Upgrading from Jira 4.4.1 to Jira 4.4.5
Fr0zt
Hello.
A couple of days ago I performed an upgrade from Jira 4.4.1 to Jira 4.4.5.
My Jira is using MyQSL 5.5.
I created the database with the following command (as referred in the documentation):
create database jiradb character set utf8;
(DOcumentation: create database jiradb character set utf8;).
When I run the Jira 4.4.5 Installer I get this message: "Upgrade Check List. Backup your external database: Your Jira database will be incompatible with your existing Jira Version..."
In here I choose next and I was able to make the upgrade successfully.
I don't understand why did i got this message. Is this only a reminder to check database compatibility?
What does this mean?
Mohamed Riza
September 17, 2018
Hi @Fr0zt
These are checklist items.
The first one, which you have quoted, asks you to backup the Jira database before upgrading. This is because during an upgrade, there installer makes changes to the database of Jira. However, in case you need to role back to the previous version of Jira, then you cannot use this database anymore because of the changes made. Therefore you will be a backed up copy to roll back.
This is just a precautionary measure. We highly recommend this.
Fr0zt
I see.
So this doesn't necessarily means that my database is not compatible with my Jira, right?
Keri
September 25, 2018
You're correct.  The message is a little misleading - it's not that the database version or configuration which is incompatible - it's that after the upgrade, the data will have been upgrades and the data will be incompatible with the old version Jira.
Get Certified! ✍️
