Use Custom Field (multi user picker) as condition for workflow transition
Renske de Boer December 9, 2013
I have a Custom Field of type "multi user picker". I would like to use the user(s) specified in this field as condition for a transition in my workflow. Is this possible?
If I use the condition "User Is In Group Custom Field", the custom field I would like to use does not appear in the Group Selector list.
I would appreciate any help you can provide.
RambanamP
December 10, 2013
did you installed JSU plugin ?
the "User Is In Custom field" condition is from the JSU plugin
https://jsutil.atlassian.net/wiki/display/JSUTIL/JIRA+Suite+Utilities+Workflow+Conditions
Renske de Boer December 10, 2013
That solved the issue. Thank you!
Jonathan Harber
I have a similar problem.  I cannot get the Condition to work on my transition.  When the user selects BRM from a 2 choices BRM and RI (Non-cash) in a Custom Field named Purchase Method, I want the workflow to go to @BRM.  We have JSU installed.  Here are pictures of the workflow, but using the pictured Condition, the workflow stops at Approved by PM?BRM Gear Workflow.JPG Condition of BRM.JPG
ioann sys June 1, 2018
Hello!
How to compare UserPicker (multi) values with empy string ("", null)?
Nic Brough -Adaptavist-
June 1, 2018
To answer your question as stated, custom-field-value.equals("")
In reality, that will not work, because an empty custom field is not "" or even null, you will get a not found error as it doesn't exist at all.
In that case a simple "(if custom-field-value)" will do the right test for you.
Nice one)
Thank you!
p.s.: resolved as {code}{Approver} != /nobody.*/{code}
Jobin Kuruvilla [Adaptavist]
December 9, 2013
Did you try the "Users in custom field" option? See if that works.
Hello Jobin, thank you for your answer. I don't see the "Users in custom field" option. The only condition options related to users are "User Is In Group", "User Is In Group Custom Field", "User Is In Project Role" and the assignee and reporter options.
I tried the "User Is In Group Custom Field" option, but my custom field does not appear in the list. Do I need to configure it in some way?
