Upgrade Jira
Jérôme Brandt October 14, 2013
I'am using JIRA 6.0 on Ubuntu Server. When I launch the ./atlassian-jira-6.1.1-x64.bin I've got this :
Where should JIRA 6.1.1 be installed?
[/opt/atlassian/jira]
It appears that JIRA is already installed in the directory you selected. Please choose a different directory.
I really need to change the directory ?
Retro IT
January 12, 2014
Yeah that screwed me up few times too. Atlassian should really change the install so the bracketed number or letter(s) comes first.
Norman Abramovitz
January 19, 2014
If you just hit the enter(return) key, it will default to upgrade since the install noticed you had an installation already.
Sam Hall
February 12, 2015
+1 I read description then assumed I had to hit 2 to upgrade, got confused, Ctrl+C, repeated the process without reading properly (dofus), googled, face palmed... Something not so user friendly about the layout of the option text.
Christian Czaia [Decadis AG]
October 14, 2013
Have you chosen the install instead of the upgrade option? You should choose to upgrade...
Upgrading JIRA on Linux
  1. Download the appropriate 'JIRA 'Linux 64-bit / 32-bit Installer' (.bin) file that suits your operating system (for the new version of JIRA) from theJIRA Download page.
  2. Open a Linux console and change directory (cd) to the '.bin' file's directory.
    (Warnung)If the '.bin' file is not executable after downloading it, make it executable, for example:
    chmod a+x atlassian-jira-X.Y.bin
    (where X.Y represents your version of JIRA)
  3. Execute the '.bin' file to start the upgrade wizard.
  4. When prompted to choose between creating a new JIRA installation or upgrading an existing installation, choose theUpgrade an existing JIRA installationoption.
https://confluence.atlassian.com/display/JIRA/Upgrading+JIRA+Using+a+Rapid+Upgrade+Method
Cheers
Hi Christian,
I do this.. I choose '2' but the message appears :
Unpacking JRE ...
Starting Installer ...
This will install JIRA 6.1.1 on your computer.
OK [o, Enter], Cancel [c]
o
Choose the appropriate installation or upgrade option.
Please choose one of the following:
Express Install (use default settings) [1], Custom Install (recommended for advanced users) [2], Upgrade an existing JIRA installation [3, Enter]
2
October 14, 2013
You have to choose 3!!!
1= express install
2= custom install
3=upgrade
Like • marcelorodcla likes this
Ahhhh! I will try asap!! Thanks... and sorry :/
Petr Cervenka
October 17, 2019
Had same issue! OMG 3 it is!
No, I don't...
