Use aui-select2 in gadget's configuration screen
Michael Kornatzki
September 25, 2024
i have created a gadget with a multiselect list in the gadget's configuration screen.
Now I want to use aui-select2, but I can't find the right place to specify it.
When I click on the button to edit the gadget-configuration, there is no event (or i can't find it).
In Javascript simply use
AJS.$(document).ready(function() {
AJS.$(“#dashboards”).auiSelect2();
does not work.
Probably because the configuration page is not displayed when loading (display: none)
Thanks in advance
Michael
Tuncay Senturk _Snapbytes_
Hi @Michael Kornatzki
I know gadgets and JavaScript in XML can be a pain in the neck. I usually use the following approach to dynamically retrieve select options via REST and fill the select component accordingly. I hope that helps.
userpref: "mySelect",
label: "Label",
type: "callbackBuilder",
callback: function (parentDiv) {
var componentSelect = AJS.$("<select/>").attr({
class: "select"
// call your rest and fill select component with options
AJS.$.get("__ATLASSIAN_BASE_URL__/rest_service", function (data) {
AJS.$(data).each(function () {
var option = AJS.$("<option>").attr('value', this.value).text(this.label);
if (gadget.getPref("mySelect") == this.value) {
option.attr("selected", "true");
componentSelect.append(option);
parentDiv.append(componentSelect);
I also used select2(), but I can't say it is the best approach.
Best
SERVER
Register now
