Unknown packaging: eclipse-plugin
Karim Belhadj
hello team
I try to create a new plugin (first time) , but i get always this error in eclipse
 error: Unknown packaging: eclipse-plugin.
this is my pom .xml
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>fr.spectrumgroupe.jira.plugins</groupId>
<artifactId>test.jira</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<name>test.jira</name>
<description>This is the fr.spectrumgroupe.jira.plugins:test.jira plugin for Atlassian JIRA.</description>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<!-- Add dependenc
y on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<!-- https://mvnrepository.com/artifact/com.atlassian.plugins/atlassian-plugins-osgi-testrunner -->
<dependency>
<version>2.0.1</version>
<scope>test</scope>
</dependency>
<!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit -->
<!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit -->
<dependency>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-client</artifactId>
<version>${testkit.version}</version>
<scope>test</scope>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<artifactId>jira-testkit-plugin</artifactId>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>
fr.spectrumgroupe.jira.plugins.api,
</Export-Package>
<!-- Add package import here -->
<Import-Package>
org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional",
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<repositories>
<repository>
<id>Atlassian-Repo</id>
<name>Atlassianrepo</name>
<url>https://maven.atlassian.com/repository/public/</url>
</repository>
</repositories>
<properties>
<jira.version>7.13.0</jira.version>
<amps.version>8.0.0</amps.version>
<plugin.testrunner.version>2.0.1</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<!-- This property ensures consistency between the key in atlassian-plugin.xml and the OSGi bundle's key. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
</project>
regards
