Urgent Lucene Exception Issue
Dylan
Could you please advise how this issue:
TP-Processor13 ERROR [com.atlassian.bonnie.ConcurrentLuceneConnection] Error closing writer. java.io.FileNotFoundException: /opt/jira/indexes/comments/_4ubij.fnm (No such file or directory)
Thread-228 ERROR [atlassian.core.user.UserUtils] [Ljava.lang.StackTraceElement;@258e5d0e
Thread-228 ERROR [event.listeners.search.IssueIndexListener] Error re-indexing changes for issue 'current issue'
com.atlassian.jira.issue.index.IndexException: com.atlassian.bonnie.LuceneException: org.apache.lucene.store.LockObtainFailedException: Lock obtain timed out: SimpleFSLock@/opt/jira/indexes/comments/write.lock
can be resolved in JIRA.
I've deleted the write.lock file from directory /opt/jira/indexes/comments/ and restarted JIRA but it did not help. The problem with Lucene still exists.
Please advise how this Lucene Exception can be resolved.
Dylan
tier-0 grump
April 4, 2012
In these cases it's not enough to clear out the lock file - you nearly always have to delete the indexes and then reindex. If the problem persists, then you may have to up your open file limit, as this is often the root cause of files not being there, otherwise it's an early sign of hard disk failure...
Joe Clark
April 4, 2012
For urgent requests, you should use https://support.atlassian.com - our support site is staffed by dedicated support engineers across the globe and are able to assist immediately with "system down" issues in most timezones.
Answers.atlassian.com is a community site and we have no dedicated staff to ensure prompt responses to critical issues.
I did a search in our knowledge base and found a couple of articles that might be helpful:
Register today
