We have deployed Jira Data Center on our server behind the proxy.
But we have a problem is upload file too slow
Example: 15MB with 30 minutes not complete.
I think it is proxy but not sure.
I hope everyone give me more advice and information we need to fix that.
Hi
If bypassing the reverse proxy and directly accessing the server node for uploading, is the speed normal?
We recently encountered a similar issue where the reverse proxy's kernel version had a bug, resulting in extremely slow uploads. After updating the kernel version, everything returned to normal.
Thank you,
You think the reason is version Jira right?
And we need update version jira to pass the problem?
We are using Jira Data Center 9.4.2
The issue might not be related to the JIRA version. If accessing it directly without going through the reverse proxy results in normal speed, the investigation can be conducted at the reverse proxy level
Currently, I am installing Jira Data Center behind the proxy because my company require it. But the speed upload file is too slow.
I haven't found any information to fix that.
You can advice me more information to fix that?
Thank you so much
Is it possible to temporarily use a 4-layer reverse proxy to directly forward port 8080 to the JIRA node for testing purposes?
