Upgraded successfully, altered server.xml to reflect ajp-connection
Did not work entirely...
Oops - an error has occurred
System Error
A system error has occurred.
If this problem persists, please contact your JIRA administrators.
Otherwise, please create a support issue on our support system at http://support.atlassian.com with the following information:
a description of your problem
cut & paste the error and system information found below
Cause:
java.lang.RuntimeException: org.apache.jasper.JasperException: An exception occurred processing JSP page /includes/decorators/aui-layout/header.jsp at line 42 39: PluggableTopNavigation pluggableTopNavigation = topNavModuleDescriptor.getModule(); 40: 41: %> 42: <%= pluggableTopNavigation.getHtml(request) %> 43: <% } %> Stacktrace:
Stack Trace: hide
40:
41: %>
43: <% } %>
Stacktrace:
at com.opensymphony.sitemesh.webapp.decorator.BaseWebAppDecorator.render(BaseWebAppDecorator.java:39)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:84)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.labs.remoteapps.modules.permissions.ApiScopingFilter.doFilter(ApiScopingFilter.java:71)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:234)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:157)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:738)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.atlassian.labs.remoteapps.modules.oauth.OAuth2LOFilter.doFilter(OAuth2LOFilter.java:70)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:78)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463)
at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:75)
at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:554)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Unknown Source)
Referer URL: Unknown
Build Information:
Uptime : N/A
Version : 5.1.1
Build Number : 772
Build Date : Tue Jul 17 00:00:00 CEST 2012
Build Revision : c73db67d5b7b5c0c6559cdfee76905e8ca1a63cb
Atlassian Partner : null
Installation Type : Standalone
Server ID : Contact your Administrator to discover this property value.
Last Upgrade : 20/Aug/12 14:07 (v4.4.3#663)
Server Information:
Application Server: Apache Tomcat/6.0.32
Servlet Version: 2.5
File Paths:
Contact your System Administrator to discover file path information.
Memory Information:
Total Memory: 2730 MB
Free Memory: 2048 MB
Used Memory: 682 MB
Total PermGen Memory: 256 MB
Free PermGen Memory: 126 MB
Used PermGen Memory: 129 MB
System Information:
System Date : Monday, 20 Aug 2012
System Time : 14:30:41 +0200
Current Working Directory : Contact your System Administrator to discover this property value.
Java Version : 1.6.0_26
Java Vendor : Sun Microsystems Inc.
JVM Version : 1.0
JVM Vendor : Sun Microsystems Inc.
JVM Implementation Version : 20.1-b02
Java Runtime : Java(TM) SE Runtime Environment
Java VM : Java HotSpot(TM) 64-Bit Server VM
User Name : root
User Timezone : Europe/Stockholm
User Locale : English (United States)
System Encoding : UTF-8
Operating System : Linux 2.6.38-11-server
OS Architecture : amd64
Application Server Container :
Database type : mysql
Database JNDI address : mysql jdbc:mysql://localhost/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB
Database URL : Hidden
Database version : 5.1.54-1ubuntu4
Database driver : MySQL-AB JDBC Driver mysql-connector-java-5.1.10 ( Revision: ${svn.Revision} )
External user management : OFF
JVM Input Arguments : Contact your System Administrator to discover this property value.
Language Info:
Installed languages: English (UK)
French (France)
German (Germany)
Japanese (Japan)
Spanish (Spain)
Default language: English (United States) - System Default
Request Information:
- Request URL: https://www.navetti.com/jira/500page.jsp
- Scheme: https
- Server: www.navetti.com
- Port: 443
- URI: /jira/500page.jsp
- Context Path: /jira
- - Servlet Path: /500page.jsp
- - Path Info: null
- - Query String:
Request Attributes
- javax.servlet.forward.request_uri : /jira/secure/Dashboard.jspa
- javax.servlet.forward.context_path : /jira
- javax.servlet.forward.servlet_path : /secure/Dashboard.jspa
- javax.servlet.forward.path_info : /500page.jsp
- os_securityfilter_already_filtered : true
- com.atlassian.jira.web.filters.JiraPostEncodingFilter_alreadyfiltered : true
- jira.session.max.inactive.interval : 18000
- com.newrelic.agent.TRANSACTION_NAME : /*.jspa
- jira.request.time.micros : 2
- atlassian.core.seraph.original.url : /secure/Dashboard.jspa
- javax.servlet.error.servlet_name : action
- com.opensymphony.sitemesh.USINGSTREAM : false
- com.atlassian.jira.web.filters.JiraFirstFilter_alreadyfiltered : true
- com.atlassian.gzipfilter.GzipFilter_already_filtered : true
- loginfilter.already.filtered : true
- com.atlassian.johnson.filters.JohnsonFilter_already_filtered : true
- jira.webwork.generic.dispatcher : webwork.dispatcher.GenericDispatcher@610c2607
- com.atlassian.jira.web.filters.JiraLastFilter_alreadyfiltered : true
- com.atlassian.jira.web.filters.accesslog.AccessLogFilter_already_filtered : true
- javax.servlet.error.message :
- jira.session.last.accessed.time : 1345465836737
- webwork.result : Value stack =========== ===========
- webwork.request_uri : /jira/secure/Dashboard.jspa
- javax.servlet.error.request_uri : /jira/secure/Dashboard.jspa
- com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter_already_filtered : true
- jira.selected.section : home_link
- webwork.valuestack.head : com.atlassian.jira.web.action.Dashboard@6494c757
- com.atlassian.jira.timezone.TimeZoneServiceCachingDecorator#userTimeZone : TimeZoneInfoImpl{Europe/Stockholm}
- jira.webwork.cleanup : false
- jira.request.id : 870x3x1
- javax.servlet.error.status_code : 500
- com.atlassian.labs.botkiller.BotKillerFilter : true
- jira.request.start.millis : 1345465837004
- com.atlassian.jira.web.filters.accesslog.AccessLogRequestInfoexit.called : true
- com.opensymphony.sitemesh.APPLIED_ONCE : true
- com.atlassian.core.filters.HeaderSanitisingFilter_already_filtered : true
- webwork.view_uri : /secure/views/dashboard.jsp
- helpUtil : com.atlassian.jira.web.util.HelpUtil@63ab5457
- jira.request.assession.id : 1a7kqd7
- javax.servlet.error.exception : java.lang.RuntimeException: org.apache.jasper.JasperException: An exception occurred processing JSP page /includes/decorators/aui-layout/header.jsp at line 42 39: PluggableTopNavigation pluggableTopNavigation = topNavModuleDescriptor.getModule(); 40: 41: %> 42: <%= pluggableTopNavigation.getHtml(request) %> 43: <% } %> Stacktrace:
Request Logging
0 log statements generated by this request:
Listeners
- Issue Assignment Listener (com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener)
- Issue Index Listener (com.atlassian.jira.event.listeners.search.IssueIndexListener)
- Mail Listener (com.atlassian.jira.event.listeners.mail.MailListener)
Services
- Backup Service (com.atlassian.jira.service.services.export.ExportService)
- Delay: 600 minutes
- Create/Comment Service (com.atlassian.jira.service.services.mail.MailFetcherService)
- Delay: 1 minutes
- Mail Queue Service (com.atlassian.jira.service.services.mail.MailQueueService)
- Delay: 1 minutes
- NotificationCacheUpdateJob-job (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 1440 minutes
- PluginLicenseExpiryJob-job (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Service Provider Session Remover (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 480 minutes
- Service Provider Token Remover (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 1 minutes
- com.atlassian.streams.internal.ActivityProviderConnectionMonitorImpl:activityProviderMonitor (com.atlassian.sal.jira.scheduling.JiraPluginSchedulerService)
- Delay: 15 minutes
Plugins
- ActiveObjects Plugin - OSGi Bundle 0.19.7 - Plugin by Atlassian
- Enabled
- Admin Menu Sections 1.0 - Plugin by Atlassian
- Enabled
- Apache HttpClient OSGi bundle 4.0 - Plugin by Apache Software Foundation
- Enabled
- Apache HttpCore OSGi bundle 4.0 - Plugin by Apache Software Foundation
- Enabled
- Applinks Product Plugin 3.7.3 - Plugin by Atlassian
- Enabled
- build: 10
- Atlassian - Administration - Quick Search - JIRA 1.0 - Plugin by Atlassian
- Enabled
- Atlassian Bonfire - JIRA 4.x Plugin 1.3.2 - Plugin by Atlassian
- Enabled
- Atlassian Bot Session Killer 1.7.1 - Plugin by Atlassian
- Enabled
- Atlassian Embedded Crowd - Administration Plugin 1.4.3 - Plugin by Atlassian
- Enabled
- Atlassian Gadgets OAuth Service Provider Plugin 3.2.0-m2 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Admin Summary Component 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Application Properties 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Closure Template Renderer 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Common AppLinks Based Issue Link Plugin 5.1.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - Confluence Link 5.1.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - Gadgets Plugin 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Header Plugin 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Invite User 1.5 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Issue Navigation 1.0.36 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Issue Web Link 5.1.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - Look And Feel Logo Upload Plugin 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Mail Plugin 5.1.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - My JIRA Home 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - OAuth Consumer SPI 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - OAuth Service Provider SPI 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Project Config Plugin 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Quick Edit Plugin 1.0.42 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - REST Plugin 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - Remote JIRA Link 5.1.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian JIRA - Plugins - SAL Plugin 5.1.1 - Plugin by Atlassian Software Systems
- Enabled
- Atlassian JIRA - Plugins - Share Content Component 5.1.1 - Plugin by Atlassian
- Enabled
- Atlassian JIRA - Plugins - View Issue Panels 5.1.1 - Plugin by ${project.organization.name}
- Enabled
- Atlassian OAuth Admin Plugin 1.4.1 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Consumer Plugin 1.4.1 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Consumer SPI 1.4.1 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Service Provider Plugin 1.4.1 - Plugin by Atlassian
- Enabled
- Atlassian OAuth Service Provider SPI 1.4.1 - Plugin by Atlassian
- Enabled
- Atlassian REST - Module Types 2.6.5.1 - Plugin by Atlassian
- Enabled
- Atlassian Remote Apps - Plugin 0.4.490 - Plugin by Atlassian
- Enabled
- Atlassian Soy Templates - Plugin 1.1.3 - Plugin by Atlassian
- Enabled
- Atlassian Template Renderer API 1.4.2 - Plugin by Atlassian
- Enabled
- Atlassian Template Renderer Velocity 1.6 Plugin 1.4.2 - Plugin by Atlassian
- Enabled
- Atlassian UI Plugin 3.7-m6 - Plugin by Atlassian
- Enabled
- Atlassian Universal Plugin Manager Plugin 2.1.5 - Plugin by Atlassian Pty Ltd
- Enabled
- Content Link Resolvers Plugin 1.0 - Plugin by Atlassian
- Enabled
- Crowd REST API 1.0 - Plugin by Atlassian Software Systems
- Enabled
- Enabled
- Crowd System Password Encoders 1.0 - Plugin by Atlassian Software Systems
- Enabled
- Custom Field Types & Searchers 1.0 - Plugin by Atlassian
- Enabled
- Embedded Gadgets Plugin 3.2.0-m2 - Plugin by Atlassian
- Enabled
- English (United Kingdom) Language Pack 5.1.1 - Plugin by Atlassian
- Enabled
- English (United States) Language Pack 5.1.1 - Plugin by Atlassian
- Enabled
- FishEye Plugin 5.0.4.1 - Plugin by Atlassian Software Systems
- Enabled
- Gadget Dashboard Plugin 3.2.0-m2 - Plugin by Atlassian
- Enabled
- Gadget Directory Plugin 3.2.0-m2 - Plugin by Atlassian
- Enabled
- Gadget Spec Publisher Plugin 3.2.0-m2 - Plugin by Atlassian
- Enabled
- GreenHopper 5.8 - Plugin by Atlassian
- Disabled
- HipChat 1.1.7 - Plugin by Atlassian
- Enabled
- ICU4J 3.8.0.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Issue Operations Plugin 1.0 - Plugin by Atlassian
- Enabled
- Issue Tab Panels Plugin 1.0 - Plugin by Atlassian
- Enabled
- Issue Views Plugin 1.0 - Plugin by Atlassian
- Enabled
- JDOM DOM Processor 1.0.0 - Plugin by SpringSource
- Enabled
- JIRA Active Objects SPI implementation 0.19.7 - Plugin by Atlassian Software Systems
- Enabled
- JIRA Activity Stream Plugin 5.1.4 - Plugin by Atlassian
- Enabled
- JIRA Bamboo Plugin 5.0 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- configure.url: /secure/admin/jira/ViewBambooApplicationLinks.jspa
- JIRA Drag and Drop Attachment Plugin 2.8.2 - Plugin by Atlassian Pty Ltd.
- Enabled
- JIRA Footer 1.0 - Plugin by Atlassian
- Enabled
- JIRA French (France) Language Pack 5.1.0-rc3-v2r2020-2012-07-03 - Plugin by Atlassian Community
- Enabled
- JIRA German (Germany) Language Pack 5.1.0-rc3-v2r5195-2012-07-05 - Plugin by Atlassian Community
- Enabled
- JIRA Importers Plugin (JIM) 4.3.2 - Plugin by Atlassian
- Disabled
- JIRA Issue Collector Plugin 1.1 - Plugin by Atlassian
- Enabled
- JIRA JSON-RPC Plugin 1.0.4 - Plugin by Atlassian Software
- Enabled
- JIRA Japanese (Japan) Language Pack 5.1.0-rc3-v2r12502-2012-07-03 - Plugin by Atlassian Community
- Enabled
- JIRA Monitoring Plugin 05.5 - Plugin by Atlassian
- Enabled
- JIRA Spanish (Spain) Language Pack 5.1.0-rc3-v2r11451-2012-06-28 - Plugin by Atlassian Community
- Enabled
- JIRA Streams Inline Actions Plugin 5.1.4 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- JIRA Time Zone Detection plugin 1.5 - Plugin by Atlassian
- Enabled
- JIRA Usage Hints 1.0 - Plugin by Atlassian
- Enabled
- JIRA Welcome Plugin 1.1.10 - Plugin by Atlassian
- Enabled
- JIRA iCalendar Plugin 1.0.8 - Plugin by Atlassian
- Enabled
- JQL Functions 1.0 - Plugin by Atlassian
- Enabled
- JSON Library 20070829.0.0.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Keyboard Shortcuts Plugin 1.0 - Plugin by Atlassian
- Enabled
- Neko HTML 1.9.12.1 - Plugin by Atlassian Pty Ltd
- Enabled
- Opensocial Plugin 3.2.0-m2 - Plugin by Atlassian
- Enabled
- Preset Filters Sections 1.0 - Plugin by Atlassian
- Enabled
- Project Panels Plugin 1.0 - Plugin by Atlassian
- Enabled
- Project Role Actors Plugin 1.0 - Plugin by Atlassian
- Enabled
- RMsis 1.5.1 - Plugin by Optimizory
- Enabled
- vendor-logo: includes/images/optimizory-logo-130x47.jpg
- plugin-icon: includes/images/rmsis-icon-16x16.png
- plugin-logo: includes/images/rmsis-logo-75x75.png
- vendor-icon: includes/images/optimizory-icon-16x16.png
- ROME, RSS and atOM utilitiEs for Java 1.0 - Plugin by Sun Microsystems
- Enabled
- ROME: RSS/Atom syndication and publishing tools 0.9.0 - Plugin by SpringSource
- Enabled
- RPC JIRA Plugin 5.0.5 - Plugin by Atlassian
- Enabled
- Renderer Component Factories Plugin 1.0 - Plugin by Atlassian
- Enabled
- Renderer Plugin 1.0 - Plugin by Atlassian
- Enabled
- Reports Plugin 1.0 - Plugin by Atlassian
- Enabled
- Streams API 5.1.4 - Plugin by Atlassian
- Enabled
- Streams Core Plugin 5.1.4 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- Streams Inline Actions Plugin 5.1.4 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- Streams Plugin 5.1.4 - Plugin by Atlassian Software Systems Pty Ltd
- Enabled
- Streams SPI 5.1.4 - Plugin by Atlassian
- Enabled
- Streams Third Party Provider Plugin 5.1.4 - Plugin by Atlassian
- Enabled
- Support Tools Plugin 3.0.8 - Plugin by Atlassian Support
- Enabled
- Top Navigation Bar 1.0 - Plugin by Atlassian
- Enabled
- User Format 1.0 - Plugin by Atlassian
- Enabled
- User Navigation Bar Sections 1.0 - Plugin by Atlassian
- Enabled
- User Profile Links 1.0 - Plugin by Atlassian
- Enabled
- User Profile Panels 1.0 - Plugin by Atlassian
- Enabled
- View Project Operations Sections 1.0 - Plugin by Atlassian
- Enabled
- Web Resources Plugin 1.0 - Plugin by Atlassian
- Enabled
- Webwork Plugin 1.0 - Plugin by Atlassian
- Enabled
- Wiki Renderer Macros Plugin 1.0 - Plugin by Atlassian
- Enabled
- Workflow Designer Plugin 2.6.2 - Plugin by Atlassian
- Enabled
- Workflow Plugin 1.0 - Plugin by Atlassian
- Enabled
- jira-help-tips 0.22 - Plugin by Atlassian
- Enabled
Incompatible Bonfire plugin version break JIRA. Remove Bonfire plugin and reinstall the latest version of Bonfire.
Hi Niklas,
Based on the main error "org.apache.jasper.JasperException" maybe this JIRA Knowledge Base can give a hand in troubleshooting it.
Kind Regards
