Update a custom field during the transition by using script runner.
Raju Anumula May 9, 2019
Hello Team,
1) I need to update the 'Epic Status(type=status of epic)' custom field during the transition. I think it is possible with a script runner, if yes please help me with a script I am not expertized in the script.
2) Clear the custom filed value during the transition?
Thanks in Advance.
Nic Brough -Adaptavist-
May 9, 2019
To update a field, see https://library.adaptavist.com/entity/change-the-value-of-a-custom-field-in-a-post-function  But remember that "status" is not a field, it is a display of the position of an issue in the process.
But, "Epic Status" is usually a field pulled down from the associated Epic, so updating that means updating the Epic, which would affect all the stories the Epic is related to.
Raju Anumula May 9, 2019 edited
Hello @Nic Brough -Adaptavist- ,
Thanks for your quick response.
The code given is not compatible with my version of Jira, we are using Jira version 7.12.3
Register now
