Upgrading JIRA6.0.6->JIRA6.3.7 fails
Denys Kovalenko
October 28, 2014
Exception during upgrade process:
Exception thrown during upgrade: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:GlobalPermissionEntry][group_id,jira-users][permission,USER_PICKER][id,10000] (SQL Exception while executing the following:INSERT INTO globalpermissionentry (ID, PERMISSION, GROUP_ID) VALUES (?, ?, ?) (Duplicate entry '10000' for key 'PRIMARY'))
com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:GlobalPermissionEntry][group_id,jira-users][permission,USER_PICKER][id,10000] (SQL Exception while executing the following:INSERT INTO globalpermissionentry (ID, PERMISSION, GROUP_ID) VALUES (?, ?, ?) (Duplicate entry '10000' for key 'PRIMARY'))
	at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.createValue(DefaultOfBizDelegator.java:397)
	at com.atlassian.jira.ofbiz.WrappingOfBizDelegator.createValue(WrappingOfBizDelegator.java:219)
	at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build6304.migrateValue(UpgradeTask_Build6304.java:104)
	at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build6304.doUpgrade(UpgradeTask_Build6304.java:90)
	at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeTaskSuccess(UpgradeManagerImpl.java:693)
	at com.atlassian.jira.upgrade.UpgradeManagerImpl.runUpgradeTasks(UpgradeManagerImpl.java:542)
	at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgrade(UpgradeManagerImpl.java:471)
	at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeeded(UpgradeManagerImpl.java:413)
	at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeededAndAllowed(UpgradeManagerImpl.java:348)
	at com.atlassian.jira.upgrade.UpgradeLauncher.checkIfUpgradeNeeded(UpgradeLauncher.java:106)
	at com.atlassian.jira.upgrade.UpgradeLauncher.start(UpgradeLauncher.java:54)
	at com.atlassian.jira.startup.ActiveServicesLauncher.start(ActiveServicesLauncher.java:42)
	at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:137)
	at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:324)
	at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:214)
	at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:118)
	at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:32)
	at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:81)
	at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:34)
	at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:76)
	at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:71)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4992)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5490)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1575)
	at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1565)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:GlobalPermissionEntry][group_id,jira-users][permission,USER_PICKER][id,10000] (SQL Exception while executing the following:INSERT INTO globalpermissionentry (ID, PERMISSION, GROUP_ID) VALUES (?, ?, ?) (Duplicate entry '10000' for key 'PRIMARY'))
	at org.ofbiz.core.entity.GenericDAO.singleInsert(GenericDAO.java:200)
	at org.ofbiz.core.entity.GenericDAO.insert(GenericDAO.java:165)
	at org.ofbiz.core.entity.GenericHelperDAO.create(GenericHelperDAO.java:83)
	at org.ofbiz.core.entity.GenericDelegator.create(GenericDelegator.java:554)
	at org.ofbiz.core.entity.GenericDelegator.create(GenericDelegator.java:540)
	at org.ofbiz.core.entity.GenericValue.create(GenericValue.java:98)
	at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.createValue(DefaultOfBizDelegator.java:392)
	... 29 more
Denys Kovalenko
November 12, 2014
It seems like i was experiencing a problem with database integrity.
Fixed by re-deploying dev environment.
twong_atlassian
November 3, 2014
Denys: I'd recommend contacting support- this might be a database integrity issue and they'll probably need to analyze your backup.
Denys Kovalenko
November 3, 2014
Is there any ideas how to fix that issue during upgrade process?
Register today
