Sign up Log in
Unknown lifecycle phase error
Vedant Kulkarni
I am getting Unknown lifecycle phase error after entering the command
atlas-mvn eclipse:eclipse
Can anybody help me with this?
3 votes
harshahid_h February 27, 2020
@Vlad Polonskiy  Thanks a lot :)
changed to "call set MVN_COMMAND=%%MVN_COMMAND:%%"
Build is success now.
Andy Heinzer
February 15, 2019
It looks like this kind of error has been reported before when using the Atlassian-SDK on Windows platforms specifically.  Please see the bug report in https://ecosystem.atlassian.net/browse/ATLASSDK-93
In it, other users have reported in the comments there that it might be possible to modify a mvn.bat file in that bin folder and make some adjustments to avoid this error.   I'm more concerned about the first error on the screen after you run your command of:
'else' is not recognized as an internal or external command,
operable program or batch file.
Perhaps if we can address that issue first, these other errors can be avoided entirely.
James Linnell
March 1, 2019
I have fixed the 'else' error with the solution in that thread: https://ecosystem.atlassian.net/browse/ATLASSDK-93?focusedCommentId=284542&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-284542
I still receive the Unknown Lifecycle Phase error.
Vlad Polonskiy
April 1, 2019
Looks like I was able to fix "Lifecycle Phase" error as follows (I got it on Windows):
1. In "atlas-mvn.bat" file comment out the following line:
call set MVN_COMMAND=%%MVN_COMMAND:${mavenPluginName}=%MVN_PLUGIN%%%
2. Replace it with:
Vlad
Like # people like this
Melek Jebnoun_Vectors_
Many thanks this solve the issue I was having :)
Thanks again
Tom Lister October 11, 2019
thanks - fixed my eclipse error
else is here but I'm not sure how to fix
:loopstart
set /a ARGI = !ARGI! + 1
set /a ARGN = !ARGI! + 1
if !ARGI! gtr %ARGC% goto loopend
call :getarg !ARGI! ARG
call :getarg !ARGN! ARGNEXT
else (
set MVN_PARAMS=%MVN_PARAMS% %ARG%
shift
goto loopstart
:loopend
Leirbag Assuab
Many thanks @Vlad Polonskiy! After updating SDK I've been stuck for several hours with "Lifecycle Phase" error. Your comment contains must-have info to fix it.
Like Sam likes this
Derek White
This is entirely unacceptable. Why has the SDK not been updated to fix this wide-spread issue?
Atlassian's priorities over the last couple years have been atrocious. They need to gets their shit together. People are already talking to their C-levels to convince them to leave Atlassian products.
You make products for developers, but ignore developers.
Developers like text-based editors, so Atlassian is removing text-based editing across all their products. It's already gone from confluence, bitbucket is currently in transition (hit the feedback button and complain! please!), and Jira will likely be next (I don't use Cloud, so not sure about there).
Developers like using code blocks. Atlassian has had several issues dating back a decade to allow code blocks to be indented. Nothing. Some of their products don't even allow inline code blocks. It's absolutely ridiculous.
What happened to no sales/marketing? Oh, yeah, you went public in 2015. That explains a lot. Everything Atlassian is doing these days is geared toward non-technical users - the same users that sales/marketing would be approaching to sell the products to. In the past, developers chose to use Atlassian products because they were good and pushed it up the chain. They are reversing this process and it is resulting in developers being pushed away from the products.
A simple google search for "alternatives to atlassian" shows numerous articles from 2019 listing their top alternatives. Some as recent as a few days ago. The tides are changing. People are looking elsewhere.
Derek White
`atlas-mvn clean` still fails with "No goals have been specified for this build." Might fix the goals with format eclipse:eclipse, but it doesn't work with singular commands. You can use the atlas-* scripts for most of them, but not all. Still not 100%, but enough to actually get working.
Jonathan Rosenberg
@Vlad Polonskiy Vlad's solution worked for me and should be posted as the answer.
Like Sam likes this
oliverbriansyson
December 3, 2019
Cant seem to find the bat file?  Where would the bat file be in the folder structure?
Like Sam likes this
Leirbag Assuab
Hi @oliverbriansyson , it would be in "bin" folder (%ATLAS_SDK_HOME%\bin):
Sam
@Vlad Polonskiy Thanks for commenting, it fixed it for me!
@Leirbag Assuab Thanks for specifying where the bat file is!
George Lewe (Lewe)
Unbelievable. Fits well in the general loss of Atlassians connection to users and developers. I am sorry to see that development still ongoing.
Thanks for the fix, Vlad. Should have been provided by Atlassian a long time ago.
John Lill
April 1, 2020
Thanks for this, I can't believe it is still an issue, over a year now.
Derek White
A year?! Ha!
"November 4, 2015" is when the issue (https://ecosystem.atlassian.net/browse/ATLASSDK-93) was created.
Like John Lill likes this
John Lill
April 6, 2020
Ouch. :(
