×Can someone let me know how to update a issue picker value.
this is what am using which is not working.
def issuepicker= ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Issue Picker")
myIssue.setCustomFieldValue(issuepicker, value)
It kinda depends where you want to execute this script.
Is this a postfunction, listener or somewhere else?
setCustomFieldValue(issuepicker, value) only sets the mutable issue object (in memory) to the specified value. That should normally be followed by updateIssue()
In a listener, to update a custom field, there are 3 general methods that I'm aware of
#1 is preferable because it ensures all validation & permissions are respected. It takes care of logging the change in the issue history and re-indexing the issue. This is closest to replicating the user's action in the UI.
#2 will create the issue history but you must add your own code to update the index
#3 will only update the custom field and leave no trace in the history or index
@PD Sheehan I have achieved it by giving issue object as value
def filterissue = issueManager.getIssueObject(key)
myIssue.setCustomFieldValue(parentICR , filterissue)
Thank you.
