Update issues through csv file
fabio marcelo
Hi all,
It will be possible update the informations from issues in Jira through csv file ?
I am trying do this , but i only got to create a new issue.
I attached the csv file that i am using .
I want update the values from issue TRA-96.
Please could you help me ?
Bob Swift
October 8, 2012
JIRA Command Line Interface support running CLI actions from csv including create and update. For example, see How to import JIRA issues using CSV
fabio marcelo
Hi Bob,
I installed the CLI here.
Please could you help me to use this comand line interface?
Do you have one example "updating issues" from csv ?
Thanks in Advance
BR
Fabio
Norman Abramovitz
October 8, 2012
Follow the example for import issue, but the action should be updateissue instead of createissue.
https://bobswift.atlassian.net/wiki/display/ACLI/Release+notes+2.1#Releasenotes2.1-RunActionsFromCSVFile
Make sure you read about the parameters for updateissue
Bob Swift
October 9, 2012
Norman answered it. See updateIssue for the parameters.
fabio marcelo
Hi Bob and Norman,
Thanks for the help. I got create and update the issues.
But i cannot update the status from these issues . It will be possible change the status ?
Thanks in Advance
Best Regards
Fabio
Norman Abramovitz
October 9, 2012
Register now
