I'm trying to update a custom field in an issue when it is updated in a linked issue in a different project. Here is what I've set up so far but nothing seems to be happening with I update the fields.
I assume...
...is this correct?
Are there any error messages in the audit log when you test the rule? Do the target issue(s) in NPS show any evidence of an action in the issue history?
The rule should then look like this:
Let us know if this helps!
Ste
@Ste Wright Thanks, actually it was exactly like that, minus one thing. I mistakenly selected for Create Issue in the trigger. which caused it not to run at all. But now its working.
One follow up though, i want to add one more modifier. Only update the date if the trigger date is newer/later than the date its replacing.
Learn more
