Update the resolution field in issue on workflow transition
hemanth acharya September 18, 2014
Hi all,
There are two customized workflows defined at the moment. There is a postFunction defined for each of the workflows separately. But, there is a scenario when the transition can happen from one state of workflow1 to another state of workflow2. We cannot set a postfunction for such a transition, but it should happen such that on this particular transition the resolution has to be set to "None". I have to do this in the code itself. Right now am trying with some groovy scripts but it seem not to work, can anyone help me on this scenario.
I had the following groovy which is not serving the purpose. Could anyone please help me?
import com.atlassian.jira.issue.IssueManager;
			import com.atlassian.jira.issue.MutableIssue;
			import com.atlassian.jira.project.Project;
			import com.atlassian.jira.project.ProjectManager;
			import com.atlassian.jira.issue.issuetype.IssueType;
			import com.atlassian.jira.workflow.JiraWorkflow;
			import com.atlassian.jira.component.ComponentAccessor;
			import com.opensymphony.workflow.loader.ActionDescriptor;
			import com.opensymphony.workflow.loader.FunctionDescriptor;
			import webwork.dispatcher.ActionResult;
			import com.atlassian.core.util.map.EasyMap;
			import com.atlassian.core.ofbiz.CoreFactory;
			import com.atlassian.jira.ComponentManager;
			IssueManager issueManager = ComponentAccessor.getIssueManager();
            MutableIssue targetIssue = issueManager.getIssueObject("ALM-1696");
		          ProjectManager projectManager =ComponentAccessor.getProjectManager();
              String tartgetProject=targetIssue.getProjectObject().getKey();
          Project targetProject = projectManager.getProjectObjByKey(tartgetProject);
		            IssueType issueTypeObject=null;
					def issueType = "Bug"
					def Status = "Code/Hardware Bug (Response/Resolution)"
             Collection<IssueType> issueTypes=   ComponentAccessor.getIssueTypeSchemeManager().getIssueTypesForProject(targetProject);
             Iterator itr=issueTypes.iterator();
			//	ComponentManager componentManager = ComponentManager.getInstance()
             //  User remoteUser = componentManager.getJiraAuthenticationContext().getUser()
             while(itr.hasNext()){
                 IssueType projectIssueType=(IssueType)itr.next();
                 if(issueType.equals(projectIssueType.getName()))
                 {issueTypeObject=projectIssueType;
                  break;}
		   JiraWorkflow workflow=ComponentAccessor.getWorkflowManager().getWorkflow(targetProject.getId(), issueTypeObject.getId());
		   Collection<ActionDescriptor> actions = workflow.getAllActions();
		   authenticationContext =ComponentAccessor.getJiraAuthenticationContext()
		    for (final ActionDescriptor actionDescriptor : actions)
            if (actionDescriptor.getName().contains(Status))
             targetIssue.setResolution(null);
            // targetIssue.store();
			// targetIssue.update(ComponentAccessor.getUserManager().getUserObject("some email id"),targetIssue, null,false)
               Map actionParams = EasyMap.build("issue", targetIssue.getGenericValue(), "issueObject", targetIssue, "remoteUser", ComponentAccessor.getUserManager().getUserObject("some email id"), "dispatchEvent", Boolean.FALSE);
               ActionResult aResult = CoreFactory.getActionDispatcher().execute(ActionNames.ISSUE_UPDATE, actionParams);
Hemanth
Jobin Kuruvilla [Adaptavist]
September 18, 2014
Use IssueTransition validateTransition and transition methods. You can set the resolution in IssueInputParameters.
hemanth acharya September 21, 2014
Could you please provide me with a snippet?
September 21, 2014
If you search for samples in this forum or in google, you will find quite a few ;)
hemanth acharya September 23, 2014
I don't know why I typed that comment :P Was too lazy I guess to search. Got it thanks. :)
