Update cascading fields values based on other field selection
Peter Newton March 30, 2022
Hi
I need to make 3 fields work togeder and I'm having hard times with cascading select update.For this, I'm using scriptrunner - behavior
Maybe someone did it already and can help me with a code
On create issue screen i have 3 fields. Field A, B and C
Field A is a simple single select
Field B and C are cascading select
They are all defined and have values
I need to hide certain values from cascading select fields as follow:
When I select a value in Field A, the values from parent of Field B should be filtered and only some of them should be available for selection. The values from child of Field B should be updated according to parent selection.
Continuing, when I select a value in parent of Field B, the the parent of Field C should be filtered and only some values should be available for selection
Can anyone help with this, please?
