Unexpected Import Failure
Jero Dungog May 30, 2019
I had a backup file from one of my Jira Server instances,
When I try to import a specific project from that backup file I get a Null Pointer Exception on the atlassian-jira.log file
While the import interface only shows: There was an unexpected problem processing the backup XML file <directory of imported file> : null
Does anyone have any idea on how to resolve this issue?
full log is:
2019-05-31 01:54:29,067 JiraTaskExectionThread-10 ERROR <account> 114x106574x1 xkqi7u 203.177.52.178,127.0.0.1 /secure/admin/ProjectImportSelectProject.jspa [c.a.j.imports.xml.DefaultBackupXmlParser] Unexpected import failure
java.lang.NullPointerException
at com.atlassian.greenhopper.imports.LexorankPreImportHandler.addFieldMapping(LexorankPreImportHandler.java:94)
at com.atlassian.greenhopper.imports.LexorankPreImportHandler.handleEntity(LexorankPreImportHandler.java:78)
at com.atlassian.jira.imports.project.ao.handler.ChainedAoSaxHandler.endRow(ChainedAoSaxHandler.java:289)
at com.atlassian.jira.imports.project.ao.handler.ChainedAoSaxHandler.endElement(ChainedAoSaxHandler.java:193)
at com.atlassian.jira.imports.project.ao.handler.ChainedAoSaxHandler.endElement(ChainedAoSaxHandler.java:151)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.atlassian.security.xml.RestrictedXMLReader.parse(RestrictedXMLReader.java:103)
at com.atlassian.jira.imports.xml.DefaultBackupXmlParser$XmlParser.parseXml(DefaultBackupXmlParser.java:115)
at com.atlassian.jira.imports.xml.DefaultBackupXmlParser.parse(DefaultBackupXmlParser.java:64)
at com.atlassian.jira.imports.xml.DefaultBackupXmlParser.parseXml(DefaultBackupXmlParser.java:52)
at com.atlassian.jira.imports.xml.DefaultBackupXmlParser.parseAoBackupXml(DefaultBackupXmlParser.java:46)
at com.atlassian.jira.imports.project.DefaultProjectImportManager.getAoProjectImportData(DefaultProjectImportManager.java:363)
at com.atlassian.jira.imports.project.DefaultProjectImportManager.getProjectImportData(DefaultProjectImportManager.java:257)
at com.atlassian.jira.bc.imports.project.DefaultProjectImportService.getProjectImportData(DefaultProjectImportService.java:576)
at com.atlassian.jira.web.action.admin.importer.project.ProjectImportSelectProject$MappingResultCallable.call(ProjectImportSelectProject.java:252)
at com.atlassian.jira.web.action.admin.importer.project.ProjectImportSelectProject$MappingResultCallable.call(ProjectImportSelectProject.java:233)
at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:481)
at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:443)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:216)
at java.lang.Thread.run(Thread.java:748)
Earl McCutcheon
June 3, 2019
Hi Jero,
The error is occuring in the LexorankPreImportHandler while attempting to map the rank field values but conflicting on a missing value.
Additional details on the cause of this error as well as steps to correct the issue can be seen in the following KB article:
Check this out and let me know if you have any questions.
Earl
