Upgrading from 5.1.6 to 5.2.9
DeepakBhatia
We have exported the database of JIRA 5.1.6 installation as entities.xml file and imported the same in JIRA 5.2.9. But we are getting error TaskWorkFlow has two drafts and the import crashed.
But if we see the table draftworkflowschemeentity in mysql, it doesn't have any entry.
Elvir Hadzic
May 14, 2013
Hello Deepak
There's a difference between workflows and workflow schemes. Maybe that's the missunderstanding. Can you try to check the table jiradraftworkflows?
Please let me know if this helps, so I can try to assist you further in case it won't solve the problem.
Register now
