Update custom field when scheduler runs groovy script
Robi Anton
Usually, we run groovy script on workflow's post function.
On my case, I am calling a groovy script each day from a scheduler (Systems-> Services)
On this script I have to update a value of a custom field.
I am able to update a value from a post function, but how to do in this case?
Thanks smile
Thanos Batagiannis [Adaptavist]
April 13, 2016
Hi Robi,
This depends on the type of your custom field, but for a test field should be something like
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def tgtField = customFieldManager.getCustomFieldObjects(issue).find {it.name == "testString"}
if (tgtField) {
	def changeHolder = new DefaultIssueChangeHolder();
	tgtField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(tgtField), "new value"),changeHolder);
Robi Anton
@Thanos Batagiannis [Adaptavist]
I don't want to call my script from my workflow, but from scheduler...
rTrack Support
Hi robi anton,
how u create a new custom field in JIRA with groovy script runner .
can u help on this .
Jozef Kotlár
April 14, 2016
When your script is run from scheduler, there is no proper authentication context (no one is logged in), so you need to replace your code
def user = ComponentAccessor.getJiraAuthenticationContext().getUser().directoryUser
with
def USER_NAME = "jira-automation" // replace with existing user
def user = ComponentAccessor.getUserManager().getUserByName(USER_NAME)?.getDirectoryUser()
Robi Anton
This is my script that I call from my wf postfunction.
When I call it from the scheduler, it fails for the variable user, also for the jquery, etc.
Could someone correct my script ?
The script should be ran by scheduler . Thanks
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.search.SearchException
import com.atlassian.jira.web.bean.PagerFilter
def jqlSearch = "project = 'AISC - Suivi des demandes' and ('Date de livraison' >= startOfMonth(-1) and 'Date de livraison' <=endOfMonth(-1))"
//If you are going to use a JIRA version => 7 then you should get the ApplicationUser instead of User, to do that remove the .directoryUser
def searchService = ComponentAccessor.getComponentOfType(SearchService.class)
SearchService.ParseResult parseResult = searchService.parseQuery(user, jqlSearch)
def value = 0
def myCustomField = customFieldManager.getCustomFieldObjectByName("Temps d'intervention")
if (parseResult.isValid()) {
try {
def results = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
def issues = results.getIssues()
issues.each {
if (it.getCustomFieldValue(myCustomField))
value += it.getCustomFieldValue(myCustomField).toInteger()
} catch (SearchException e) {
e.printStackTrace()
} else {
log.warn("Invalid query")
return null
return value
April 13, 2016
JIRA version ? Also how this script connects to the 'update custom field' question ? Also more information (maybe a screenshot) on the service configuration and any errors in your log files... Help me to help you smile
Robi Anton
My JIRA version is 6.2.6
Script Runner Version: 2.1.16
Maybe my question was not so clear. I will explain properly smile
I want to use the same groovy script that I was using from my workflow (on a transition).
As I want to run it all the first of month, I need to call this script from a scheduler.
What does my script do?
It executes a jqlquery, then for each issue, it calculates a sum of values contained on a custom value.
 Then I update the calculated value on an other custom field.
From a workflow post-function, It works properly, but when I call it form a scheduler, I have some ERRORS.
When I am running the script by the scheduler:
2016-04-14 10:07:06,171 QuartzScheduler_Worker-3 ERROR ServiceRunner Statistiques [onresolve.jira.gr oovy.GroovyRunner] The script failed : javax.script.ScriptException: javax.script.ScriptException: java .lang.NullPointerException: Cannot get property 'directoryUser' on null object
2016-04-14 10:07:06,171 QuartzScheduler_Worker-3 ERROR ServiceRunner Statistiques [onresolve.jira.gr oovy.GroovyService] Script service failed: /app/jira/jira_data/scripts/scriptSommeCourant.groovy
javax.script.ScriptException: javax.script.ScriptException: java.lang.NullPointerException: Cannot get property 'directoryUser' on null object
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:117)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:103)
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:212)
at com.onresolve.jira.groovy.GroovyRunner.runFile(GroovyRunner.java:102)
at com.onresolve.jira.groovy.GroovyRunner.run(GroovyRunner.java:62)
at com.onresolve.jira.groovy.GroovyService.run(GroovyService.java:52)
at com.atlassian.jira.service.JiraServiceContainerImpl.run(JiraServiceContainerImpl.java:61)
at com.atlassian.jira.service.ServiceRunner.execute(ServiceRunner.java:48)
at org.quartz.core.JobRunShell.run(JobRunShell.java:195)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:520)
Caused by: javax.script.ScriptException: java.lang.NullPointerException: Cannot get property 'directory User' on null object
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:318)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:111)
... 9 more
Caused by: java.lang.NullPointerException: Cannot get property 'directoryUser' on null object
at org.codehaus.groovy.runtime.NullObject.getProperty(NullObject.java:56)
at org.codehaus.groovy.runtime.InvokerHelper.getProperty(InvokerHelper.java:156)
at org.codehaus.groovy.runtime.callsite.NullCallSite.getProperty(NullCallSite.java:44)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java: 227)
at Script97.run(Script97.groovy:27)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:315)
... 10 more
For the error of directoryUser, the script search a current user executing the script. But there is no user running this..only the scheduler. I have tried to give the id of variable "user" manually like:
def user = "yk3520:10100"
Second error:
2016-04-14 10:31:06,053 QuartzScheduler_Worker-2 ERROR ServiceRunner Statistiques [onresolve.jira.groovy.GroovyRunner] The script failed : javax.script.ScriptException: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.bc.issue.search.DefaultSearchService.parseQuery() is applicable for argument types: (java.lang.String, java.lang.String) values: [yk3520:10100, project = 'AISC - Suivi des demandes' and ('Date de livraison' >= startOfMonth() and 'Date de livraison' <=now()) and status = Validation]
Possible solutions: parseQuery(com.atlassian.crowd.embedded.api.User, java.lang.String)
2016-04-14 10:31:06,055 QuartzScheduler_Worker-2 ERROR ServiceRunner Statistiques [onresolve.jira.groovy.GroovyService] Script service failed: /app/jira/jira_data/scripts/scriptSommeCourant.groovy
Caused by: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.bc.issue.search.DefaultSearchService.parseQuery() is applicable for argument types: (java.lang.String, java.lang.String) values: [yk3520:10100, project = 'AISC - Suivi des demandes' and ('Date de livraison' >= startOfMonth() and 'Date de livraison' <=now()) and status = Validation]
... 9 more
Caused by: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.bc.issue.search.DefaultSearchService.parseQuery() is applicable for argument types: (java.lang.String, java.lang.String) values: [yk3520:10100, project = 'AISC - Suivi des demandes' and ('Date de livraison' >= startOfMonth() and 'Date de livraison' <=now()) and status = Validation]
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:55)
at org.codehaus.groovy.runtime.callsite.PojoMetaClassSite.call(PojoMetaClassSite.java:46)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120)
at Script96.run(Script96.groovy:30)
... 10 more
For resume:
I want to get a sum of values from custom fields of issues.
The value of this sum should be updated on a another custom field.
 And this script should be ran by a scheduler.
Hope you can help me now smile @Thanos Batagiannis [Adaptavist]
April 14, 2016
Robi,
What Jozef spotted plus the latest part where you should get the custom field of the issue that you want to save the result.
def jqlSearch = "project = 'AISC - Suivi des demandes' and ('Date de livraison' &gt;= startOfMonth(-1) and 'Date de livraison' &lt;=endOfMonth(-1))"
def userManager = ComponentAccessor.getUserManager()
def issueManager = ComponentAccessor.getIssueManager()
def searchService = ComponentAccessor.getComponentOfType(SearchService)
def user = userManager.getUserByName("admin").directoryUser
def value = 0
def myCustomField = customFieldManager.getCustomFieldObjectByName("Number Field")
    try {
        results.getIssues().each { value += it.getCustomFieldValue(myCustomField) ?: 0 }
        e.printStackTrace()
} else {
    return null
// Save the value at custom field with name A number custom field of issue with key TEST-1
def targetIssue = issueManager.getIssueByCurrentKey("TEST-1")
def customField = customFieldManager.getCustomFieldObjects(targetIssue).find {it.name == "A number custom field"}
if (customField) {
    customField.updateValue(null, targetIssue,
            new ModifiedValue(targetIssue.getCustomFieldValue(customField), value),changeHolder)
    log.debug "Custom field $customField.name} updated with value ${value}"
    return
log.warn "Custom field ${customField?.name} was not updated"
Maybe there should be a couple of checks that you should take care (such as if the jql returned any issues) in order to know exactly what went wrong. But the script above is a tested and is a good start.
Robi Anton
Thanks a lot @Thanos Batagiannis [Adaptavist]
It works very well.
As you said, I have to make a couple of checks to run the script.
I had to replace the first if condition my my own script.
Then in the line "new ModifiedValue(targetIssue.getCustomFieldValue(customField), value),changeHolder)", I have to add value.toString().
Here is my script:
import org.apache.log4j.Category
import com.atlassian.jira.issue.util.IssueChangeHolder
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder;
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.issue.*;
import java.sql.Timestamp
Calendar localCalendar = Calendar.getInstance(TimeZone.getDefault());
int currentDay = localCalendar.get(Calendar.DATE);
println currentDay
def jqlSearch = "project = 'AISC - Suivi des demandes' and status was in (Validation) and ('Date de livraison' &gt;= startOfMonth(-1) and 'Date de livraison' &lt;=endOfMonth(-1))"
def user = userManager.getUserByName("yk3520").directoryUser
def value = 0
try {
issues.each {
e.printStackTrace()
} else {
return null
def targetIssue = issueManager.getIssueByCurrentKey("SL-8")
def customField = customFieldManager.getCustomFieldObjects(targetIssue).find {it.name == "Total intervention M-1"}
if (customField) {
            new ModifiedValue(targetIssue.getCustomFieldValue(customField), value.toString()),changeHolder)
    return
Robi Anton
@Jamie Echlin [Adaptavist]
In the above script, I was able to get the value of custom fields. But now, I want to get the values of system fields like "Orignal estimate".
I have tried to change this line :
by
def myCustomField = customFieldManager.getEstimate()
But I have error like:
No signature of method: com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getEstimate() is applicable for
Am I correct?
Or is there other way to do that?
Thanks!!
JamieA
April 19, 2016
issue.estimate
Robi Anton
Could you give me the full line please?
JamieA
April 20, 2016
that was the full line, to get the issue estimate. It's not a custom field, so don't use the custom field manager.
Robi Anton
But how to use it on my script?
It returns a value who is not the original estimated time.
JamieA
April 20, 2016
try issue.originalEstimate
Robi Anton
Thanks a lot, it works! smile
Here is my correction :
try {
issues.each {
if (it.originalEstimate)
//60 beacause it.originalEstimate returns the value in seconds
value += (it.originalEstimate)/60
e.printStackTrace()
} else {
return null
Aleks Yenin (Polontech)
April 13, 2016
Here is script for updating one cf depending on another :
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.customfields.option.Options;
import com.atlassian.jira.issue.customfields.option.Option;
import com.atlassian.jira.issue.ModifiedValue;
import com.atlassian.jira.component.ComponentAccessor;
// Custom field ID's
int sourceCfID = 10101;
int targetCfID = 10102;
// Option ID's of target custom field
int optionFirst = 99998;
int optionSecond = 99999;
CustomFieldManager customFieldManager = ComponentManager.getInstance().getCustomFieldManager();
String sourceCfValue = customFieldManager.getCustomFieldObject(sourceCfID).getValue(issue).toString();
CustomField targetCf = customFieldManager.getCustomFieldObject(targetCfID);
// If value of source custom field is XXX, then select first option, if NOT select second option
// This can be replaced by switch statement if you need to check more options!!!!
int targetCfOption = (sourceCfValue == 'XXX') ? optionFirst : optionSecond;
Options targetCfOptions = ComponentAccessor.getOptionsManager().getOptions(targetCf.getRelevantConfig(issue));
Option ChoosenOption = targetCfOptions.getOptionById(targetCfOption);
targetCf.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValu
Robi Anton
Why source/target??? And I dont have option son my custom field
rTrack Support
Hi robi,
are you updating the custom field values for multi level or single level ?
Register here ⬇️
