Use Scrptrunner call REST API response json error
Vũ Tuấn Anh _VF-IT-KVH_ November 12, 2024
Code
def post(def hostUrl, def endpoint, def body, def token) {
    if (hostUrl.toString().contains('&') || hostUrl.toString().contains('?')) {
        log.error 'The parameters of the endpoint must be included in the query variable'
        return
    def client = new RESTClient(hostUrl)
    client.setHeaders([
            'Accept'       : ContentType.JSON,
            'Authorization': "Bearer $token"
    client.handler.success = { HttpResponseDecorator response, json ->
        json
    client.handler.failure = { HttpResponseDecorator response ->
        log.error response.entity.content.text
    client.post(
        path: endpoint,
        body: body,
        contentType: ContentType.JSON
JSON reponse
ResponseMsg: [
        MSGCODE: 0,
        MSGTYPE:S,
        MSGINFOR:Hold vehicles completed,
        MSGDATA: [
                KEY:HSP-1099,
                VAL: 5,
                DESC: DONE
                KEY:HSP-1100,
                VAL: 5,
                DESC: DONE
                KEY:HSP-1101,
                VAL: 5,
                DESC: DONE
Radek Dostál
November 13, 2024
So what exactly is your question?
Vũ Tuấn Anh _VF-IT-KVH_ November 27, 2024
I fied it.
Register now
