We are looking to upgrade our Jira Datacenter version from 9.4.14 to 9.12.19 (latest LTS version). Have a couple of quick questions as we prepare for the upgrade.
OS - Server 2019
Database - SQL Server 2017
1. Type of install - Previous sys admin used manual install. Any benefit or pro/cons with doing manual over using the installer?
2. Java version is currently Java 8. What is the requirement for Java version at 9.12.19?
3. "Plan Your Upgrade" feature within Jira recommends 9.11. Any issue going further to the latest LTS of 9.12.19?
4. Log4J upgrade? I believe Log4J2 is a requirement at this point? Are there good instructions for this process? Anything to be prepared for and should I do this ahead of upgrade?
5. Utilize LDAP auth, but looking to move to Okta. Any need for changes before upgrade?
6. Backups - We have a test env to run this through before Prod. Anything outside of Jira directory and database backups to be considered?
7. Scriptrunner workflows - I'm assuming if changing Java versions the scriptrunner scripts will need to be updated. Any feedback here would be appreciated!
I believe that's all for now. I appreciate any feedback and guidance.
Thank you!
Firstly, check into what is stopping you doing a migration to Jira Cloud. It's where Jira is going eventually. Lots of people who can help with all of this at https://partnerdirectory.atlassian.com/
No great advantage one way or the other. Either way you will need to look at changes in the bin directory files to see if things have changed there in the latest version
See https://confluence.atlassian.com/adminjiraserver0912/supported-platforms-1346046805.html
I would go for Java 17 myself
I recommend using the latest LTS version, but check that all your plugins support that version before upgrading
I don't think you should need to do anything explicit here?
Make sure you record all the SSO info before you start the upgrade. You will need to log in with a locally defined admin user to reconfigure those settings after the upgrade
Check your Sys Info page for all modified files and record why they were changed
Upgrade your plugins to their latest compatible version and test those carefully too
Disable all notifications scheme in all projects in the test instance to avoid confusing emails
Change the color of the top bar in your test instance so people don't get confused
No, I don't think that changing Java versions will affect this, since the scripts are Groovy. Updating the version of ScriptRunner may do so though
Disclaimer: I work for Adaptavist, makers of ScriptRunner and one of the Atlassian partners who can help with migrations and upgrades, but am not part of those teams
These are all great points for doing a Jira upgrade!
I can elaborate on what we do for our data centre version upgrades.
I hope these points help - feel free to ask any follow up questions.
Thank you all for super quick and helpful feedback! Some basic questions but a good start in planning out my approach.
Register now
