Upgrade from JIRA 6.2 to JIRA Latest version 7
Eda Prasad April 19, 2017
Am planning to Upgrade from JIRA 6.2 to JIRA Latest version 7.x
The previous version is JIRA Software v6.2 + JIRA Agile v6.6.13 so from this am planning to upgrade new version 7.x
Can I upgrade directly from v6.2 to v7.x
Please let me know your inputs on the same?
Nic Brough -Adaptavist-
April 19, 2017
I would not recommend it.  It might work, but I've had lots of problems.
A better option would be to upgrade to 7.0, then 7.latest, but that can still be flaky.
The best option is to upgrade to 6.4.latest in full, then jump to 7.latest.
The supported route is 6.4, 7.0, 7.latest.  But generally 6.4 to 7.3 seems to be working fine on the times I've done it.
Eda Prasad April 19, 2017 edited
Thank You Nic.
Eda Prasad April 24, 2017
@Nic Brough [Adaptavist]:
As we discussed earlier from 6.2 to 7 is not possible so I have installed 6.4.14 version with java v1.8
Now I have created one new server, installed java 1.8 and JIRA v6.4.14
But while restoring the data from v6.2 to 6.4 throwing errors Nic.
Prasad
Please find the logs while restoring the Jira v6.2 to 6.4.
Technical details
Log's referral number: 31fbea8b-57e8-443f-9d32-32805e1a9222
Cause:
Referer URL:
java.lang.RuntimeException: org.apache.jasper.JasperException: An exception occurred processing JSP page /includes/decorators/aui-layout/head-resources.jsp at line 13
10:     HeaderFooterRendering headerAndFooter = ComponentAccessor.getComponent(HeaderFooterRendering.class);
11:
12:     headerAndFooter.requireCommonResources();
13:     headerAndFooter.includeResources(out);
14: %>
15: <script type="text/javascript" src="<%=headerAndFooter.getKeyboardShortCutScript(request) %>"></script>
16: <%
Stacktrace:
11:
14: %>
16: <%
Stacktrace:
        at com.opensymphony.sitemesh.webapp.decorator.BaseWebAppDecorator.render(BaseWebAppDecorator.java:37)
        at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:92)
        at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
        at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(PageBuilderFilter.java:90)
        at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(CommittedResponseHtmlErrorRecoveryFilter.java:63)
        at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
        at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70)
        at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
        at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78)
        at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
        at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
        at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
        at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239)
        at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
        at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172)
        at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
        at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79)
        at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
        at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
        at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
        at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
        at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
        at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
        at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
        at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40)
        at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
        at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
        at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
        at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
        at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
        at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
        at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79)
        at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
        at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:61)
        at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:115)
        at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:92)
        at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:56)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
        at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
        at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.jasper.JasperException: An exception occurred processing JSP page /includes/decorators/aui-layout/head-resources.jsp at line 13
11:
14: %>
16: <%
Stacktrace:
        at org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:568)
        at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:470)
        at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
        at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
        at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:748)
        at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:604)
        at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:543)
        at com.opensymphony.sitemesh.compatability.OldDecorator2NewDecorator.render(OldDecorator2NewDecorator.java:46)
        at com.opensymphony.sitemesh.webapp.decorator.BaseWebAppDecorator.render(BaseWebAppDecorator.java:33)
        ... 112 more
Caused by: com.atlassian.activeobjects.internal.ActiveObjectsSqlException: There was a SQL exception thrown by the Active Objects library:
Database:
        - name:MySQL
        - version:5.6.24-enterprise-commercial-advanced
        - minor version:6
        - major version:5
Driver:
        - name:MySQL Connector Java
        - version:mysql-connector-java-5.1.41 ( Revision: 83c6dc41b96809df81444362933043b20a1d49d5 )
com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'jiratestdb.AO_60DB71_RAPIDVIEW' doesn't exist
        at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.count(EntityManagedActiveObjects.java:269)
        at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects.count(TenantAwareActiveObjects.java:377)
        at sun.reflect.GeneratedMethodAccessor638.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:497)
        at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
        at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
        at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
        at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
        at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
        at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
        at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
        at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
        at com.sun.proxy.$Proxy7697.count(Unknown Source)
        at com.atlassian.greenhopper.service.rapid.view.RapidViewDao.countBySprintMarkersMigrated(RapidViewDao.java:122)
        at com.atlassian.greenhopper.service.migration.sprintmarker.SprintMarkerMigrationHelper.countUnmigratedRapidViews(SprintMarkerMigrationHelper.java:160)
        at com.atlassian.greenhopper.sprintmigration.SprintMigrationBannerPreferencesImpl.hasNonMigratedBoards(SprintMigrationBannerPreferencesImpl.java:57)
        at com.atlassian.greenhopper.sprintmigration.SprintMigrationBannerPreferencesImpl.shouldDisplayBanner(SprintMigrationBannerPreferencesImpl.java:52)
        at com.atlassian.greenhopper.web.condition.UrlReadingSprintMigrationBannerCondition.addToUrl(UrlReadingSprintMigrationBannerCondition.java:32)
        at com.atlassian.plugin.webresource.condition.DecoratingUrlReadingCondition.addToUrl(DecoratingUrlReadingCondition.java:31)
        at com.atlassian.plugin.webresource.WebResourceModuleDescriptor.addToUrl(WebResourceModuleDescriptor.java:207)
        at com.atlassian.plugin.webresource.url.DefaultUrlBuilderMap.getOrCreateForType(DefaultUrlBuilderMap.java:57)
        at com.atlassian.plugin.webresource.PluginResourceLocatorImpl.getPluginResources(PluginResourceLocatorImpl.java:243)
        at com.atlassian.plugin.webresource.ContextBatchBuilder$WebResourceKeysToContextBatches.create(ContextBatchBuilder.java:279)
        at com.atlassian.plugin.webresource.ContextBatchBuilder.buildBatched(ContextBatchBuilder.java:81)
        at com.atlassian.plugin.webresource.ContextBatchBuilder.build(ContextBatchBuilder.java:61)
        at com.atlassian.plugin.webresource.assembler.DefaultWebResourceAssembler$ResourceRequirer.addContextBatchDependencies(DefaultWebResourceAssembler.java:321)
        at com.atlassian.plugin.webresource.assembler.DefaultWebResourceAssembler$ResourceRequirer.includeResources(DefaultWebResourceAssembler.java:279)
        at com.atlassian.plugin.webresource.assembler.DefaultWebResourceAssembler$ResourceRequirer.access$1300(DefaultWebResourceAssembler.java:236)
        at com.atlassian.plugin.webresource.assembler.DefaultWebResourceAssembler$DefaultAssembledResources.drainIncludedResources(DefaultWebResourceAssembler.java:217)
        at com.atlassian.jira.plugin.navigation.HeaderFooterRendering.includeResources(HeaderFooterRendering.java:100)
        at org.apache.jsp.decorators.admin_jsp._jspService(admin_jsp.java:297)
        at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
        at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432)
        ... 142 more
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'jiratestdb.AO_60DB71_RAPIDVIEW' doesn't exist
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
        at com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
        at com.mysql.jdbc.Util.getInstance(Util.java:408)
        at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:943)
        at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3973)
        at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3909)
        at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2527)
        at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2680)
        at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2501)
        at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1858)
        at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1966)
        at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
        at net.java.ao.EntityManager.count(EntityManager.java:976)
        at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.count(EntityManagedActiveObjects.java:265)
        ... 184 more
Help us plant more trees
