Hi guys!
I am getting this error when trying to upgrade Jira to 8 version. I know about new feature in Jira 8 like issue archieving , but looks like in after upgrade this field not creates in database (MySQL). I use manual method using tar archieve. How to fix It?)
Caused by: org.ofbiz.core.entity.GenericDataSourceException: SQL Exception while executing the following:SELECT pkey, issuenum, PROJECT, REPORTER, ASSIGNEE, CREATOR, issuetype, SUMMARY, DESCRIPTION, ENVIRONMENT, PRIORITY, RESOLUTION, issuestatus, CREATED, UPDATED, DUEDATE, RESOLUTIONDATE, VOTES, WATCHES, TIMEORIGINALESTIMATE, TIMEESTIMATE, TIMESPENT, WORKFLOW_ID, SECURITY, FIXFOR, COMPONENT, ARCHIVED FROM jiraissue WHERE ID=? (Unknown column 'ARCHIVED' in 'field list')
Issue has been resolved. Tmp dir was full on mysql host. Changed mysql configuration to store tmp files on /data directory
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
