Sign up Log in
Unresolved constraint in bundle - JIRA-Bamboo plugin
Peter Macdonald July 16, 2013
I am getting the folloiwng error after upgrading from JIRA 5.2.10 to 5.2.11 and JIRA-Bamboo plugin from 5.1.6 to 6.1.7.
2013-07-17 10:06:24,881 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Detected an error (BundleException) enabling the plugin 'com.atlassian.jira.plugin.ext.bamboo' : Unresolved constraint in bundle com.atlassian.jira.plugins.jira-bamboo-plugin [107]: Unable to resolve 107.0: missing requirement [107.0] package; (&(package=com.atlassian.jira)(version>=6.0.0)).
I have seem similar posts in this forum and the Bamboo Documentation but in those cases the message is being output by Bamboo, not JIRA. The full stack trace is:
2013-07-17 10:06:24,881 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Detected an error (BundleException) enabling the plugin 'com.atlassian.jira.plugin.ext.bamboo' : Unresolved constraint in bundle com.atlassian.jira.plugins.jira-bamboo-plugin [107]: Unable to resolve 107.0: missing requirement [107.0] package; (&(package=com.atlassian.jira)(version>=6.0.0)). This error usually occurs when your plugin imports a package from another bundle with a specific version constraint and either the bundle providing that package doesn't meet those version constraints, or there is no bundle available that provides the specified package. For more details on how to fix this, see http://confluence.atlassian.com/x/1xy6D
2013-07-17 10:06:24,881 localhost-startStop-1 WARN [plugin.osgi.factory.OsgiPlugin] Unable to enable plugin 'com.atlassian.jira.plugin.ext.bamboo'
com.atlassian.plugin.osgi.container.OsgiContainerException: Cannot start plugin: com.atlassian.jira.plugin.ext.bamboo
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:445)
at com.atlassian.plugin.impl.AbstractPlugin.enable(AbstractPlugin.java:237)
at com.atlassian.plugin.manager.PluginEnabler.actualEnable(PluginEnabler.java:114)
at com.atlassian.plugin.manager.PluginEnabler.enable(PluginEnabler.java:99)
at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:725)
at com.atlassian.plugin.manager.DefaultPluginManager.init(DefaultPluginManager.java:178)
at com.atlassian.jira.plugin.JiraPluginManager.start(JiraPluginManager.java:58)
at com.atlassian.jira.ComponentManager$PluginSystem.start(ComponentManager.java:678)
at com.atlassian.jira.ComponentManager.startJIRA(ComponentManager.java:221)
at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:213)
at com.atlassian.jira.ComponentManager.start(ComponentManager.java:198)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:23)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:105)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:284)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:169)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:98)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:25)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:64)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:59)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:80)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:75)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:108) <+5> (StandardContext.java:4791) (StandardContext.java:5285) (LifecycleBase.java:150) (ContainerBase.java:1559) (ContainerBase.java:1549)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.osgi.framework.BundleException: Unresolved constraint in bundle com.atlassian.jira.plugins.jira-bamboo-plugin [107]: Unable to resolve 107.0: missing requirement [107.0] package; (&(package=com.atlassian.jira)(version>=6.0.0))
at org.apache.felix.framework.Felix.resolveBundle(Felix.java:3409)
at org.apache.felix.framework.Felix.startBundle(Felix.java:1709)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:905)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:892)
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:417)
2013-07-17 10:06:24,897 localhost-startStop-1 ERROR [atlassian.plugin.manager.PluginEnabler] Unable to enable plugin com.atlassian.jira.plugin.ext.bamboo
By falling back to plugin version 5.1.6, my JIRA instance has no issues with the JIRA-Bamboo plugin. Is this version really compatible with JIRA 5.2.11 or just version 6?
