Hi Goutham
Upgrading from JIRA 5.1.5 to 5.1.6 is pretty straight-forward. Basically, you can use the rapid upgrade method by downloading the installer version of JIRA and select Upgrade an existing JIRA installation option and the remaining steps should be quite straight-forward.
However, always test the upgrade process in the testing environment first and make sure you backup everything (JIRA installation directory, JIRA Home directory, JIRA database dump).
Hopefully it helps!
Cheers :)
Please read the https://confluence.atlassian.com/display/JIRA/Upgrading+JIRA and tell us if you get stuck there.
