UnsatisfiedDependencyException error when creating a custom field plugin
Angelo Diego Crabolu
I'm trying to migrate on old plugin I wrote, containing a custom field but I get  then following error com.atlassian.cache.CacheException: com.atlassian.util.concurrent.LazyReference$InitializationException: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'xxx.plugins.jira.customfields.ReadOnlyProjectComponent': Unsatisfied dependency expressed through constructor argument with index 0 of type [com.atlassian.jira.issue.customfields.manager.OptionsManager]: No qualifying bean of type [com.atlassian.jira.issue.customfields.manager.OptionsManager] found for dependency: expected at least 1 bean which qualifies as autowire candidate for this dependency. Dependency annotations: {@com.atlassian.plugin.spring.scanner.annotation.imports.JiraImport(value=)}; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No qualifying bean of type [com.atlassian.jira.issue.customfields.manager.OptionsManager] found for dependency: expected at least 1 bean which qualifies as autowire candidate for this dependency. Dependency annotations: {@com.atlassian.plugin.spring.scanner.annotation.imports.JiraImport(value=)}
Here is the code for the component
package com.index_education.plugins.jira.customfields;
import com.atlassian.jira.bc.issue.search.SearchService;import com.atlassian.jira.bc.project.component.ProjectComponent;import com.atlassian.jira.component.ComponentAccessor;import com.atlassian.jira.config.FeatureManager;import com.atlassian.jira.issue.customfields.impl.MultiSelectCFType;import com.atlassian.jira.issue.customfields.manager.GenericConfigManager;import com.atlassian.jira.issue.customfields.manager.OptionsManager;import com.atlassian.jira.issue.customfields.option.Option;import com.atlassian.jira.issue.customfields.persistence.CustomFieldValuePersister;import com.atlassian.jira.issue.Issue;import com.atlassian.jira.issue.fields.CustomField;import com.atlassian.jira.issue.fields.config.FieldConfig;import com.atlassian.jira.issue.fields.layout.field.FieldLayoutItem;import com.atlassian.jira.issue.fields.rest.json.beans.JiraBaseUrls;import com.atlassian.jira.security.JiraAuthenticationContext;
import java.util.ArrayList;import java.util.List;import java.util.Map;
import com.atlassian.plugin.spring.scanner.annotation.imports.JiraImport;
public class ReadOnlyProjectComponent extends MultiSelectCFType {
        public ReadOnlyProjectComponent(@JiraImport OptionsManager optionsManager, @JiraImport CustomFieldValuePersister valuePersister,    @JiraImport GenericConfigManager genericConfigManager, @JiraImport JiraBaseUrls jiraBaseUrls, @JiraImport SearchService searchService, @JiraImport FeatureManager featureManager    @JiraImport JiraAuthenticationContext authenticationContext) {        super(optionsManager, valuePersister, genericConfigManager, jiraBaseUrls, searchService, featureManager, authenticationContext);    }
    @Override    public Map<StringObjectgetVelocityParameters(final Issue issuefinal CustomField fieldfinal FieldLayoutItem fieldLayoutItem) {
        // This method is also called to get the default value, in        // which case issue is null         if (issue.equals(null)) {            return super.getVelocityParameters(issue, field, fieldLayoutItem);        }
        FieldConfig fieldConfig = field.getRelevantConfig(issue);        // add what you need to the map here        OptionsManager optionsManager = ComponentAccessor.getOptionsManager();                List<OptionexistingOptions = new ArrayList<Option>();        optionsManager.removeCustomFieldConfigOptions(fieldConfig);
        Long l = 0L;        for (ProjectComponent component : ComponentAccessor.getProjectComponentManager().findAllForProject(issue.getProjectObject().getId())) {            Option option = optionsManager.createOption(fieldConfig, null, l, component.getName());            existingOptions.add(option);            l++;        }                optionsManager.updateOptions(existingOptions);                        final Map<StringObjectmap = super.getVelocityParameters(issue, field, fieldLayoutItem);        return map;    }}
Any idea of what's wrong?
Tuncay Senturk _Snapbytes_
November 21, 2019 edited
Hi @Angelo Diego Crabolu
Have you tried adding below component-import to atlassian-plugin.xml ?
<component-import key="optionsManager" interface="com.atlassian.jira.issue.customfields.manager.OptionsManager" />
HI, @Tuncay Senturk _Snapbytes_
yes I did and I get a atlassian-plugin.xml contains a definition of component-import. This is not allowed when Atlassian-Plugin-Key is set.
[ERROR]
Ignat May 10, 2022 edited
for me worked this
import com.atlassian.plugin.spring.scanner.annotation.imports.ComponentImport;
import org.springframework.beans.factory.annotation.Autowired;
import javax.inject.Inject;
import javax.inject.Named;
import java.util.logging.Level;
jira.core dependency should be uncommented for this plugin to work
@Named // using @Named instead of @Scanned by Matveev's suggestion
public class MultiSelect2 extends MultiSelectCFType {
use of atlassian logger described it this tutorial
https://developer.atlassian.com/server/jira/platform/writing-jira-event-listeners-with-the-atlassian-event-library/
// private static final Logger log = LoggerFactory.getLogger(MultiSelect2.class);
private final LoggerUtils loggerUtils;
private final java.util.logging.Logger logger;
atlassian tutorial step 4.4 suggests to use @JiraImport annotation for
constructor arguments to import them from host application with atlassian
spring scanner
https://developer.atlassian.com/server/jira/platform/creating-a-custom-field-in-jira/
@Autowired
@Inject
public MultiSelect2(@ComponentImport CustomFieldValuePersister customFieldValuePersister
, @ComponentImport GenericConfigManager genericConfigManager
, @ComponentImport JiraBaseUrls jiraBaseUrls
, @ComponentImport SearchService searchService
, @ComponentImport FeatureManager featureManager
, @ComponentImport JiraAuthenticationContext jiraAuthenticationContext) {
Options manager is acquired trough ComponentAccessor and the rest of
managers trough @ComponentImport annotation of Atlassian Spring Scanner
I do not know what this matters for yet
super(ComponentAccessor.getOptionsManager() // this interface is used to manipulate options. not sure if I need it here
, customFieldValuePersister // This interface is used to save an issue's custom field value to the database
, jiraBaseUrls
, searchService
, featureManager
, jiraAuthenticationContext); // This interface is used to store Generic configuration values for issue's custom field
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
