Upgrade from 6.4
Juby John October 13, 2017 edited
Does 7.0.0 version have sub versions like 7.0.2, 7.0.4, 7.0.10? Which version of 7.0.0 should we move to if we are upgrading Jira from 6.4. I mean which one is preferable.
Nic Brough -Adaptavist-
October 13, 2017
No, they're not "sub versions", they are separate versions.
7.0.0 is one distinct version.  7.0.1 is the next version.  7.0.2 next, and so-on.  These numbers are usually talked about in terms of "major", "minor" and "point" releases.
A major release usually represents a massive structural change (or a major rebranding exercise in some software).  A minor release is usually some improvements, new functionality and often changes to existing functions.  A point release is very rarely anything more than bug fixes or minor enhancements that don't change the shape of the database or functionality.
As a general rule, you should choose the latest point release for the major.minor version you choose.
In your case, you should upgrade to 7.0.latest, then, as that's out of support, make a choice to go to 7.4 or 7.5 (again, use the latest point release)
Thanks Nic
Jobin Kuruvilla [Adaptavist]
October 13, 2017
Thanks Jobin.
