Update for JIRA Database Values plugin
David Miralles August 12, 2015
I'm working as a provider for a company who manages their own licences but we are performing the analysis of the upgrade from JIRA 5.2.2 to JIRA 6.4.8. We have checked that the plugin "JIRA Database Values plugin" has no version for JIRA 6.4.8, only to 6.3.15.
Are you working on the supported version for JIRA 6.4.8?
Thank you in advance and best regards.
Wim Deblauwe
August 16, 2015
Hi David,
thanks for testing. I have released version 3.5 on the marketplace: https://marketplace.atlassian.com/plugins/org.deblauwe.jira.plugin.database-values-plugin
regards,
Wim
David Miralles August 14, 2015
Hi Wim,
Thanks for the plugin.
I've installed it in our DEV environment as type 1 add-on without problems.
Moreover, we have checked it in two custom fields which are executing queries via database values plugin and they work properly.
I don't know exactly all the functionalities the plugin includes, Please, provide me some funcionalities to test and I will do it without problems.
David.
Wim Deblauwe
August 13, 2015
There is a test version you can download from http://download.idalko.com/stuff/database-values-plugin-3.5-SNAPSHOT.jar. As soon as somebody tells me that he tested this version and it is ok, I  will release it.
See also https://answers.atlassian.com/questions/15274171
regards,
Wim
Ok, but do you know if this vendor is working on the new version?When this version will be available?
If you don't know this information can you please give me the contact?
Thanks.
michael_ngangom
August 12, 2015
Hello, You can refer the below link for the contact details: https://marketplace.atlassian.com/vendors/21189 They probably should be able to provide the necessary information. Regards, Michael
michael_ngangom
August 12, 2015
As you know JIRA Database Values plug-in is a third party plug-in and it is not supported but you can ask questions about it here. The vendor might be having a better idea of a compatible version release, if that is what you are asking for is.
Get Certified! ✍️
