djira.jelly.on=true -XX:+PrintGCDateStamps -XX:ReservedCodeCacheSize=128m -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=/var/local/atlassian/jira/endorsed -Dcatalina.base=/var/local/atlassian/jira -Dcatalina.home=/var/local/atlassian/jira -Djava.io.tmpdir=/var/local/atlassian/jira/temp ___ Java System Properties _________________ atlassian.plugins.enable.wait : 300 atlassian.standalone : JIRA catalina.base : /var/local/atlassian/jira catalina.home : /var/local/atlassian/jira catalina.useNaming : true common.loader : ${catalina.base}/lib, ${catalina.base}/lib/*.jar, ${catalina.home}/lib, ${catalina.home}/lib/*.jar file.encoding : UTF-8 file.encoding.pkg : sun.io java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment java.awt.headless : true java.awt.printerjob : sun.print.PSPrinterJob java.class.version : 50.0 java.home : /usr/java/jdk1.6.0_45/jre java.io.tmpdir : /var/local/atlassian/jira/temp java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory java.naming.factory.url.pkgs : org.apache.naming java.runtime.name : Java(TM) SE Runtime Environment java.runtime.version : 1.6.0_45-b06 java.specification.name : Java Platform API Specification java.specification.vendor : Sun Microsystems Inc. java.specification.version : 1.6 java.util.logging.config.file : /var/local/atlassian/jira/conf/logging.properties java.util.logging.manager : org.apache.juli.ClassLoaderLogManager java.vendor : Sun Microsystems Inc. java.vendor.url : http://java.sun.com/ java.vendor.url.bug : http://java.sun.com/cgi-bin/bugreport.cgi java.version : 1.6.0_45 java.vm.info : mixed mode java.vm.name : Java HotSpot(TM) 64-Bit Server VM java.vm.specification.name : Java Virtual Machine Specification java.vm.specification.vendor : Sun Microsystems Inc. java.vm.specification.version : 1.0 java.vm.vendor : Sun Microsystems Inc. java.vm.version : 20.45-b01 jira.jelly.on : true mail.mime.decodeparameters : true org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true os.arch : amd64 os.name : Linux os.version : 2.6.32-358.14.1.el6.x86_64 package.access : sun., org.apache.catalina., org.apache.coyote., org.apache.tomcat., org.apache.jasper., sun.beans. package.definition : sun., java., org.apache.catalina., org.apache.coyote., org.apache.tomcat., org.apache.jasper. server.loader : shared.loader : sun.arch.data.model : 64 sun.boot.library.path : /usr/java/jdk1.6.0_45/jre/lib/amd64 sun.cpu.endian : little sun.cpu.isalist : sun.io.unicode.encoding : UnicodeLittle sun.java.command : org.apache.catalina.startup.Bootstrap start sun.java.launcher : SUN_STANDARD sun.jnu.encoding : UTF-8 sun.management.compiler : HotSpot 64-Bit Tiered Compilers sun.os.patch.level : unknown tomcat.util.buf.StringCache.byte.enabled : true user.country : US user.dir : /var/local/atlassian user.home : /root user.language : en user.name : root user.timezone : US/Pacific-New 2014-03-18 11:06:47,400 main INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks. 2014-03-18 11:06:47,440 main INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory '/var/local/atlassian/jira-home' is validated and locked for exclusive use by this instance. 2014-03-18 11:06:47,441 main INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully. 2014-03-18 11:06:47,615 main INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /var/local/atlassian/jira-home/dbconfig.xml 2014-03-18 11:06:47,697 main INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher 2014-03-18 11:06:50,121 main INFO [atlassian.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully. 2014-03-18 11:06:50,123 main INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Post database-configuration launchers 2014-03-18 11:06:51,108 main INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from /var/local/atlassian/jira-home/dbconfig.xml 2014-03-18 11:06:52,238 main INFO [atlassian.jira.startup.DatabaseLauncher] Database transactions enabled: true 2014-03-18 11:06:52,245 main INFO [atlassian.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2 2014-03-18 11:06:52,247 main INFO [atlassian.jira.startup.JiraStartupLogger] Database configuration OK ___ Database Configuration _________________ Loading entityengine.xml from : file:/var/local/atlassian/jira/atlassian-jira/WEB-INF/classes/entityengine.xml Entity model field type name : mssql Entity model schema name : dbo Database Version : Microsoft SQL Server - 10.50.4276 Database Driver : jTDS Type 4 JDBC Driver for MS SQL Server and Sybase - 1.2.5 Database URL : jdbc:jtds:sqlserver://krkdevatldb2:1433/JIRADB_RogerW Database JDBC config : mssql jdbc:jtds:sqlserver://krkdevatldb2:1433/JIRADB_RogerW 2014-03-18 11:06:53,109 main INFO [atlassian.jira.startup.JiraStartupLogger] ___ Starting the JIRA Plugin System _________________ 2014-03-18 11:06:53,110 main INFO [atlassian.plugin.manager.DefaultPluginManager] Initialising the plugin system 2014-03-18 11:07:05,017 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/activeobjects-jira-spi-0.19.7.jar (1329355350000) created 2014-03-18 11:07:05,061 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/activeobjects-plugin-0.19.7.jar (1329355348000) created 2014-03-18 11:07:05,128 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/applinks-plugin-3.6.4.jar (1329355326000) created 2014-03-18 11:07:05,133 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-feedback-plugin-1.1.3.jar (1329355348000) created 2014-03-18 11:07:05,151 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-gadgets-dashboard-plugin-3.1.21.jar (1329355350000) created 2014-03-18 11:07:05,160 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-gadgets-directory-plugin-3.1.21.jar (1329355350000) created 2014-03-18 11:07:05,168 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-gadgets-embedded-plugin-3.1.21.jar (1329355350000) created 2014-03-18 11:07:05,174 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-gadgets-oauth-service-provider-plugin-3.1.21.jar (1329355350000) created 2014-03-18 11:07:05,194 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-gadgets-opensocial-plugin-3.1.21.jar (1329355350000) created 2014-03-18 11:07:05,222 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-gadgets-publisher-plugin-3.1.21.jar (1329355350000) created 2014-03-18 11:07:05,322 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-jira-rpc-plugin-5.0.5.jar (1329355350000) created 2014-03-18 11:07:05,354 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-oauth-admin-plugin-1.3.10.jar (1329355350000) created 2014-03-18 11:07:05,359 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-oauth-consumer-plugin-1.3.10.jar (1329355350000) created 2014-03-18 11:07:05,376 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-oauth-consumer-spi-1.3.10.jar (1329355140000) created 2014-03-18 11:07:05,411 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-oauth-service-provider-plugin-1.3.10.jar (1329355350000) created 2014-03-18 11:07:05,415 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-oauth-service-provider-spi-1.3.10.jar (1329355132000) created 2014-03-18 11:07:05,446 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-rest-module-2.5.5.jar (1329355348000) created 2014-03-18 11:07:05,454 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-template-renderer-api-1.3.1.jar (1329355170000) created 2014-03-18 11:07:05,494 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-template-renderer-velocity16-plugin-1.3.1.jar (1329355348000) created 2014-03-18 11:07:05,548 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/atlassian-universal-plugin-manager-plugin-1.5.3.jar (1329355348000) created 2014-03-18 11:07:05,605 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/auiplugin-3.5.5.jar (1329355348000) created 2014-03-18 11:07:05,624 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/com.springsource.com.sun.syndication-0.9.0.jar (1329355348000) created 2014-03-18 11:07:05,635 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/com.springsource.org.jdom-1.0.0.jar (1329355348000) created 2014-03-18 11:07:05,650 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/crowd-rest-application-management-2.3.6.jar (1329355210000) created 2014-03-18 11:07:05,664 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/crowd-rest-plugin-2.3.6.jar (1329355210000) created 2014-03-18 11:07:05,675 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/embedded-crowd-admin-plugin-1.3.7.jar (1329355350000) created 2014-03-18 11:07:05,685 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/httpclient-osgi-4.0.jar (1329355350000) created 2014-03-18 11:07:05,692 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/httpcore-osgi-4.0.jar (1329355350000) created 2014-03-18 11:07:05,710 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/icu4j-3.8-1.jar (1329355350000) created 2014-03-18 11:07:05,715 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-admin-quicknav-plugin-5.0.jar (1329356124000) created 2014-03-18 11:07:05,772 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-admin-summary-plugin-5.0.jar (1329356120000) created 2014-03-18 11:07:05,785 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-application-properties-plugin-5.0.jar (1329356118000) created 2014-03-18 11:07:05,808 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-bamboo-plugin-5.0.jar (1329355350000) created 2014-03-18 11:07:05,901 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-fisheye-plugin-5.0.0.jar (1329355350000) created 2014-03-18 11:07:05,925 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-gadgets-plugin-5.0.jar (1329356106000) created 2014-03-18 11:07:05,930 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-ical-feed-1.0.2.jar (1329355348000) created 2014-03-18 11:07:05,966 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-importers-plugin-4.0.jar (1329355350000) created 2014-03-18 11:07:05,971 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-issue-link-applinks-common-plugin-5.0.jar (1329356198000) created 2014-03-18 11:07:06,011 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-issue-link-confluence-plugin-5.0.jar (1329356206000) created 2014-03-18 11:07:06,032 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-issue-link-remote-jira-plugin-5.0.jar (1329356202000) created 2014-03-18 11:07:06,049 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-issue-link-web-plugin-5.0.jar (1329356202000) created 2014-03-18 11:07:06,055 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-json-rpc-plugin-1.0.4.jar (1329355348000) created 2014-03-18 11:07:06,085 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-language-pack-de_DE-5.0.0-rc2-v2r3852-2012-01-06.jar (1329355350000) created 2014-03-18 11:07:06,090 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-language-pack-es_ES-5.0.0-rc2-v2r6467-2011-12-29.jar (1329355350000) created 2014-03-18 11:07:06,095 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-language-pack-fr_FR-5.0.0-rc2-v2r1553-2012-01-05.jar (1329355348000) created 2014-03-18 11:07:06,101 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-language-pack-ja_JP-5.0.0-rc2-v2r10187-2012-01-05.jar (1329355348000) created 2014-03-18 11:07:06,105 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-languages-5.0-en_UK.jar (1329355650000) created 2014-03-18 11:07:06,109 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-languages-5.0-en_US.jar (1329355650000) created 2014-03-18 11:07:06,119 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-lookandfeel-plugin-5.0.jar (1329356126000) created 2014-03-18 11:07:06,138 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-mail-plugin-5.0.jar (1329356194000) created 2014-03-18 11:07:06,142 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-oauth-consumer-spi-plugin-5.0.jar (1329356068000) created 2014-03-18 11:07:06,145 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-oauth-service-provider-spi-plugin-5.0.jar (1329356062000) created 2014-03-18 11:07:06,196 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-project-config-plugin-5.0.jar (1329356116000) created 2014-03-18 11:07:06,208 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-quick-edit-plugin-1.0.29.jar (1329355350000) created 2014-03-18 11:07:06,214 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-rest-plugin-5.0.jar (1329356090000) created 2014-03-18 11:07:06,222 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-sal-plugin-5.0.jar (1329356110000) created 2014-03-18 11:07:06,230 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-share-plugin-5.0.jar (1329356196000) created 2014-03-18 11:07:06,235 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-soy-plugin-5.0.jar (1329356120000) created 2014-03-18 11:07:06,260 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-view-issue-plugin-5.0.jar (1329356122000) created 2014-03-18 11:07:06,269 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/jira-whatsnew-plugin-1.1.0.1.jar (1329355348000) created 2014-03-18 11:07:06,273 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/json-20070829-1.jar (1329355348000) created 2014-03-18 11:07:06,277 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/nekohtml-1.9.12-1.jar (1329355350000) created 2014-03-18 11:07:06,287 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/rome-1.0.jar (1329355348000) created 2014-03-18 11:07:06,293 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/soy-template-plugin-1.0.0-m3.jar (1329355196000) created 2014-03-18 11:07:06,304 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/stp-2.9.5.jar (1329355348000) created 2014-03-18 11:07:06,443 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-aggregator-plugin-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,448 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-api-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,453 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-core-plugin-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,458 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-inline-actions-plugin-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,462 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-jira-inline-actions-plugin-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,641 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-jira-plugin-5.1.0.jar (1329355348000) created 2014-03-18 11:07:06,653 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-spi-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,661 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/streams-thirdparty-plugin-5.1.0.jar (1329355350000) created 2014-03-18 11:07:06,672 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/.bundled-plugins/workflow-designer-plugin-2.5.2.jar (1329355348000) created 2014-03-18 11:07:13,895 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-jira-plugin, com.atlassian.sal.jira, com.atlassian.jira.jira-project-config-plugin, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.jira.extra.jira-ical-feed, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.streams, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.gadgets.directory, com.atlassian.gadgets.dashboard, com.atlassian.support.stp, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.gadgets, crowd-rest-application-management, com.atlassian.soy.soy-template-plugin, com.atlassian.streams.core, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.gadgets.publisher, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.opensocial, com.atlassian.oauth.serviceprovider, com.atlassian.applinks.applinks-plugin, com.atlassian.gadgets.embedded, com.atlassian.streams.actions, crowd-rest-plugin, com.atlassian.jira.rest], 300 seconds remaining 2014-03-18 11:07:14,900 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.streams, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.gadgets.directory, com.atlassian.gadgets.dashboard, com.atlassian.support.stp, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.gadgets, com.atlassian.soy.soy-template-plugin, com.atlassian.streams.core, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.opensocial, com.atlassian.oauth.serviceprovider, com.atlassian.applinks.applinks-plugin, com.atlassian.gadgets.embedded, com.atlassian.streams.actions, com.atlassian.jira.rest], 298 seconds remaining 2014-03-18 11:07:15,900 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-project-config-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.streams, com.atlassian.oauth.admin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.gadgets.directory, com.atlassian.gadgets.dashboard, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.gadgets, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.gadgets.opensocial, com.atlassian.oauth.serviceprovider, com.atlassian.applinks.applinks-plugin, com.atlassian.gadgets.embedded, com.atlassian.streams.actions, com.atlassian.jira.rest], 297 seconds remaining 2014-03-18 11:07:16,901 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-jira-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.streams, com.atlassian.gadgets.directory, com.atlassian.gadgets.dashboard, com.atlassian.jira.gadgets, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.embedded, com.atlassian.streams.actions], 296 seconds remaining 2014-03-18 11:07:17,908 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-jira-plugin, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.streams, com.atlassian.gadgets.directory, com.atlassian.gadgets.dashboard, com.atlassian.jira.gadgets, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.streams.actions], 295 seconds remaining 2014-03-18 11:07:18,908 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.jira.plugins.jira-importers-plugin], 294 seconds remaining 2014-03-18 11:07:21,028 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/installed-plugins/plugin_5906681460021137957_groovyrunner-2.1.17.jar (1395157810000) created 2014-03-18 11:07:21,035 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/installed-plugins/plugindev-4931646583654405199jira-marketleader-customermailer-admin-1.0.2.jar (1372880709000) created 2014-03-18 11:07:21,039 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: /var/local/atlassian/jira-home/plugins/installed-plugins/plugindev-8029732847330587585jira-marketleader-customermailer-listener-1.0.2.jar (1372880490000) created 2014-03-18 11:07:21,331 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.marketleader.jira.jira-marketleader-customermailer-listener, com.onresolve.jira.groovy.groovyrunner], 300 seconds remaining 2014-03-18 11:07:22,058 Spring executor 8 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.onresolve.jira.groovy.groovyrunner org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'scriptManager' defined in URL [bundle://86.0:0/META-INF/spring/atlassian-plugins-components.xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: com/atlassian/jira/web/action/JiraWebActionSupport$MessageType at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409) at java.security.AccessController.doPrivileged(Native Method) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355) at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918) at java.lang.Thread.run(Thread.java:662) Caused by: java.lang.NoClassDefFoundError: com/atlassian/jira/web/action/JiraWebActionSupport$MessageType at java.lang.Class.getDeclaredMethods0(Native Method) at java.lang.Class.privateGetDeclaredMethods(Class.java:2436) at java.lang.Class.getDeclaredMethods(Class.java:1793) at org.codehaus.groovy.reflection.CachedClass$3$1.run(CachedClass.java:84) at java.security.AccessController.doPrivileged(Native Method) at org.codehaus.groovy.reflection.CachedClass$3.initValue(CachedClass.java:81) at org.codehaus.groovy.reflection.CachedClass$3.initValue(CachedClass.java:79) at org.codehaus.groovy.util.LazyReference.getLocked(LazyReference.java:46) at org.codehaus.groovy.util.LazyReference.get(LazyReference.java:33) at org.codehaus.groovy.reflection.CachedClass.getMethods(CachedClass.java:250) at groovy.lang.MetaClassImpl.populateMethods(MetaClassImpl.java:341) at groovy.lang.MetaClassImpl.fillMethodIndex(MetaClassImpl.java:291) at groovy.lang.MetaClassImpl.initialize(MetaClassImpl.java:2900) at org.codehaus.groovy.reflection.ClassInfo.getMetaClassUnderLock(ClassInfo.java:166) at org.codehaus.groovy.reflection.ClassInfo.getMetaClass(ClassInfo.java:182) at org.codehaus.groovy.runtime.metaclass.MetaClassRegistryImpl.getMetaClass(MetaClassRegistryImpl.java:227) at org.codehaus.groovy.runtime.InvokerHelper.getMetaClass(InvokerHelper.java:751) at org.codehaus.groovy.runtime.callsite.CallSiteArray.createCallStaticSite(CallSiteArray.java:59) at org.codehaus.groovy.runtime.callsite.CallSiteArray.createCallSite(CallSiteArray.java:146) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112) at com.onresolve.jira.groovy.ScriptManagerImpl.afterPropertiesSet(ScriptManagerImpl.groovy:452) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1369) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335) ... 19 more Caused by: java.lang.ClassNotFoundException: com.atlassian.jira.web.action.JiraWebActionSupport$MessageType at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526) at org.apache.felix.framework.ExtensionManager$ExtensionManagerModule.getClassByDelegation(ExtensionManager.java:672) at org.apache.felix.framework.resolver.WireImpl.getClass(WireImpl.java:99) at org.apache.felix.framework.ModuleImpl.searchImports(ModuleImpl.java:1345) at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:711) at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73) at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) ... 44 more 2014-03-18 11:07:22,073 Spring executor 8 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.onresolve.jira.groovy.groovyrunner, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'scriptManager' defined in URL [bundle://86.0:0/META-INF/spring/atlassian-plugins-components.xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: com/atlassian/jira/web/action/JiraWebActionSupport$MessageType at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409) at java.security.AccessController.doPrivileged(Native Method) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355) at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918) at java.lang.Thread.run(Thread.java:662) Caused by: java.lang.NoClassDefFoundError: com/atlassian/jira/web/action/JiraWebActionSupport$MessageType at java.lang.Class.getDeclaredMethods0(Native Method) at java.lang.Class.privateGetDeclaredMethods(Class.java:2436) at java.lang.Class.getDeclaredMethods(Class.java:1793) at org.codehaus.groovy.reflection.CachedClass$3$1.run(CachedClass.java:84) at java.security.AccessController.doPrivileged(Native Method) at org.codehaus.groovy.reflection.CachedClass$3.initValue(CachedClass.java:81) at org.codehaus.groovy.reflection.CachedClass$3.initValue(CachedClass.java:79) at org.codehaus.groovy.util.LazyReference.getLocked(LazyReference.java:46) at org.codehaus.groovy.util.LazyReference.get(LazyReference.java:33) at org.codehaus.groovy.reflection.CachedClass.getMethods(CachedClass.java:250) at groovy.lang.MetaClassImpl.populateMethods(MetaClassImpl.java:341) at groovy.lang.MetaClassImpl.fillMethodIndex(MetaClassImpl.java:291) at groovy.lang.MetaClassImpl.initialize(MetaClassImpl.java:2900) at org.codehaus.groovy.reflection.ClassInfo.getMetaClassUnderLock(ClassInfo.java:166) at org.codehaus.groovy.reflection.ClassInfo.getMetaClass(ClassInfo.java:182) at org.codehaus.groovy.runtime.metaclass.MetaClassRegistryImpl.getMetaClass(MetaClassRegistryImpl.java:227) at org.codehaus.groovy.runtime.InvokerHelper.getMetaClass(InvokerHelper.java:751) at org.codehaus.groovy.runtime.callsite.CallSiteArray.createCallStaticSite(CallSiteArray.java:59) at org.codehaus.groovy.runtime.callsite.CallSiteArray.createCallSite(CallSiteArray.java:146) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112) at com.onresolve.jira.groovy.ScriptManagerImpl.afterPropertiesSet(ScriptManagerImpl.groovy:452) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1369) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335) ... 19 more Caused by: java.lang.ClassNotFoundException: com.atlassian.jira.web.action.JiraWebActionSupport$MessageType at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526) at org.apache.felix.framework.ExtensionManager$ExtensionManagerModule.getClassByDelegation(ExtensionManager.java:672) at org.apache.felix.framework.resolver.WireImpl.getClass(WireImpl.java:99) at org.apache.felix.framework.ModuleImpl.searchImports(ModuleImpl.java:1345) at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:711) at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73) at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) ... 44 more 2014-03-18 11:07:23,422 main INFO [atlassian.plugin.manager.DefaultPluginManager] Plugin system started in 0:00:30.309 2014-03-18 11:07:23,432 main INFO [atlassian.jira.startup.JiraStartupLogger] ___ Plugin System Started _________________ 2014-03-18 11:07:24,778 main ERROR [atlassian.jira.service.OfBizServiceConfigStore] Unable to create a service config for service with the name : Git Revision Indexing Service com.atlassian.jira.service.OfBizServiceConfigStore$ClassNotFoundServiceException: Could not find class: com.xiplink.jira.git.revisions.RevisionIndexService at com.atlassian.jira.service.OfBizServiceConfigStore.instantiateServiceContainer(OfBizServiceConfigStore.java:217) at com.atlassian.jira.service.OfBizServiceConfigStore.getServiceContainer(OfBizServiceConfigStore.java:179) at com.atlassian.jira.service.OfBizServiceConfigStore.getAllServiceConfigs(OfBizServiceConfigStore.java:159) at com.atlassian.jira.service.DefaultServiceManager.loadServices(DefaultServiceManager.java:316) at com.atlassian.jira.service.DefaultServiceManager.ensureServicesLoaded(DefaultServiceManager.java:306) at com.atlassian.jira.service.DefaultServiceManager.getServices(DefaultServiceManager.java:81) at com.atlassian.jira.upgrade.ConsistencyCheckImpl.getServices(ConsistencyCheckImpl.java:170) at com.atlassian.jira.upgrade.ConsistencyCheckImpl.ensureSingleService(ConsistencyCheckImpl.java:524) at com.atlassian.jira.upgrade.ConsistencyCheckImpl.checkMailListenerAndService(ConsistencyCheckImpl.java:385) at com.atlassian.jira.upgrade.ConsistencyCheckImpl.checkDataConsistency(ConsistencyCheckImpl.java:224) at com.atlassian.jira.upgrade.ConsistencyCheckImpl.checkConsistency(ConsistencyCheckImpl.java:213) at com.atlassian.jira.upgrade.ConsistencyCheckImpl.initialise(ConsistencyCheckImpl.java:177) at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:102) at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:250) at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:149) at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:94) at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:24) at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:61) at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33) at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:56) at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:67) at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:62) at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121) at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165) at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134) at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203) at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:95) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205) at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053) at org.apache.catalina.core.StandardHost.start(StandardHost.java:840) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053) at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463) at org.apache.catalina.core.StandardService.start(StandardService.java:525) at org.apache.catalina.core.StandardServer.start(StandardServer.java:754) at org.apache.catalina.startup.Catalina.start(Catalina.java:595) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414) Caused by: java.lang.ClassNotFoundException: Class 'com.xiplink.jira.git.revisions.RevisionIndexService' not found. at com.atlassian.jira.plugin.DefaultComponentClassManager.constructEvenIfNotEnabled(DefaultComponentClassManager.java:151) at com.atlassian.jira.plugin.DefaultComponentClassManager.newInstance(DefaultComponentClassManager.java:70) at com.atlassian.jira.service.OfBizServiceConfigStore.loadServiceClass(OfBizServiceConfigStore.java:351) at com.atlassian.jira.service.OfBizServiceConfigStore.instantiateServiceContainer(OfBizServiceConfigStore.java:212) ... 44 more 2014-03-18 11:07:24,779 main ERROR [atlassian.jira.service.OfBizServiceConfigStore] The class 'com.xiplink.jira.git.revisions.RevisionIndexService' could not be found. This can happen when a plugin is uninstalled or disabled 2014-03-18 11:07:24,779 main ERROR [atlassian.jira.service.OfBizServiceConfigStore] A NoOp Service has been returned and hence 'Git Revision Indexing Service' will not do anything until fixed. 2014-03-18 11:07:24,813 main INFO [atlassian.jira.upgrade.ConsistencyCheckImpl] The Server ID for this JIRA instance is: [AQ0A-GS8Y-3ZGR-VH7E] 2014-03-18 11:07:25,532 main INFO [atlassian.jira.startup.JiraStartupLogger] ___ User Directories (Ordered) ______________ INTERNAL : JIRA Internal Directory Implementing Class : com.atlassian.crowd.directory.InternalDirectory Allowed Operations : CREATE_GROUP, CREATE_ROLE, CREATE_USER, DELETE_GROUP, DELETE_ROLE, DELETE_USER, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_ROLE, UPDATE_ROLE_ATTRIBUTE, UPDATE_USER, UPDATE_USER_ATTRIBUTE Encryption Type : atlassian-security Active : true Attributes : user_encryption_method : atlassian-security DELEGATING : JIRA Delegated Authentication Directory Implementing Class : com.atlassian.crowd.directory.DelegatedAuthenticationDirectory Allowed Operations : CREATE_GROUP, CREATE_ROLE, CREATE_USER, DELETE_GROUP, DELETE_ROLE, DELETE_USER, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_ROLE, UPDATE_ROLE_ATTRIBUTE, UPDATE_USER, UPDATE_USER_ATTRIBUTE Encryption Type : Active : false Attributes : crowd.delegated.directory.auto.create.user : false crowd.delegated.directory.type : com.atlassian.crowd.directory.GenericLDAP ldap.basedn : DC=sky,DC=dom ldap.password : xxxxxx ldap.url : ldap://krk-corpdc01:389 ldap.user.username : sAMAccountName ldap.userdn : CN=JiraADAuth,OU=Accounts,OU=Production Backoffice,OU=Resources,DC=Sky,DC=dom CONNECTOR : ML-LDAP-Kirkland Implementing Class : com.atlassian.crowd.directory.MicrosoftActiveDirectory Allowed Operations : CREATE_GROUP, DELETE_GROUP, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_USER_ATTRIBUTE Encryption Type : sha Active : false Attributes : autoAddGroups : com.atlassian.crowd.directory.sync.currentstartsynctime : com.atlassian.crowd.directory.sync.lastdurationms : 22823 com.atlassian.crowd.directory.sync.laststartsynctime : 1395091000640 crowd.sync.incremental.enabled : false directory.cache.synchronise.interval : 31536000 ldap.basedn : ou=Kirkland,dc=sky,dc=dom ldap.connection.timeout : 30000 ldap.group.description : cn ldap.group.dn : ou=Groups,ou=Technology ldap.group.filter : (objectClass=group) ldap.group.name : cn ldap.group.objectclass : group ldap.group.usernames : member ldap.local.groups : true ldap.nestedgroups.disabled : false ldap.pagedresults : true ldap.pagedresults.size : 1000 ldap.password : xxxxxx ldap.pool.initsize : ldap.pool.maxsize : ldap.pool.prefsize : ldap.pool.timeout : 0 ldap.propogate.changes : false ldap.read.timeout : 60000 ldap.referral : true ldap.relaxed.dn.standardisation : false ldap.roles.disabled : true ldap.search.timelimit : 0 ldap.secure : false ldap.url : ldap://krk-corpdc01.sky.dom:389 ldap.user.displayname : displayName ldap.user.dn : ldap.user.email : mail ldap.user.encryption : sha ldap.user.filter : (&(objectClass=user)(sAMAccountName=*)) ldap.user.firstname : givenName ldap.user.group : memberOf ldap.user.lastname : sn ldap.user.objectclass : user ldap.user.password : xxxxxx ldap.user.username : sAMAccountName ldap.user.username.rdn : sAMAccountName ldap.userdn : CN=TechWiki,OU=service accounts,DC=sky,DC=dom ldap.usermembership.use : false ldap.usermembership.use.for.groups : false CONNECTOR : ML-LDAP-Denver Implementing Class : com.atlassian.crowd.directory.MicrosoftActiveDirectory Allowed Operations : CREATE_GROUP, DELETE_GROUP, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_USER_ATTRIBUTE Encryption Type : sha Active : false Attributes : autoAddGroups : com.atlassian.crowd.directory.sync.currentstartsynctime : com.atlassian.crowd.directory.sync.lastdurationms : 3173 com.atlassian.crowd.directory.sync.laststartsynctime : 1395091000640 crowd.sync.incremental.enabled : false directory.cache.synchronise.interval : 31536000 ldap.basedn : dc=sky,dc=dom ldap.connection.timeout : 30000 ldap.group.description : cn ldap.group.dn : ou=Groups,ou=Technology,ou=Kirkland ldap.group.filter : (objectClass=group) ldap.group.name : cn ldap.group.objectclass : group ldap.group.usernames : member ldap.local.groups : true ldap.nestedgroups.disabled : false ldap.pagedresults : true ldap.pagedresults.size : 1000 ldap.password : xxxxxx ldap.pool.initsize : ldap.pool.maxsize : ldap.pool.prefsize : ldap.pool.timeout : 0 ldap.propogate.changes : false ldap.read.timeout : 60000 ldap.referral : true ldap.relaxed.dn.standardisation : false ldap.roles.disabled : true ldap.search.timelimit : 0 ldap.secure : false ldap.url : ldap://krk-corpdc01.sky.dom:389 ldap.user.displayname : displayName ldap.user.dn : ou=Denver ldap.user.email : mail ldap.user.encryption : sha ldap.user.filter : (&(objectClass=user)(sAMAccountName=*)) ldap.user.firstname : givenName ldap.user.group : memberOf ldap.user.lastname : sn ldap.user.objectclass : user ldap.user.password : xxxxxx ldap.user.username : sAMAccountName ldap.user.username.rdn : sAMAccountName ldap.userdn : CN=TechWiki,OU=service accounts,DC=sky,DC=dom ldap.usermembership.use : false ldap.usermembership.use.for.groups : false CROWD : Crowd BugtrackerCustomers Implementing Class : com.atlassian.crowd.directory.RemoteCrowdDirectory Allowed Operations : UPDATE_GROUP_ATTRIBUTE,UPDATE_USER_ATTRIBUTE Encryption Type : Active : true Attributes : application.name : bugtrackercustomers application.password : xxxxxx com.atlassian.crowd.directory.sync.currentstartsynctime : com.atlassian.crowd.directory.sync.issynchronising : false com.atlassian.crowd.directory.sync.lastdurationms : 1818 com.atlassian.crowd.directory.sync.laststartsynctime : 1395091015775 crowd.server.url : http://crowddev/crowd crowd.sync.incremental.enabled : false directory.cache.synchronise.interval : 86400 useNestedGroups : false ___ Core Application Properties ____________ Version : 5.0 Build # : 713 Build Date : Wed Feb 15 00:00:00 PST 2012 Installation Type : Standalone Server ID : AQ0A-GS8Y-3ZGR-VH7E Base URL : http://bugtrackerdev Default Language : English (United States) External User Management : OFF ___ Application Properties _________________ ARCHIVED_COLLECTORS : #java.util.Map ebaf746e�10315 b8d79dd5�10315 1d37e7b2�10315 COLLECTOR_IDS.10315 : #java.util.List com.atlassian.activeobjects.admin.ActiveObjectsPluginToTablesMapping : null com.atlassian.jira.ext.charting:build : 1500 com.atlassian.jira.jira-mail-plugin:build : 1 com.atlassian.jira.lookandfeel.customizeColors : false com.atlassian.jira.lookandfeel.logoChoice : UPLOAD com.atlassian.jira.lookandfeel:build : 1 com.atlassian.jira.lookandfeel:customDefaultFaviconHiresURL : /images/64jira.png com.atlassian.jira.lookandfeel:customDefaultFaviconURL : /favicon.ico com.atlassian.jira.lookandfeel:faviconHeight : 64 com.atlassian.jira.lookandfeel:faviconWidth : 64 com.atlassian.jira.lookandfeel:isDefaultFavicon : false com.atlassian.jira.lookandfeel:usingCustomFavicon : false com.atlassian.jira.lookandfeel:usingCustomLogo : true com.atlassian.jira.plugin.ext.bamboo:build : 1 com.atlassian.jira.plugin.labels:build : 2300 com.atlassian.jira.plugins.jira-importers-plugin:build : 1 com.atlassian.sal.jira:build : 2 com.atlassian.upm.atlassian-universal-plugin-manager-plugin:build : 1 com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseR8bdca18bb1b7389d0a2d834a01247d76 : null com.atlassian.upm.license.internal.impl.PluginSettingsPluginLicenseRfdbfad06c2f1036a60cb955d7e285d69 : #java.util.List com.pyxis.greenhopper.jira com.atlassian.upm.log.PluginSettingsAuditLogService:log:upm_audit_log : null com.atlassian.upm.log.PluginSettingsAuditLogService:log:upm_audit_log_v2 : null com.atlassian.upm:notifications:dismissal-edition.mismatch:com.atlas4d3c0bfafee406f59dd4aac2dc5e85c7 : #java.util.List com.atlassian.upm:notifications:dismissal-edition.mismatch:com.redra618cfcf13830bba3b1939690baab5305 : #java.util.List com.atlassian.upm:notifications:dismissal-edition.mismatch:com.redraac25d8ab0da3b0966edf123408b4c40a : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.expired:com.atl6d92c115ab49814c611187ff8c870f4c : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.expired:com.red05fb87fa0422296812b40d2a1260b850 : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.expired:com.red456a088d4e482069d4eea3cd5ba0738c : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired:c2079ffcb6c96e93e4eb60bf9cdbab629 : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired:c4485c9b91976e9b33b1dbe36cd96827f : #java.util.List com.atlassian.upm:notifications:dismissal-evaluation.nearlyexpired:ce46a7633c8a683e7892e070853f1f827 : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.expired : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.expired:com.atd2e004da5cbedcef43f249e5ec10afb1 : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.expired:com.re3d2da9b2cda222a8d777cd7879815dd0 : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.expired:com.re611ac2f025aaa78b1e002e47da2fc2c2 : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired:57542aaf659e08d97e2b941eb4599d8b : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired:5c38f7657e5dce6f695670b53307a704 : #java.util.List com.atlassian.upm:notifications:dismissal-maintenance.nearlyexpired:a16f8cd13b61e45b10f1a453cad20047 : #java.util.List com.atlassian.upm:notifications:dismissal-update : #java.util.List com.atlassian.upm:notifications:dismissal-update:com.atlassian.jira.117175fa5842144871c2082b14a3d704 : #java.util.List com.atlassian.upm:notifications:dismissal-update:com.redradishtech.j00fe6ed5f9860d0bfa15c7ba0e4257f3 : #java.util.List com.atlassian.upm:notifications:dismissal-update:com.redradishtech.jcb785f3db8214dac81e64b0771e94044 : #java.util.List com.atlassian.upm:notifications:notification-edition.mismatch : #java.util.List com.atlassian.upm:notifications:notification-evaluation.expired : #java.util.List com.atlassian.upm:notifications:notification-evaluation.nearlyexpired : #java.util.List com.atlassian.upm:notifications:notification-maintenance.expired : #java.util.List com.pyxis.greenhopper.jira com.atlassian.upm:notifications:notification-maintenance.nearlyexpired : #java.util.List com.atlassian.upm:notifications:notification-update : #java.util.List com.pyxis.greenhopper.jira com.plugenta.jiraauditor com.atlassian.jira.plugin.ext.bamboo com.atlassian.jirafisheyeplugin com.innovalog.jmcf.jira-misc-custom-fields net.bull.javamelody com.atlassian.jira.extra.jira-ical-feed com.atlassian.upm:plugin-upgrades: : 0 com.marketleader.jira.customermailer.crowdpassword : Pinpoint123 com.marketleader.jira.customermailer.crowdtimeout : com.marketleader.jira.customermailer.crowdurl : http://crowddev/crowd com.marketleader.jira.customermailer.crowdusername : jira-customermailer com.marketleader.jira.customermailer.events : 10000,10001,10002,10003,10004,10005 com.marketleader.jira.customermailer.goldmineIgnoredEvents : com.marketleader.jira.customermailer.goldmineProjects : CS com.marketleader.jira.customermailer.oneservepassword : Pinpoint123 com.marketleader.jira.customermailer.oneservetimeout : com.marketleader.jira.customermailer.oneserveurl : http://oneservedev/appserver.svc/rest/ com.marketleader.jira.customermailer.oneserveusername : hvdevtest3 com.marketleader.jira.customermailer.orderType : OrderType com.marketleader.jira.customermailer.profileId : ProfileId com.onresolve.jira.groovy.groovyrunner:groovyrunner : null com.plugenta.jiraauditor.param.startDate : null com.plugenta.jiraauditor.version.number : 1.1.1 com.pyxis.greenhopper.jira:build : 22 com.redradishtech.jira.marketleader.customermailer.crowdpassword : Pinpoint123 com.redradishtech.jira.marketleader.customermailer.crowdurl : http://crowdtest/crowd com.redradishtech.jira.marketleader.customermailer.crowdusername : jira-customermailer com.redradishtech.jira.marketleader.customermailer.events : com.redradishtech.jira.marketleader.customermailer.oneservepassword : Pinpoint123 com.redradishtech.jira.marketleader.customermailer.oneserveurl : http://oneservetest/ com.redradishtech.jira.marketleader.customermailer.oneserveusername : hvdevtest3 com.redradishtech.jira.marketleader.customermailer.profileId : ProfileId jira.ajax.autocomplete.issuepicker.enabled : true jira.ajax.autocomplete.labelsuggestion.limit : 20 jira.ajax.autocomplete.limit : 20 jira.alertheader.visibility : private jira.assignee.change.is.sent.to.both.parties : true jira.attachment.allow.zip.support : true jira.attachment.do.not.expand.as.zip.extensions.list : docx, docm, dotx, dotm, xlsx, xlsm, xltx, xltm, xlsb, xlam, pptx, pptm, potx, potm, ppam, ppsx, ppsm, sldx, sldm, thmx, odt, odp, ods, odg, odb, odf, ott, otp, ots, otg, odm, sxw, stw, sxc, stc, sxi, sti, sxd, std, sxg jira.attachment.download.mime.sniffing.workaround : workaround jira.attachment.number.of.zip.entries : 30 jira.autoexport : true jira.avatar.default.id : 10011 jira.avatar.megapixels : 10 jira.avatar.user.anonymous.id : 10193 jira.avatar.user.default.id : 10192 jira.baseurl : http://bugtrackerdev jira.browser.unsupported.warnings.disabled : false jira.bulk.edit.limit.issue.count : 1000 jira.chart.days.previous.limit.daily : 300 jira.chart.days.previous.limit.hourly : 10 jira.chart.days.previous.limit.monthly : 7500 jira.chart.days.previous.limit.quarterly : 22500 jira.chart.days.previous.limit.weekly : 1750 jira.chart.days.previous.limit.yearly : 36500 jira.clone.linktype.name : Cloners jira.clone.prefix : CLONE - jira.comment.level.visibility.groups : true jira.constant.default.priority : 4 jira.contact.administrators.message : null jira.dashboard.max.gadgets : 20 jira.databasequery.batch.size : 100 jira.date.picker.java.format : d/MMM/yy jira.date.picker.javascript.format : %e/%b/%y jira.date.time.picker.java.format : dd/MMM/yy h:mm a jira.date.time.picker.javascript.format : %e/%b/%y %I:%M %p jira.date.time.picker.use.iso8061 : false jira.db.txns.disabled : false jira.default.jndi.name : java:comp/env/jdbc/JiraDS jira.disable.login.gadget : false jira.disable.multipart.get.http.request : true jira.edition : enterprise jira.email.fromheader.format : ${fullname} (defects) jira.exportimport.cleanxml : true jira.home : jira.i18n.include.meta-data : true jira.i18n.language.index : english jira.index.batch.maxbuffereddocs : 300 jira.index.batch.maxmergedocs : 2147483647 jira.index.batch.mergefactor : 50 jira.index.interactive.maxbuffereddocs : 300 jira.index.interactive.maxmergedocs : 2147483647 jira.index.interactive.mergefactor : 4 jira.index.lock.waittime : 30000 jira.index.max.reindexes : 4000 jira.index.maxfieldlength : 10000 jira.index.update.bulk.optimization : 400 jira.issue.actions.order : asc jira.issue.operations.ajax.enabled : true jira.issueindex.fetch.size : 200 jira.jql.autocomplete.disabled : false jira.lf.application.id : jira jira.lf.date.complete : dd-MMM-yy hh:mm a jira.lf.date.day : EEEE h:mm a jira.lf.date.dmy : dd-MMM-yy jira.lf.date.relativize : true jira.lf.date.time : hh:mm a jira.lf.edit.version : 3 jira.lf.favicon.hires.url : /images/64jira.png jira.lf.favicon.url : /favicon.ico jira.lf.gadget.color1 : #369 jira.lf.gadget.color2 : #900925 jira.lf.gadget.color3 : #d94625 jira.lf.gadget.color4 : #346006 jira.lf.gadget.color5 : #003366 jira.lf.gadget.color6 : #411E66 jira.lf.gadget.color7 : #bbb jira.lf.logo.height : 32 jira.lf.logo.url : /jira-logo-scaled.png jira.lf.logo.width : 177 jira.lf.menu.bgcolour : #326ca6 jira.lf.menu.separator : #f0f0f0 jira.lf.menu.textcolour : #ffffff jira.lf.text.activelinkcolour : #326ca6 jira.lf.text.headingcolour : #292929 jira.lf.text.linkcolour : #326ca6 jira.lf.top.bgcolour : #003366 jira.lf.top.hilightcolour : #326ca6 jira.lf.top.separator.bgcolor : #003366 jira.lf.top.textcolour : #ffffff jira.lf.top.texthilightcolour : #f0f0f0 jira.max.AdminPage.history.items : 5 jira.max.Issue.history.items : 50 jira.max.JQLQuery.history.items : 10 jira.max.history.items : 10 jira.max.issue.filter.dropdown.items : 10 jira.max.issue.history.dropdown.items : 6 jira.maximum.authentication.attempts.allowed : 3 jira.mode : private jira.option.allowattachments : true jira.option.allowcookies : true jira.option.allowsubtasks : true jira.option.allowthumbnails : true jira.option.allowunassigned : false jira.option.captcha.on.signup : false jira.option.emailvisible : show jira.option.ignore.url.with.key : true jira.option.indexing : true jira.option.issuelinking : true jira.option.logoutconfirm : never jira.option.precedence.header.exclude : false jira.option.rpc.allow : true jira.option.timetracking : true jira.option.user.externalmanagement : false jira.option.user.externalpasswordmanagement : false jira.option.voting : true jira.option.watching : true jira.option.web.usegzip : false jira.path.attachments : G:\jira\data\attachments jira.path.attachments.use.default.directory : true jira.path.index : D:\jira\indexes jira.path.index.use.default.directory : true jira.plugin.state-.com.atlassian.jira.gadgets:text-gadget : true jira.plugin.state-.com.atlassian.jira.plugin.ext.bamboo : false jira.plugin.state-.com.atlassian.jira.plugin.ext.subversion : false jira.plugin.state-.com.atlassian.jira.plugin.system.renderers.wiki.macros:html : true jira.plugin.state-.com.atlassian.jira.whatsnew.jira-whatsnew-plugin:show-whats-new-flag : true jira.plugin.state-.com.atlassian.jirafisheyeplugin : false jira.plugin.state-.com.atlassian.jirafisheyeplugin:crucible-issuepanel : false jira.plugin.state-.com.atlassian.jirafisheyeplugin:crucible-projectpanel : false jira.plugin.state-.com.atlassian.jirafisheyeplugin:fisheye-issuepanel : false jira.plugin.state-.com.atlassian.jirafisheyeplugin:fisheye-projectpanel : false jira.plugin.state-.com.consultingtoolsmiths.jira.plugin.ext.mercurial.mercurial-jira-plugin : false jira.plugin.state-.com.onresolve.jira.groovy.groovyrunner : true jira.plugin.state-.com.onresolve.jira.groovy.groovyrunner:scriptrunner_section : true jira.plugin.state-.com.plugenta.jiraauditor : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-boardsearch-shortcut-classic : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-chartboard-shortcut-classic : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-collapsecolumn-shortcut : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-delete-shortcut-classic : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-nextbox-shortcut : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-planningboard-shortcut : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-prevbox-shortcut : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-priority-shortcut-classic : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-releasedboard-shortcut-classic : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-taskboard-shortcut-classic : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-togglebox-shortcut : false jira.plugin.state-.com.pyxis.greenhopper.jira:greenhopper-togglecard-shortcut : false jira.plugin.state-.com.xiplink.jira.git.jira-git-plugin : false jira.plugin.state-.net.bull.javamelody : false jira.plugin.state-.tac.jira.languages.de_DE : false jira.plugin.state-.tac.jira.languages.es_ES : false jira.plugin.state-.tac.jira.languages.fr_FR : false jira.plugin.state-.tac.jira.languages.ja_JP : false jira.project.summary.max.issues : 3 jira.projectkey.description : admin.projects.key.description jira.projectkey.pattern : ([A-Z][A-Z]+) jira.projectkey.reservedwords.list : PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7, COM8, COM9, CON, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, LPT9 jira.projectkey.warning : admin.errors.must.specify.unique.project.key jira.releasenotes.default : Html jira.releasenotes.templatenames : Html, Text jira.releasenotes.templates : releasenotes-html.vm, releasenotes-text.vm jira.scheme.default.issue.type : 10000 jira.schemes.comparison.max : 5 jira.screenshotapplet.enabled : true jira.screenshotapplet.linux.enabled : false jira.search.fullcontentview.pagebreaks : true jira.search.maxclauses : 65000 jira.search.views.default.max : 1000 jira.search.views.max.limit : 1000 jira.search.views.max.unlimited.group : jira.sendmail.recipient.batch.size : 100 jira.setup : true jira.show.contact.administrators.form : false jira.subscription.email.max.issues : 200 jira.subtask.quickcreateform.fields : summary,issuetype,assignee,timetracking jira.subtask.quickcreateform.template : templates/jira/issue/subtask/quickcreationform-vertical.vm jira.table.cols.dashboard : issuetype, issuekey, summary, priority jira.table.cols.subtasks : issuetype, status, assignee, progress jira.table.cols.voted : issuetype, issuekey, summary, priority, status jira.table.cols.watched : issuetype, issuekey, summary, priority, status jira.table.gadget.max.rows : 50 jira.thumbnail.maxheight : 200 jira.thumbnail.maxwidth : 200 jira.timetracking.copy.comment.to.work.desc.on.transition : true jira.timetracking.days.per.week : 5 jira.timetracking.default.unit : MINUTE jira.timetracking.estimates.legacy.behaviour : true jira.timetracking.format : hours jira.timetracking.hours.per.day : 6 jira.title : Market Leader Defect Tracker jira.trustedapp.key.private.data : null jira.trustedapp.key.public.data : null jira.trustedapp.uid : jira:10257653 jira.trustedapps.timeout.default : 10000 jira.trustedapps.urlmatch.default : /sr/jira.issueviews:searchrequest /secure/RunPortlet /rest /rpc/soap /plugins/servlet/streams /plugins/servlet/applinks jira.usermanagement.maxdisplaymembers : 200 jira.version.patched : 713 jira.view.issue.links.sort.order : type, status, priority jira.view.issue.show.quicksubtask.when.no.subtasks : false jira.viewcvs.root.type : cvsroot jira.webresource.flushcounter : 4 jira.webresource.superbatch.flushcounter : 1 jira.websudo.is.disabled : true jira.websudo.timeout : 10 jira.whitelist.disabled : false jira.whitelist.rules : null jira.xsrf.enabled : true show.plugin.marketing.hints : true user.default.share.private : true user.issues.per.page : 30 user.keyboard.shortcuts.disabled : false user.notifications.mimetype : html user.notify.own.changes : false user.show.actions.in.navigator : true webwork.i18n.encoding : UTF-8 webwork.multipart.maxSize : 10485760 ___ License Details ________________________ License Set : true Entitled To Support : true Evaluation : false Description : JIRA Unlimited Users: Developer License SEN : SEN-L1713071 Organisation : HouseValues Partner : Maximum Number Of Users : Unlimited ___ Database Statistics ____________________ Issues : 45574 Projects : 26 Custom Fields : 92 Workflows : 17 Users : 2323 Groups : 198 Attachments : 24517 Comments : 99803 ___ Upgrade History ________________________ 5.0#713 Time Performed : 2012-05-17 23:32:36.293 Original Version : 4.0#466 4.0#466 Time Performed : Unknown ___ File Paths _____________________________ JIRA Home : /var/local/atlassian/jira-home Location of atlassian-jira.log : /var/local/atlassian/jira-home/log/atlassian-jira.log Index Path : /var/local/atlassian/jira-home/caches/indexes Attachment Path : /var/local/atlassian/jira-home/data/attachments ___ User Plugins ____________________________ Number : 4 JavaMelody Monitoring Plugin : net.bull.javamelody Version : 1.37.0 Status : disabled Vendor : JavaMelody Description : Monitoring of JIRA, Confluence or Bamboo server with JavaMelody. MarketLeader Customer Notification Listener : com.marketleader.jira.jira-marketleader-customermailer-listener Version : 1.0.2 Status : enabled Vendor : Red Radish Description : Listener which emails customers $authhash-equipped emails on certain events. Marketleader Customer Notification Admin Interface : com.marketleader.jira.jira-marketleader-customermailer-admin Version : 1.0.2 Status : enabled Vendor : Red Radish Description : Admin interface for the MarketLeader customer emailer listener Script Runner : com.onresolve.jira.groovy.groovyrunner Version : 2.1.17 Status : disabled Vendor : Jamie Echlin Ltd Description : Script runner plugin for Atlassian JIRA. ___ System Plugins __________________________ Number : 80 ActiveObjects Plugin - OSGi Bundle : com.atlassian.activeobjects.activeobjects-plugin Version : 0.19.7 Status : enabled Vendor : Atlassian Description : An OSGi bundle that provides a service that allows plugins to persist objects using the ActiveObjects framework Apache HttpClient OSGi bundle : org.apache.httpcomponents.httpclient-4.0 Version : 4.0 Status : enabled Vendor : Apache Software Foundation Description : HttpComponents Client (OSGi bundle) Apache HttpCore OSGi bundle : org.apache.httpcomponents.httpcore-4.0 Version : 4.0 Status : enabled Vendor : Apache Software Foundation Description : HttpComponents Core (OSGi bundle) Applinks Product Plugin : com.atlassian.applinks.applinks-plugin Version : 3.6.4 Status : enabled Vendor : Atlassian Description : Plugin that facilitates discovery, connections and authentication with remote applications Atlassian Embedded Crowd - Administration Plugin : com.atlassian.crowd.embedded.admin Version : 1.3.7 Status : enabled Vendor : Atlassian Description : Provides the administration of local and remote user directories. Atlassian Gadgets OAuth Service Provider Plugin : com.atlassian.gadgets.oauth.serviceprovider Version : 3.1.21 Status : enabled Vendor : Atlassian Description : Plugin that makes OAuth Service Providers Gadget aware. Atlassian JIRA - Plugins - Admin Quick Navigation : com.atlassian.jira.jira-admin-quicknav-plugin Version : 5.0 Status : enabled Vendor : Atlassian Description : Inserts quick navigation component in JIRA Administration Panel Atlassian JIRA - Plugins - Admin Summary Component : com.atlassian.jira.jira-admin-summary-plugin Version : 5.0 Status : enabled Vendor : Atlassian Description : Supplies Content to the JIRA Administration Summary Page Atlassian JIRA - Plugins - Application Properties : com.atlassian.jira.jira-application-properties-plugin Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides advanced application properties configuration Atlassian JIRA - Plugins - Closure Template Renderer : com.atlassian.jira.jira-soy-plugin Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides renderer for Closure templates Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin : com.atlassian.jira.jira-issue-link-applinks-common-plugin Version : 5.0 Status : enabled Vendor : ${project.organization.name} Description : Provides the common utilities for AppLinks based issue link plugins Atlassian JIRA - Plugins - Confluence Link : com.atlassian.jira.jira-issue-link-confluence-plugin Version : 5.0 Status : enabled Vendor : ${project.organization.name} Description : Provides creation and rendering of issue links to Confluence pages Atlassian JIRA - Plugins - Gadgets Plugin : com.atlassian.jira.gadgets Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides Gadgets and REST endpoints bundled with JIRA Atlassian JIRA - Plugins - Issue Web Link : com.atlassian.jira.jira-issue-link-web-plugin Version : 5.0 Status : enabled Vendor : ${project.organization.name} Description : Provides creation and rendering of issue links to web pages Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin : com.atlassian.jira.lookandfeel Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides logo upload capabilities Atlassian JIRA - Plugins - Mail Plugin : com.atlassian.jira.jira-mail-plugin Version : 5.0 Status : enabled Vendor : ${project.organization.name} Description : JIRA provides cutting edge issue tracking and project management. Atlassian JIRA - Plugins - OAuth Consumer SPI : com.atlassian.jira.oauth.consumer Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides the Consumer SPI implementation required for OAuth in JIRA. Atlassian JIRA - Plugins - OAuth Service Provider SPI : com.atlassian.jira.oauth.serviceprovider Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides the OAuth Service Provider SPI implementation required for OAuth in JIRA. Atlassian JIRA - Plugins - Project Config Plugin : com.atlassian.jira.jira-project-config-plugin Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides easier project administration with JIRA Atlassian JIRA - Plugins - Quick Edit Plugin : com.atlassian.jira.jira-quick-edit-plugin Version : 1.0.29 Status : enabled Vendor : Atlassian Description : This is the com.atlassian.jira:jira-quick-edit-plugin plugin for Atlassian JIRA. Atlassian JIRA - Plugins - REST Plugin : com.atlassian.jira.rest Version : 5.0 Status : enabled Vendor : Atlassian Description : Provides a REST interface for JIRA Atlassian JIRA - Plugins - Remote JIRA Link : com.atlassian.jira.jira-issue-link-remote-jira-plugin Version : 5.0 Status : enabled Vendor : ${project.organization.name} Description : Provides creation and rendering of links to remote JIRA issues Atlassian JIRA - Plugins - SAL Plugin : com.atlassian.sal.jira Version : 5.0 Status : enabled Vendor : Atlassian Software Systems Description : JIRA implementation of the Shared Application Access Layer (SAL) Atlassian JIRA - Plugins - Share Content Component : com.atlassian.jira.jira-share-plugin Version : 5.0 Status : enabled Vendor : Atlassian Description : Allows users to share issue and searches Atlassian JIRA - Plugins - View Issue Panels : com.atlassian.jira.jira-view-issue-plugin Version : 5.0 Status : enabled Vendor : ${project.organization.name} Description : Provides WebPanels for the View Issue Page Atlassian OAuth Admin Plugin : com.atlassian.oauth.admin Version : 1.3.10 Status : enabled Vendor : Atlassian Description : Plugin that provides a single tabbed view for administering OAuth consumers and service provider information. Atlassian OAuth Consumer Plugin : com.atlassian.oauth.consumer Version : 1.3.10 Status : enabled Vendor : Atlassian Description : Plugin that makes it possible for applications to become Consumers. Atlassian OAuth Consumer SPI : com.atlassian.oauth.atlassian-oauth-consumer-spi-1.3.10 Version : 1.3.10 Status : enabled Vendor : Atlassian Description : Consumer SPIs to allow applications to provide custom implementations of storing token and consumer info Atlassian OAuth Service Provider Plugin : com.atlassian.oauth.serviceprovider Version : 1.3.10 Status : enabled Vendor : Atlassian Description : Plugin that makes it possible for applications to become Service Providers. Atlassian OAuth Service Provider SPI : com.atlassian.oauth.atlassian-oauth-service-provider-spi-1.3.10 Version : 1.3.10 Status : enabled Vendor : Atlassian Description : Service Provider SPIs to allow applications to provide custom implementations of storing token consumer info Atlassian REST - Module Types : com.atlassian.plugins.rest.atlassian-rest-module Version : 2.5.5 Status : enabled Vendor : Atlassian Description : A plugin that contains REST module types Atlassian Soy Templates - Plugin : com.atlassian.soy.soy-template-plugin Version : 1.0.0-m3 Status : enabled Vendor : Atlassian Description : Base POM for Atlassian projects Atlassian Template Renderer API : com.atlassian.templaterenderer.api Version : 1.3.1 Status : enabled Vendor : Atlassian Description : API and plugins for easily rendering content from different template engines. Atlassian Template Renderer Velocity 1.6 Plugin : com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin Version : 1.3.1 Status : enabled Vendor : Atlassian Description : API and plugins for easily rendering content from different template engines. Atlassian UI Plugin : com.atlassian.auiplugin Version : 3.5.5 Status : enabled Vendor : Atlassian Description : An Atlassian plugin that contains the core javascript files used in Atlassian products. Atlassian Universal Plugin Manager Plugin : com.atlassian.upm.atlassian-universal-plugin-manager-plugin Version : 1.5.3 Status : enabled Vendor : Atlassian Pty Ltd Description : This is the plugin that provides the Atlassian Universal Plugin Manager. Crowd REST API : crowd-rest-application-management Version : 1.0 Status : enabled Vendor : Atlassian Software Systems Description : Crowd REST API - Application Management Crowd REST API : crowd-rest-plugin Version : 1.0 Status : enabled Vendor : Atlassian Software Systems Description : Crowd REST API Crowd System Password Encoders : crowd.system.passwordencoders Version : 1.0 Status : enabled Vendor : Atlassian Software Systems Description : Crowd Password Encoders shipped with Crowd Embedded Gadgets Plugin : com.atlassian.gadgets.embedded Version : 3.1.21 Status : enabled Vendor : Atlassian Description : Plugin which allows gadgets to be embedded in pages English (United Kingdom) Language Pack : com.atlassian.jira.jira-languages.en_UK Version : 5.0 Status : enabled Vendor : Atlassian Description : This plugin contains translations the core keys in JIRA for English (United Kingdom). English (United States) Language Pack : com.atlassian.jira.jira-languages.en_US Version : 5.0 Status : enabled Vendor : Atlassian Description : This plugin contains translations the core keys in JIRA for English (United States). FishEye Plugin : com.atlassian.jirafisheyeplugin Version : 5.0.0 Status : disabled Vendor : Atlassian Software Systems Description : JIRA Fisheye Plugin French (France) Language Pack : tac.jira.languages.fr_FR Version : 5.0.0-rc2-v2r1553-2012-01-05 Status : disabled Vendor : Atlassian Community Description : This plugin contains translations for fr_FR Gadget Dashboard Plugin : com.atlassian.gadgets.dashboard Version : 3.1.21 Status : enabled Vendor : Atlassian Description : Plugin which renders a dashboard of gadgets Gadget Directory Plugin : com.atlassian.gadgets.directory Version : 3.1.21 Status : enabled Vendor : Atlassian Description : Plugin which renders a directory of gadgets Gadget Spec Publisher Plugin : com.atlassian.gadgets.publisher Version : 3.1.21 Status : enabled Vendor : Atlassian Description : Plugin which provides a way to publish gadget specs found in plugins German (Germany) Language Pack : tac.jira.languages.de_DE Version : 5.0.0-rc2-v2r3852-2012-01-06 Status : disabled Vendor : Atlassian Community Description : This plugin contains translations for de_DE ICU4J : com.atlassian.bundles.icu4j-3.8.0.1 Version : 3.8.0.1 Status : enabled Vendor : Atlassian Pty Ltd Description : ICU4J as an OSGi bundle JDOM DOM Processor : com.springsource.org.jdom-1.0.0 Version : 1.0.0 Status : enabled Vendor : SpringSource Description : JIRA Active Objects SPI implementation : com.atlassian.activeobjects.jira.spi Version : 0.19.7 Status : enabled Vendor : Atlassian Software Systems Description : A plugin that provides the DataSourceProvider service JIRA Activity Stream Plugin : com.atlassian.streams.streams-jira-plugin Version : 5.1.0 Status : enabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. JIRA Bamboo Plugin : com.atlassian.jira.plugin.ext.bamboo Version : 5.0 Status : disabled Vendor : Atlassian Software Systems Pty Ltd Description : Allows you to see builds and telemetry from a remote Bamboo server JIRA Feedback Plugin : com.atlassian.plugin.atlassian-feedback-plugin Version : 1.1.3 Status : enabled Vendor : Atlassian Description : Provides a dialog for customers to provide feedback directly to Atlassian from within JIRA. JIRA Importers Plugin (JIM) : com.atlassian.jira.plugins.jira-importers-plugin Version : 4.0 Status : enabled Vendor : Atlassian Description : A plugin (originally part of JIRA 4.2 and older) which provides capability to import to JIRA issues from 3rd party issue trackers: Bugzilla, FogBugz and Mantis. JIRA JSON-RPC Plugin : com.atlassian.jira.rpc.jira-json-rpc-plugin Version : 1.0.4 Status : enabled Vendor : Atlassian Software Description : Exposes JIRA SOAP services using JSON-RPC JIRA Streams Inline Actions Plugin : com.atlassian.streams.jira.inlineactions Version : 5.1.0 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : JIRA Streams Inline Actions Plugin JIRA Usage Hints : jira.usage.hints Version : 1.0 Status : enabled Vendor : Atlassian Description : This library includes the web fragments for JIRA usage hints displayed on issue operation dialogs. It should never be disabled. JIRA What's New Plugin : com.atlassian.jira.whatsnew.jira-whatsnew-plugin Version : 1.1.0.1 Status : enabled Vendor : Atlassian Description : Displays a whats new dialog for users just having upgraded to this version of JIRA. JQL Functions : jira.jql.function Version : 1.0 Status : enabled Vendor : Atlassian Description : This plugin implements a JQL function in JIRA. JSON Library : com.atlassian.bundles.json-20070829.0.0.1 Version : 20070829.0.0.1 Status : enabled Vendor : Atlassian Pty Ltd Description : Library for manipulating JSON Japanese (Japan) Language Pack : tac.jira.languages.ja_JP Version : 5.0.0-rc2-v2r10187-2012-01-05 Status : disabled Vendor : Atlassian Community Description : This plugin contains translations for ja_JP Keyboard Shortcuts Plugin : jira.keyboard.shortcuts Version : 1.0 Status : enabled Vendor : Atlassian Description : A plugin that defines a number of keyboard shortcuts. Neko HTML : com.atlassian.bundles.nekohtml-1.9.12.1 Version : 1.9.12.1 Status : enabled Vendor : Atlassian Pty Ltd Description : Neko HTML library as an OSGi bundle Opensocial Plugin : com.atlassian.gadgets.opensocial Version : 3.1.21 Status : enabled Vendor : Atlassian Description : Plugin for OpenSocial API Support and Gadget Rendering ROME, RSS and atOM utilitiEs for Java : rome.rome-1.0 Version : 1.0 Status : enabled Vendor : Sun Microsystems Description : All Roads Lead to ROME. ROME is a set of Atom/RSS Java utilities that make it easy to work in Java with most syndication formats. Today it accepts all flavors of RSS (0.90, 0.91, 0.92, 0.93, 0.94, 1.0 and 2.0), Atom 0.3 and Atom 1.0 feeds. Rome includes a set of parsers and generators for the various flavors of feeds, as well as converters to convert from one format to another. The parsers can give you back Java objects that are either specific for the format you want to work with, or a generic normalized SyndFeed object that lets you work on with the data without bothering about the underlying format. ROME: RSS/Atom syndication and publishing tools : com.springsource.com.sun.syndication-0.9.0 Version : 0.9.0 Status : enabled Vendor : SpringSource Description : RPC JIRA Plugin : com.atlassian.jira.ext.rpc Version : 5.0.5 Status : enabled Vendor : Atlassian Description : The standard JIRA RPC services, both SOAP and XML-RPC. Spanish (Spain) Language Pack : tac.jira.languages.es_ES Version : 5.0.0-rc2-v2r6467-2011-12-29 Status : disabled Vendor : Atlassian Community Description : This plugin contains translations for es_ES Streams API : com.atlassian.streams.streams-api-5.1.0 Version : 5.1.0 Status : enabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. Streams Core Plugin : com.atlassian.streams.core Version : 5.1.0 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : Streams Core Plugin Streams Inline Actions Plugin : com.atlassian.streams.actions Version : 5.1.0 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : Streams Inline Actions Plugin Streams Plugin : com.atlassian.streams Version : 5.1.0 Status : enabled Vendor : Atlassian Software Systems Pty Ltd Description : Streams Plugin Streams SPI : com.atlassian.streams.streams-spi-5.1.0 Version : 5.1.0 Status : enabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. Streams Third Party Provider Plugin : com.atlassian.streams.streams-thirdparty-plugin Version : 5.1.0 Status : enabled Vendor : Atlassian Description : Lists recent activity in a single project, or in all projects. Support Tools Plugin : com.atlassian.support.stp Version : 2.9.5 Status : enabled Vendor : Atlassian Support Description : This is the Support Tools Plugin, developed to help Atlassian customers with our products. User Format : jira.user.format Version : 1.0 Status : enabled Vendor : Atlassian Description : This plugin renders a user in JIRA. User Profile Panels : jira.user.profile.panels Version : 1.0 Status : enabled Vendor : Atlassian Description : This library includes the panels included on the user profile page. Workflow Designer Plugin : com.atlassian.jira.plugins.jira-workflow-designer Version : 2.5.2 Status : enabled Vendor : Atlassian Description : The visual way to edit JIRA Workflows. jira-ical-feed : com.atlassian.jira.extra.jira-ical-feed Version : 1.0.2 Status : enabled Vendor : Atlassian Description : Provides an iCal feed of JIRA issues and versions ___ Listeners ______________________________ Instance Count : 3 Mail Listener : com.atlassian.jira.event.listeners.mail.MailListener Issue Assignment Listener : com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener Issue Index Listener : com.atlassian.jira.event.listeners.search.IssueIndexListener ___ Services _______________________________ Instance Count : 10 Email - Backup Request Automated Tickets : com.atlassian.jira.service.services.mail.MailFetcherService Service Delay : 60000ms popserver : backuprequests@marketleader.com handler.params : project=HD, issuetype=5, catchemail=backuprequests@marketleader.com, createusers=true,ccassignee=true, bulk=forward handler : admin.service.common.handler.create.or.comment Email - HR Notifications : com.atlassian.jira.service.services.mail.MailFetcherService Service Delay : 60000ms popserver : HRNotification@marketleader.com handler.params : project=HD, issuetype=5, catchemail=hrnotification@marketleader.com, createusers=true,ccassignee=false, bulk=forward handler : admin.service.common.handler.create.or.comment Git Revision Indexing Service : com.xiplink.jira.git.revisions.RevisionIndexService Service Delay : 300000ms Exception getting Service information : java.lang.UnsupportedOperationException: This method is not supported in an UnloadableJiraServiceContainer Mail Queue Service : com.atlassian.jira.service.services.mail.MailQueueService Service Delay : 60000ms NotificationCacheUpdateJob-job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 86400000ms pluginJobName : NotificationCacheUpdateJob-job repeatInterval : 86400000 initiallyFired : true PluginLicenseExpiryJob-job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 86400000ms pluginJobName : PluginLicenseExpiryJob-job repeatInterval : 86400000 initiallyFired : true Service Provider Token Remover : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 28800000ms pluginJobName : Service Provider Token Remover repeatInterval : 28800000 initiallyFired : true com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 60000ms pluginJobName : com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job repeatInterval : 60000 initiallyFired : true com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 300000ms pluginJobName : com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor repeatInterval : 300000 initiallyFired : true upmPluginUpgradeCheckJob : com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService Service Delay : 86400000ms pluginJobName : upmPluginUpgradeCheckJob repeatInterval : 86400000 initiallyFired : true ___ Trusted Applications ___________________ Instance Count : 1 Application Name : http://krkweb04:8060/ Matching URLs : /sr/jira.issueviews:searchrequest /secure/RunPortlet Matching IP : 10.10.4.34 ___ Java Class Paths _______________________ sun.boot.class.path : /usr/java/jdk1.6.0_45/jre/lib/resources.jar: /usr/java/jdk1.6.0_45/jre/lib/rt.jar: /usr/java/jdk1.6.0_45/jre/lib/sunrsasign.jar: /usr/java/jdk1.6.0_45/jre/lib/jsse.jar: /usr/java/jdk1.6.0_45/jre/lib/jce.jar: /usr/java/jdk1.6.0_45/jre/lib/charsets.jar: /usr/java/jdk1.6.0_45/jre/lib/modules/jdk.boot.jar: /usr/java/jdk1.6.0_45/jre/classes java.library.path : /usr/java/jdk1.6.0_45/jre/lib/amd64/server: /usr/java/jdk1.6.0_45/jre/lib/amd64: /usr/java/jdk1.6.0_45/jre/../lib/amd64: /usr/java/packages/lib/amd64: /usr/lib64: /lib64: /lib: /usr/lib java.endorsed.dirs : /var/local/atlassian/jira/endorsed java.ext.dirs : /usr/java/jdk1.6.0_45/jre/lib/ext: /usr/java/packages/lib/ext java.class.path : /var/local/atlassian/jira/bin/bootstrap.jar 2014-03-18 11:07:25,533 main INFO [atlassian.jira.startup.JiraStartupLogger] ****************************************************************************** JIRA 5.0 build: 713 started. You can now access JIRA through your web browser. ****************************************************************************** 2014-03-18 11:07:27,129 main INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] Starting the JIRA Scheduler.... 2014-03-18 11:07:27,161 main INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler started. 2014-03-18 11:07:28,044 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger] ___ Modifications ___________________________ Modified Files : jira-application.properties, email-template-id-mappings.xml Removed Files : None 2014-03-18 11:07:28,242 QuartzWorker-1 ERROR ServiceRunner NotificationCacheUpdateJob-job [sal.jira.scheduling.JiraPluginSchedulerService] Unable to load a service descriptor for the job 'NotificationCacheUpdateJob-job'. This is usually the result of an obsolete service that can removed in the Administration section. 2014-03-18 11:07:28,244 QuartzWorker-1 ERROR ServiceRunner PluginLicenseExpiryJob-job [sal.jira.scheduling.JiraPluginSchedulerService] Unable to load a service descriptor for the job 'PluginLicenseExpiryJob-job'. This is usually the result of an obsolete service that can removed in the Administration section. 2014-03-18 11:07:28,274 QuartzWorker-1 ERROR ServiceRunner com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job [sal.jira.scheduling.JiraPluginSchedulerService] Unable to load a service descriptor for the job 'com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job'. This is usually the result of an obsolete service that can removed in the Administration section. ^C
2.1.7 is not compatible with 5.0... use the latest compatible version with 5.0, or uninstall, then install from UPM.
Thanks. That was it.
