Hi
When importing data from a json to update object in Insight / assets is working as expected for most of the objects.
But when the object to be updated contains an attribute linked to a Jira project, the update fails.
errorMessages=[Agility Support-as-a-Service(TLN-21247): context: rlabs-insight-attribute-461; messages: [ErrorMessage{i18nKey='rlabs.insight.i18n.constraint.violation.ObjectAttributeValueBean.Invalid.Project', parameters=[], additionalMessage=null}]; ]
ObjectTypes : objectTypeResultMap={181=com.riadalabs.jira.plugins.insight.services.imports.common.ImportResult$ObjectTypeResult@654ee18[
errorMessages=[TLN-Organization]
2023-07-17 16:20:02,518 [insight-InsightThreadGroup-worker-thread-56] | Unable to update references on object Agility Support-as-a-Service (TLN-21247), ObjectTypeId: 181, Attributes: (AttributeTypeId: 302, value(s):[-1(Agility Support-as-a-Service)],AttributeTypeId: 310, value(s):[-1(20559)],AttributeTypeId: 314, value(s):[-1(21252)],AttributeTypeId: 311, value(s):[-1(1)],AttributeTypeId: 312, value(s):[-1(Mon May 01 02:00:00 CEST 2023)],AttributeTypeId: 461, value(s):[-1(27000)],AttributeTypeId: 462, value(s):[-1(501951948)]), avatar: false with actions: [] due to validation exception. Check your attribute configuration Error messages: context: rlabs-insight-attribute-461; messages: [ErrorMessage{i18nKey='rlabs.insight.i18n.constraint.violation.ObjectAttributeValueBean.Invalid.Project', parameters=[], additionalMessage=null}];
When removing the attribute to a jira project, the update of the object is working as expected:
Any suggestions?
I can reproduce it on 3 environments.
Jira: v9.4.6
JSM: 5.4.6
Solved by providing the 'browse' permissions, in the projects permissions scheme, for the user that is used to import the data.
