Usage of multiple verbose filters
Some Guy
I created multiple (verbose) filters which give me a set of issues. For example
Filter "A"
issueType NOT IN (Defect, Test)
and filter "B"
createdDate >= "2024-01-01"
In the next step, I want to use that two filters in other queries like this
"Epic Link" = MyEpic AND filter IN (A,B)
This output is a full outer join with all the issues from filter A and filter B but I need a inner join, which works with
"Epic Link" = MyEpic AND filter IN (A) AND filter IN (B)
Is there a way to make the query as short (and readable) as possible with a inner join?
Thanks.
Kalyan Sattaluri
August 19, 2024
Hello @Some Guy
What you have is as best you can get.
  • Filter = A OR Filter = B
  • Filter = A AND Filter = B
You cannot get more succinct than that.
Benito Jiménez _Sevidev_
August 19, 2024
In my opinion, to increase visibility, I would include all clauses in the same filter, separating searches with line breaks:
issueType NOT IN (Defect, Test) AND
Obviously, the filter is longer, but at a glance, the user can understand the filter's clauses.
Hope this help you!
Kind regards.
Some Guy
I think we use the server version, unfortunately I cannot use multiple lines to separate it.
August 20, 2024
Hi @Some Guy , you can start a new line from Jira JLQ search with Shift + Intro. Other Alternative is to build the query in an external text editor and copy/paste in Jira.
Like Some Guy likes this
